Baggage Area & Door Straps
rv(at)thelefflers.com
PostPosted: Tue Mar 24, 2009 11:42 am    Post subject: Baggage Area & Door Straps Reply with quote
I think you would have a c/g issue causing the tail to hit the ground long
before there is a structural issue.
Tim Olson
PostPosted: Tue Mar 24, 2009 12:09 pm    Post subject: Baggage Area & Door Straps Reply with quote
I think vans says the baggage area is rated at 100lbs.
Of course, I've sat back there a few times doing work,
so in a NON-flying situation I'm sure it's not a structural
limit. But while flying it would be a CG or perhaps
structural limit. Much more than that and you'd
start to risk tipping it onto it's tail anyway though.
partner14 wrote:
<building_partner(at)yahoo.com>
Is there a maximum weight limit on what can go in the baggage
area.... I know all of us have spent some time in/on/sprawled in that
area, but is there a structural limit.... assuming that whatever
weight you put back there keeps you in an ok situation as far as
weight and balance. Also, has anyone found a source for a decent
strap to fasten to the door to not only use to pull the doors down,
but also pull them fully closed. Thanks
Don McDonald #40636 Airworthiness done, flight training not quite
-------- Don A. McDonald 40636
http://forums.matronics.com/viewtopic.php?p 35998#235998
partner14
PostPosted: Tue Mar 24, 2009 12:35 pm    Post subject: Baggage Area & Door Straps Reply with quote
I see what you guys are saying, but if you had two 220 pounders in the front seats, with noone in the rear seats, my guess (I'm not at the hanger) is that if you put 150 pounds in the baggage area, you wouldn't come close to flipping the plane on it's back, and should still be way within CG limits. Not that I'm planning on piling it up or anything!
Don
--- On Tue, 3/24/09, Tim Olson <Tim(at)MyRV10.com> wrote:
Subject: Re: Baggage Area & Door Straps
Date: Tuesday, March 24, 2009, 1:00 PM
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
partner14 wrote:
--> RV10-List message posted by: "partner14"
<building_partner(at)yahoo.com (building_partner(at)yahoo.com)>
http://forums.matronics.com/viewtopic.php?p=2359the Matronics List Features Navigator to f="http://www.matronics.com/Navigator?RV10-List" target=_blank>http://wp://forums.matronics.com/" target=_blank>http://forums.matronics.com< ; -->
Don A. McDonald
40636
Space Cadet
PostPosted: Tue Mar 24, 2009 2:26 pm    Post subject: Re: Baggage Area & Door Straps Reply with quote
Don't forget it's 100 (or 150) lbs times the maximum g-load under flight conditions that the structure has to support.
Dwight
bkbrown(at)minetfiber.com
PostPosted: Tue Mar 24, 2009 3:34 pm    Post subject: Baggage Area & Door Straps Reply with quote
As far as a strap to pull the door down, I'd think a 10" or so section of
tubular 3/4" nylon webbing, upholstered to match your interior and set to
hard points installed in the door would work just fine...
Bob Brown
Dick Sipp
PostPosted: Tue Mar 24, 2009 5:21 pm    Post subject: Baggage Area & Door Straps Reply with quote
From page two of the weight and balance section of the manual: Baggage
compartment load limit 150lbs. and is determined by the structural limits of
the baggage floor.
I recently re-weighed my 10 after painting and interior were completed.
1701 lbs and a CG of 108.6. This was about 25 lbs. more than I was hoping
for but appears to be about average for the fleet. Looking at many of the
reported weights below 1650 in Dan's table I am thinking many of these are
initial weights sans paint and or interiors. If not, my hat is off to
anyone completing a 10 with paint and interior at under 1650.
Dick Sipp
N110DV 40065 120 hours
gengrumpy(at)aol.com
PostPosted: Tue Mar 24, 2009 5:29 pm    Post subject: Baggage Area & Door Straps Reply with quote
I believe the plans say 100lbs in baggage compartment.
Straps? I used long leather laces woven together as temp straps.....2
yrs later they're still temp straps.
I put in simple screen door type handles to help pull in the aft part
of the door (to ensure aft pin locks) and tied the leather straps to
them.....
One day I'll find nicer straps (maybe)
grumpy N184JM
that area, but is there a structural limit.... assuming that
whatever weight you put back there keeps you in an ok situation as
far as weight and balance.
