Torque values
Fox5flyer
PostPosted: Thu Mar 19, 2009 2:49 pm    Post subject: Torque values Reply with quote
I'm preparing to reinstall my prop and I'm ready to torque the AN5-10 bolts. The torque values off the standard chart are for 180-220 inch lbs. The manual that came with the prop says 150 inch lbs. I'll probably go by the manual, but it makes me wonder about this big 40 inch lb spread on the chart values. When faced with a big spread, which way is the recommended direction to go. Go with the lesser, somewhere in between, or the higher number? Also, I'm using a crow foot adapter. Does that make any difference to the values? Inquiring minds would like to know...
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
vetdrem
PostPosted: Thu Mar 19, 2009 3:21 pm    Post subject: Re: Torque values Reply with quote
the reference chart is to be used when the manufacture has not provided a specific torque spec. Always use the manufactures recommendations if provided.
A torque wrench is calibrated to be accurate when not using a crowsfoot, handle extension or any other modification to the tool. If you use a crowsfoot, you can mathematically convert the reading to take the added leverage provided by the crowsfoot into account, but be careful when doing that, mistakes are easy to make, and you could over torque the bolt very easily.
Louie
model 3 912ul
altus, ar
Paul A. Franz, P.E.
PostPosted: Thu Mar 19, 2009 3:46 pm    Post subject: Torque values Reply with quote
The specification that accompanies the prop is the one most relevant. These torque
settings are from engineering design. That said, the engineer usually specifies the
torque allowed for the bolt so I would check with the prop manufacturer's engineering
dept to make certain of their intentions.
If the crows foot is 90 deg to the wrench handle then it will not make a difference as
long as you carefully push the handle on the center pivot.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
"In Washington, one person's waste is another person's pork. Every
dime spent by the federal government has well-connected advocates
who swear the money is vital to the national interest. ... It's not
that people in government aren't as good or competent as those in
the private sector (though that may be true). The difference lies in
the incentives and feedback they face. Bureaucracies have little
check on what they do, no bottom line, no market prices for their
'output.' What they do have is an incentive to spend all the money
budgeted or risk getting less next year. As Milton Friedman used to
say, no one spends other people's money as carefully as he spends
his own. It is absurd to think the humongous constellation of
federal bureaucracies is going to identify and root out 'waste' in
any significant way. It's just not in the nature of the beast."
-- ABC's "20/20" co-anchor John Stossel
In general, the art of government consists of taking as much money as possible from
one party of the citizens to give to the other.
-- Voltaire (1764)
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Fox5flyer
PostPosted: Fri Mar 20, 2009 5:02 am    Post subject: Torque values Reply with quote
Thanks for the response, Paul. As I said in my original message, I'll be
using the manufacturer's recommendation.
What I'd really like to know is the answer to my first question. When there
is a big spread on a recommended torque value as I said below, what does
this mean in normal working conditions? Under what conditions does one use
the lower, somewhere in the middle, or higher number?
Deke Morisse
Mikado Michigan
- Joseph Joubert
Lynn Matteson
PostPosted: Fri Mar 20, 2009 5:39 am    Post subject: Torque values Reply with quote
My guess...and it's only that...is that for a wood prop, you'd use
the lower number in dry, less humid conditions, knowing that when it
got humid, the prop will take on moisture, swell and the tension on
the bolts would rise. On the other hand, if you used the higher
numbers on a "wet" prop, and conditions dried out, the prop would
shrink, causing the higher tension on the bolts to decrease.
I recently obtained a new wood prop from Sensenich...built in Florida
(read humid)...and installed it with 160 in lbs (their recommended
numbers were 130-160) of torque. I flew it as suggested and after the
first flight I re-torqued it to that same figure. After about 30
hours of flying, I noticed that there was a black dust on the
periphery of the drive flange. I re-checked the torque, and it was
down to about 85 in-lbs. I re-torqued to 160. What I think happened
was the prop was manufactured in humid conditions, sent up here to
Michigan where the winters are dry. The prop dried a bit, torque was
lost, and the prop began to "slip" on the drive flange, causing the
black dust....fretted paint from the prop. I've since checked torque
again, and it was down to 145. There is a sticker on the prop right
next to the hub which cautions "wood props need to be checked for
proper torque frequently in varying humidity conditions" or words to
that effect. I used to check my prop at oil changes, but now I'll do
a check between changes, too.
Deke, if you have a metal prop, all the preceding rambling won't
answer your question, but it should get some of the engineers in the
audience to warm up their fingers. : )
Lynn Matteson
Jabiru 2200, #2062, 615.2 hrs
Sensenich 62x46
Status: flying
On Mar 20, 2009, at 9:01 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
I'll be using the manufacturer's recommendation.
When there is a big spread on a recommended torque value as I said
below, what does this mean in normal working conditions? Under
what conditions does one use the lower, somewhere in the middle, or
higher number?
