apilot(at)surewest.net Guest
Posted: Sun Mar 29, 2009 12:08 pm Post subject: fuel flow meter |
Do any of the Kolb clan use a fuel flow meter? Would like one for my Mark IIIC. Vic
ElleryWeld(at)aol.com Guest
Posted: Sun Mar 29, 2009 2:22 pm Post subject: fuel flow meter |
I useed a Fuel flow meter in my firestar and I will install one in my MK3Xtra also I got it from Boaters World
Ellery in Maine
Building MK3Xtra
In a message dated 3/29/2009 3:08:34 P.M. Eastern Standard Time, apilot(at)surewest.net writes:
| Quote: | --> Kolb-List message posted by: <apilot(at)surewest.net>
Do any of the Kolb clan use a fuel flow meter? Would like one for my Mark IIIC. es y - MATRONICS WEB FORUMS =========================< - List Contribution Web Site ; =========================
A 100126575x1220439616x1201372437/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DfebemailfooterNO62"> See yours in just 2 easy steps!
by0ung(at)brigham.net Guest
Posted: Sun Mar 29, 2009 5:03 pm Post subject: fuel flow meter |
I hooked an aux input for the EIS to a fuel sender… it reads fuel level on the EIS to tenths of gallons, I check the starting point from a glance in the tank to see it is near where I think it should be. On a x country I burn 4 gal per hour.. and can cross check the level on the EIS to the expected fuel burn and the flight timer. If the fuel in the tank gets below 3 gal indicated it lights up the master warning light. That is my limit for reserve.
Boyd
ulflyer(at)verizon.net Guest
Posted: Sun Mar 29, 2009 8:22 pm Post subject: fuel flow meter |
Got one on my Hawk. I have the fuel flow option on my Grand Rapids
Technologies EIS - so far for several years it been accurate and
worked. It has provided some interesting data related to prop pitch
relative to performance (climb/cruise), and fuel consumption rate.
jerb
At 03:07 PM 3/29/2009, you wrote:
my Mark IIIC. Vic
planecrazzzy Guest
Posted: Mon Mar 30, 2009 3:56 pm Post subject: Re: fuel flow meter |
I love my Fuel flow gauge...
Don't let'm sell you the one called miZer...
They just put a sticker over what it REALLY is Navman 2100
It "is" a good unit...
But they charged me over $100 bucks more under "aircraft"
Gotta Fly...
60.1 KB |
8278 Time(s) |
59.4 KB |
8278 Time(s) |
Posted: Mon Mar 30, 2009 4:20 pm Post subject: fuel flow meter |
You are right about the expensive miZer sticker I had the navman 2100 and
my wing man bought the miZer and paid about 100.00 more only to find out the
extra money was for the cover up sticker
Ellery building MK3Xtra
In a message dated 3/30/2009 6:58:31 P.M. Eastern Standard Time,
planecrazzzy(at)yahoo.com writes:
Gotta Fly...
planecrazzzy Guest
Posted: Tue Mar 31, 2009 11:02 am Post subject: Re: fuel flow meter |
Hey Ellery,
You should be just about done with the Mark III X by now.
I don't hang around here... So I haven't noticed if you've posted progress....
Don't know if you heard... But the guy you made the trade with...
Can't fly... either he gets air sick.... or he got scared...Don't know.
Gotta Fly...
Mike & "Jaz" the Flying Dog
Building Wittman- Buttercup
116.01 KB |
8262 Time(s) |
128.66 KB |
8262 Time(s) |
112.41 KB |
8262 Time(s) |
Posted: Wed Apr 01, 2009 5:10 pm Post subject: fuel flow meter |
I put the MK3xtra on hold for a while I am about to get back into it now
the guy that had my old firestar couldn't fly without getting air sick and sold
it to someone else in MN and I haven't heard from him in a while but he had
damaged a wing tip the last I knew I dont know if he was capable of the
repair or not
Ellery building Mk3Xtra
In a message dated 3/31/2009 2:03:44 P.M. Eastern Standard Time,
Hey Ellery,
progress....
Gotta Fly...
rlaird
Posted: Thu Apr 02, 2009 6:32 pm Post subject: fuel flow meter |
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
rlaird
Posted: Thu Apr 02, 2009 6:51 pm Post subject: fuel flow meter |
| Quote: | I got a Navman 3100 fuel flow meter.... my console wasn't big enough
for it, so I hand-made a box for it to go into, and put it on the
"floor" of my MkIII... all the power and cables are underneath, so it's
a clean installation.
[img]cid:part1.09010200.09010800(at)cavediver.com[/img]
438.03 KB |
8237 Time(s) |
Robert Laird
Houston, TX area