Also, has anyone found a source for a decent strap to fasten to the
door to not only use to pull the doors down, but also pull them
fully closed.
Don McDonald
#40636
Don A. McDonald
40636
pascal(at)rv10builder.net
PostPosted: Tue Mar 24, 2009 5:51 pm    Post subject: Baggage Area & Door Straps Reply with quote
Maybe I'm missing something about the door. I built the door so that the
rear closes each time when my 5 year closes the door, it's actually pretty
hard for it not to fit and if it doesn't the door simply wont close and that
is obvious if it's not right.
Are the issues with the stock Van's plastic or the rivethead door alum door
guides? I have the iflyrv10 guides and they simply "guide" the door closed.
Pascal
Sent: Tuesday, March 24, 2009 5:25 PM
I put in simple screen door type handles to help pull in the aft part of
them.....
grumpy N184JM
> Is there a maximum weight limit on what can go in the baggage area.... I
> know all of us have spent some time in/on/sprawled in that area, but is
> there a structural limit.... assuming that whatever weight you put back
> there keeps you in an ok situation as far as weight and balance.
> Also, has anyone found a source for a decent strap to fasten to the door
> to not only use to pull the doors down, but also pull them fully closed.
> Thanks
> Don McDonald
> #40636
> Don A. McDonald
> 40636
Ted French
PostPosted: Tue Mar 24, 2009 8:06 pm    Post subject: Baggage Area & Door Straps Reply with quote
I found a couple of good looking dog leashes at our local pet store.
Had them shortened with a small loop at the door end, installed with a
pin to a piece of c channel. Looks good and works well.
Ted
C-FXCS flying
fully closed.
Don McDonald
#40636
Don A. McDonald
40636
French_Edwin_L_(Ted).vcf
 Filename:  French_Edwin_L_(Ted).vcf
 Filesize:  502 Bytes
 Downloaded:  659 Time(s)
Ted French
RV-10 fuselage
LarryRosen
PostPosted: Wed Mar 25, 2009 3:54 am    Post subject: Baggage Area & Door Straps Reply with quote
I always liked the way the Columbia has its door strap attached. I will do something similar on my doors. Probably using a nylon strap, like that found on luggage. I may wrap the strap in my interior fabric. Attached is a photo of the Columbia door strap.
Larry Rosen
#356
[img]cid:part1.05000102.09090507(at)gmail.com[/img]
 Filesize:  64.61 KB
 Viewed:  12548 Time(s)
Larry Rosen
#40356
N205EN (reserved)
<http>
PostPosted: Wed Mar 25, 2009 6:52 am    Post subject: Baggage Area & Door Straps Reply with quote
That’s exactly what I described…tubular nylon webbing, sewn and upholstered to match your plane, attached at hardpoints.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen
Sent: Wednesday, March 25, 2009 4:54 AM
Larry Rosen
#356
 Filesize:  64.61 KB
 Viewed:  12542 Time(s)
BrianNC
PostPosted: Wed Mar 25, 2009 7:45 am    Post subject: Re: Baggage Area & Door Straps Reply with quote
Dwight
Just what I was going to say. It's when that 150lbs. becomes 300lbs. or greater under G loads and causes the structure to fail. That's why there is a limitation.
partner14
PostPosted: Wed Mar 25, 2009 8:41 am    Post subject: Baggage Area & Door Straps Reply with quote
Thanks guys for all your comments. The FAA inspector thought there shoiuld be some limit posted.... and now I'm off to the doggie store to find a leash suitable for my door strap.  I'm figuring I can attach a plate to the door then attach the strap.
I also assume if we were flying at, or close to max gross, or with a few extra bags in the back, that we would fly our aircraft accordingly.... no steep banks, inverted flight, etc.
Thanks again, you guys are great.... except you Pascal......... just kidding!
Don McDonald
Pascal, you making any trips to Spruce in the near future?
Date: Wednesday, March 25, 2009, 8:45 AM
--> RV10-List message posted by: "BrianNC" <EMINI2000(at)YAHOO.COM (EMINI2000(at)YAHOO.COM)>
Dwight
http://forums.matronics.comsp; --> http://foru - List Contribution We -Matt Dralle, Listm/contribution" target=_blank>http://www.matronics.com/contribution
Don A. McDonald
40636
