gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Mon Mar 16, 2009 8:47 am Post subject: Monowheel outrigger double downlock spring mod |
Just added a second spring to my downlock mechanism. Pretty easy mod and now provides a resounding audible clunk
confirmation when lowering the gear. The audible confirmation with just the stock springs was getting somewhat passive and difficult to confirm.
Glenn
Windows Live™ Contacts: Organize your contact list. Check it out.
20.73 KB |
2644 Time(s) |
fklein(at)orcasonline.com Guest
Posted: Mon Mar 16, 2009 10:54 am Post subject: Monowheel outrigger double downlock spring mod |
Glenn...very nice...now why didn't I think of that?...yu b a clever fella...
Fred
do not achive
On Mar 16, 2009, at 9:46 AM, glenn crowder wrote:
[quote] Just added a second spring to my downlock mechanism. Pretty easy mod and now provides a resounding audible clunk confirmation when lowering the gear.
gcrowder2
Posted: Mon Mar 16, 2009 5:11 pm Post subject: Monowheel outrigger double downlock spring mod |
Hey Fred C thanks. No negatives yet and provides a warm and fuzzy feeling on short final that all is well. I also replaced the
original nylon legs with MDS filled nylon legs purchased from McMaster. I am experimenting with 1/4" longer legs to reduce the
rocking even more. Now there is no wing rocking at all until the TW is lifted and then its only there for a couple seconds before
rotation. Much improved on landing as well as soon as the main is down C the OR wheels are down as well preventing any side
loading or weight transfer from getting started. This does add a slight preload to the legs but they become HIGHLY loaded if
any side to side weight transfer starts up with the standard length legs. I really like it so far and can taxi up to 45 mph with
no rocking whatsoever but YMMV.
Glenn
Subject: Re: Monowheel outrigger double downlock spring mod
Date: Mon C 16 Mar 2009 11:52:28 -0700
Posted: Mon Mar 16, 2009 6:04 pm Post subject: Monowheel outrigger double downlock spring mod |
On Mar 16, 2009, at 6:09 PM, glenn crowder wrote:
| Quote: | | No negatives yet and provides a warm and fuzzy feeling on short final that all is well. |
Hey Glenn...sounds good...I've always been troubled by the eccentric loading on the bolt which holds the spring (on the original).
| Quote: | I also replaced the original nylon legs with MDS filled nylon legs purchased from McMaster. I am experimenting with 1/4" longer legs to reduce the
rocking even more. Now there is no wing rocking at all until the TW is lifted and then its only there for a couple seconds before rotation. Much improved on landing as well as soon as the main is down, the OR wheels are down as well preventing any side loading or weight transfer from getting started. |
Now are those "MDS filled" nylon legs a different composition from the originals?
BTW, how many ponies in that Soob of yours at this point? Weren't you bumping up the hp?
Fred
gcrowder2
Posted: Wed Mar 18, 2009 11:53 am Post subject: Monowheel outrigger double downlock spring mod |
Somebody on the forum recommended the MDS legs. They do seem springier C maybe just
because they're new. I really like the longer length!
No recent upgrades to my engine although my engine guy really wants to do a complete
roller cam with roller lifters. He says this will add 15 hp and not create any more heat
since what we're actually doing is eliminating friction. The rollers allow him to modify the cam profile a bit to take advantage. Will probably go to the MPFI system at the same time possibly adding 5-10 over my current single point Ellison throttle body system.
Wintertime project was to get my dual electrical system installed and working.
Springtime project will be to get the exhaust augmentation system going C hopefully reducing cooling drag significantly. Attached a pic.
Glenn
Date: Mon C 16 Mar 2009 19:04:03 -0700
rocking even more. Now there is no wing rocking at all until the TW is lifted and then its only there for a couple seconds before rotation. Much improved on landing as well as soon as the main is down C the OR wheels are down as well preventing any side loading or weight transfer from getting started. |
BTW C how many ponies in that Soob of yours at this point? Weren't you bumping up the hp?
Fred
| Quote: | http://www.matronics.com/Navigator?Europa-List
ronics.com
ww.matronics.com/contribution
| Windows Live™: Keep your life in sync. Check it out.
25.88 KB |
2635 Time(s) |
frans(at)paardnatuurlijk. Guest
Posted: Wed Mar 18, 2009 1:21 pm Post subject: Monowheel outrigger double downlock spring mod |
| Quote: | No recent upgrades to my engine although my engine guy really wants
to do a complete
If you modify the cam profile, you are not just eliminating friction.
You take advantage of the lessened friction to introduce a more
aggresive cam profile, so the engine can digest more air and fuel. This
addition of more air and fuel will certainly cause more heat. If you
burn something, heat will develop. Burn more, and you will get more
heat.
Think about this way: If the roller lifters save 15 hp, this means that
the old lifters would somehow "consume" 15 hp. 15 hp is a tremendous
amount of heat, the lifters would have melted if they were consuming
these 15 hp's... So, this was obviously not the case, so these 15 hp's
are coming from something else.
Frans Veldman
gcrowder2
