Baggage door lock
rv10rob(at)gmail.com
PostPosted: Mon Mar 30, 2009 8:31 am    Post subject: Baggage door lock Reply with quote
Anyone know of a specific model lock that will work with the baggage door on the RV-10?  I bought one at Home Depot yesterday, but it has a different style latch (thinner and smaller "hole" than the Van's F-1062 latch that ships with the kit).  Before I attempt to make the Home Depot lock/latch work, I wanted to see if anyone is aware of a lock that will just work with the latch in the kit.  Note I'm not using the ignition switch, so it didn't make sense to buy that set from Van's.
Thanks...
-Rob
Rob Kochman
RV-10 Wings
Woodinville, WA (near Seattle)
http://kochman.net/N819K
LarryRosen
PostPosted: Mon Mar 30, 2009 9:06 am    Post subject: Baggage door lock Reply with quote
They are Aircraft Spruce locks.
ACS p/n 11-01600
They are shold in sets of 2 for $26.60
<http://www.aircraftspruce.com/catalog/elpages/igswitches.php>
towards the bottom of the page.
Larry Rosen
from Van's.
Thanks...
-Rob
Rob Kochman
RV-10 Wings
Larry Rosen
#40356
N205EN (reserved)
<http>
planesmith(at)hotmail.com
Hi Rob C
This is what I used from Aircraft Spruce. They feel a little more solid than the locks at Home Depot.
NOTE: It only comes with one key even though two are pictured.
Vern Smith (Finishing #324)
Click Image to Enlarge
ACS DOOR AND
BAGGAGE LOCK SETS
P/N 11-01600 $26.60
The door and baggage locks furnished with the ignition switches above are also available separately. Set of two locks (one door and one baggage lock) furnished with one key mated to both locks. The baggage lock may be used as second door lock if preferred.
  Date: Mon C 30 Mar 2009 09:27:28 -0700
Subject: Baggage door lock
Anyone know of a specific model lock that will work with the baggage door on the RV-10?  I bought one at Home Depot yesterday C but it has a different style latch (thinner and smaller "hole" than the Van's F-1062 latch that ships with the kit).  Before I attempt to make the Home Depot lock/latch work C I wanted to see if anyone is aware of a lock that will just work with the latch in the kit.  Note I'm not using the ignition switch C so it didn't make sense to buy that set from Van's.
Thanks...
-Rob
Rob Kochman
RV-10 Wings
Woodinville C WA (near Seattle)
ttp://www.matronics.com/Navigator?RV10-List
ronics.com
ww.matronics.com/contribution
Windows Live™ SkyDrive: Get 25 GB of free online storage. Check it out. [quote][b]
n277dl
PostPosted: Mon Mar 30, 2009 9:25 am    Post subject: Re: Baggage door lock Reply with quote
Speaking of baggage door locks....
anyone remember where I put the key to mine? Very Happy Very Happy My wife swears I didn't give it to her. I know it's put up somewhere just can't remember where.
DO NOT ARCHIVE
Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes.
pascal(at)rv10builder.net
PostPosted: Mon Mar 30, 2009 9:37 am    Post subject: Baggage door lock Reply with quote
http://wcurtis.nerv10.com/08fuselage/fuselage34a.html
These work.
Pascal
Sent: Monday, March 30, 2009 8:27 AM
Thanks...
-Rob
Rob Kochman
RV-10 Wings
msausen
PostPosted: Mon Mar 30, 2009 9:38 am    Post subject: Baggage door lock Reply with quote
That’s odd as I got my locks from HD also and had no problem putting it in the baggage door. If you watch for them, you can usually find 3 keyed alike for the baggage and main doors.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Monday, March 30, 2009 12:27 PM
Thanks...
-Rob
Rob Kochman
RV-10 Wings
PostPosted: Mon Mar 30, 2009 10:51 am    Post subject: Baggage door lock Reply with quote
find the lock number and get another key made based on the code- if it's a
AS purchased call them they can get you the key, if it's Home depot, go
there and buy another lock with the same number.
No time to be looking for keys when there is other stuff, like tools, to
find and building the plane.
Are you sure your wife didn't take it?? maybe a bargaining chip for future
use?? hmm
good luck with that key either way.
Sent: Monday, March 30, 2009 9:25 AM
Subject: Re: Baggage door lock
where.
DO NOT ARCHIVE
Doug
&quot;Fools&quot; are always more creative than process people and will
http://forums.matronics.com/viewtopic.php?p 36881#236881
ron.mcgann(at)baesystems.
PostPosted: Mon Mar 30, 2009 2:06 pm    Post subject: Baggage door lock Reply with quote
I used the 2 keyed alike Spruce locks on the baggage door and pilot’s door. That left the copilot side door to lock. I did not really want another lock on the RHS, so built an internal ‘lock’ for the RHS door. A piece of angle with a nut/bolt that prevents retracting the rack. Took 5 minutes to make, is very secure, is easy to insert/remove and there is no way you can open the door from the outside (or inside for that matter).
Ron
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Tuesday, 31 March 2009 4:04 AM
Subject: RE: Baggage door lock
Michael
Thanks...
-Rob
Rob Kochman
RV-10 Wings
[b]http://www.matronics.com/Navigator?RV10-List[b][b]http://forums.matronics.com[b]http://www.matronics.com/contribution
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
 Filesize:  93.06 KB
 Viewed:  10084 Time(s)
carl.froehlich(at)cox.net
PostPosted: Mon Mar 30, 2009 3:41 pm    Post subject: Baggage door lock Reply with quote
I’ll use a tubular key cam lock. I have one on the baggage door of my 8A as I was concerned that a flat key could break off in the lock more easily than a tubular key.
For the 10, recommend the MFW-1058 from Fort Lock. Here is a link: http://www.securitybase.com/Web_store/ws400CS.cgi?category=Cam+Locks&no_search=Y
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
Thanks...
-Rob
Rob Kochman
RV-10 Wings
PostPosted: Mon Mar 30, 2009 4:14 pm    Post subject: Baggage door lock Reply with quote
Thanks, all, for the advice.  Sounds like I'll be placing an order with ACS in the near future.
-Rob
On Mon, Mar 30, 2009 at 9:27 AM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
Thanks...
-Rob
Rob Kochman
RV-10 Wings
Rob Kochman
RV-10 Wings
dmaib@me.com
PostPosted: Tue Mar 31, 2009 12:36 pm    Post subject: Re: Baggage door lock Reply with quote
I used the door locks from Steve Dinieri's iflyRV10.com. I just had him send me a third lock keyed the same as the cabin doors. Worked very nicely. Sorry, I don't have a photo. Seems like I took fewer and fewer photo's as I got near finishing!
David Maib
RV-10 #40559
New Smyrna Beach, FL