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
Lynn
Kitfox IV-Jabiru 2200
N369LM
Paul A. Franz, P.E.
PostPosted: Fri Mar 20, 2009 7:23 am    Post subject: Torque values Reply with quote
You're welcome. You should. However, dbl check with their engineering to be sure of
their intentions.
As a designer you may have reason to specify a lower torque setting. One comes to mind
is where the bolt goes into or through something that might distort in shape if given
the maximum allowable torque. Another case is where the bolt thread is far stronger
than the material it is anchored in like a steel bolt anchored in an aluminum casting.
The thread depth may not be sufficient to develop the maximum allowable torque in the
bolt.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
"It is natural to man to indulge in the illusions of hope. We are
apt to shut our eyes against a painful truth -- and listen to the
song of that syren, till she transforms us into beasts."
-- Patrick Henry
"The great advances of civilization, whether in architecture or
painting, in science or in literature, in industry or agriculture,
have never come from centralized government."
-- economist Milton Friedman (1912-2006)
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
Float Flyr
PostPosted: Fri Mar 20, 2009 1:48 pm    Post subject: Torque values Reply with quote
Going with the lower torque value will lead to much less stretching of materials including the prop blades. Speaking of which always go by the manufacturers recommendations. They may know something about the design of your equipment that you or I do not know.
Noel Loveys
CDN AME Intern
PP-Rec, Kitfox III-A
Areocet 1100 floats
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Thursday, March 19, 2009 8:18 PM
To: Kitfox List
Subject: Torque values
Deke Morisse
Mikado Michigan
- Joseph Joubert
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Roger Lee
PostPosted: Fri Mar 20, 2009 7:45 pm    Post subject: Re: Torque values Reply with quote
If you turn the crows foot 90 degrees from the handle then the torque difference is negligible, but if you keep it in line with the handle here is the proper way to calculate the new value. Open the post below.
Chapter%2007.pdf
Torque calculations with a crowfoot
 Filename:  Chapter%2007.pdf
 Filesize:  26.27 KB
 Downloaded:  538 Time(s)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Fox5flyer
PostPosted: Sat Mar 21, 2009 3:34 am    Post subject: Torque values Reply with quote
Thanks, Lynn, et al. I'm surprised how hard it's been to get good hard data
on these torque values. AC43.13 has some info--and good stuff too, but it
doesn't go deep enough and seems to assume we all know about interference
drag, etc. I called a local IA who couldn't definitively answer the
question either, other than to say that he usually just picks a value
somewhere in the middle of the spread. He also said he rarely bothers with
a torque wrench and just goes by feel, depending on what he's doing. After
wrenching on airplanes for 30 years, he probably has that "feel", but I
don't trust mine. He also said that the torque values are only a guide and
that "close is good enough" in most cases. I tend to agree with him for the
most part, but not with my prop! I want that puppy exactly like it's
supposed to be. Smile So, unless I can find some more information on this
I'm not going to worry too much about it.
Deke Morisse
Mikado Michigan
- Joseph Joubert
Lynn Matteson
PostPosted: Sat Mar 21, 2009 8:15 am    Post subject: Torque values Reply with quote
Hey, Deke, is it a metal prop? Or does it have a metal hub? The
numbers on those are a lot less critical (I would think) than if the
bolts are going to be "crushing" wood. Also, I noticed that you said
you have AN5-10 bolts....I can't believe the "-10" part. This would
make the bolts too short to go through almost anything, so I'm
assuming that's a typo...is it? I'm thinking that if they're that
short, they're only going through metal, so the range is probably not
as critical as a wood application.
Lynn Matteson
Jabiru 2200, #2062, 616.5 hrs
Sensenich 62x46
Status: flying
hard data on these torque values. AC43.13 has some info--and good
stuff too, but it doesn't go deep enough and seems to assume we all
know about interference drag, etc. I called a local IA who
couldn't definitively answer the question either, other than to say
that he usually just picks a value somewhere in the middle of the
spread. He also said he rarely bothers with a torque wrench and
just goes by feel, depending on what he's doing. After wrenching
on airplanes for 30 years, he probably has that "feel", but I don't
and that "close is good enough" in most cases. I tend to agree
with him for the most part, but not with my prop! I want that
puppy exactly like it's supposed to be. Smile So, unless I can
find some more information on this I'm not going to worry too much
about it.
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
Lynn
N369LM
Fox5flyer
PostPosted: Sat Mar 21, 2009 4:17 pm    Post subject: Torque values Reply with quote
Yup, Lynn, it's a metal cockpit adjustable prop hub by NSI (CAP). The
blades are all carbon fiber by Warp Drive. The bolts go through the crank
hub and into the prop hub about an inch deep then the bolt heads are all
safety wired on the engine side of the crank hub.
Deke Morisse
Mikado Michigan
- Joseph Joubert
