Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed Mar 18, 2009 9:43 am Post subject: Tailcone Question |
I am just starting to rivet the tailcone. I need to know if I can start riveting one side skin and the bottom skin without clecoing (is that even a word?) the other side skin in place. It seems like I can but should I?
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Tim Olson
Posted: Wed Mar 18, 2009 10:14 am Post subject: Tailcone Question |
It would probably work, but you may want to at least put some clecos in
on the other side and help ensure that all the parts are in alignment
so everything ends up straight. With the matched hole system though
I bet it would come out ok.
Strasnuts wrote:
A&P, ATP
typed CE-525(s), CE-500
RV-10 emp started!!!!
N801VR reserved
Phil.Perry(at)netapp.com Guest
Posted: Wed Mar 18, 2009 10:28 am Post subject: Tailcone Question |
I clecoed all of mine together, but left a space for the saw horses all
the way around.
This way I could sit the tailcone on the saw horses and roll it
side-to-side so I could get access to the required area.
You may be asking because you don't have a rivet partner and you're
trying to shoot and buck at the same time. I managed to get a highly
unskilled helper in my wife. She dropped the rivets in the hole and
held them (flush side) in position with a bucking bar. I shot them from
the backside with a back-rivet set. Looks great and she didn't have to
develop any skills shooting or bucking.
Phil
Strasnuts
Posted: Wed Mar 18, 2009 10:40 am Post subject: Tailcone Question |
Thanks for the quick reply,
I have done 99.9% of the build on my own so far. My wife is making most of
the money so I will get a cheaper helper
It's getting to the point where I NEED some more hands!
780 Hours
jcumins(at)jcis.net Guest
Posted: Wed Mar 18, 2009 10:49 am Post subject: Tailcone Question |
Phil
Thanks for letting us know that trick. I am sure my wife can do the same
thing, I also have a very large flat steel plate that I use for back
riveting and it works great I am sure it will work for this.
Thanks again.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
rene(at)felker.com Guest
I did a lot of my tail cone by myself. I made small back rivet table
(stacked boards) and left as many clecos in as possible and then just stuck
my head in and started riveting. As you start filling rivet holes it gets
easier since you don't have as many clecos in to get in the way (hitting the
table).
I left both side skins on in fear that I would get the bulkheads out of line
somehow.....
Rene' Felker
RV-10 N423CF Flying
801-721-6080
ogdenk
Posted: Wed Mar 18, 2009 10:58 am Post subject: Tailcone Question |
Having just been there and done that, I didn't have both side skins on while riveting and everything came out fine. I think the plans start you on the bottom skin IIRC and you really have to have the frames in place with the stiffeners, you won't be able to easily get the frames over the stiffeners once riveted.
I put my clecoes on the inside of the skins and did as many rivets as possible by back riveting. This worked great, just be sure there is no gap between the stiffener and skin and that you're solid on the back riveting plate.
Once the top skins go on, it really helps to have a ten year old (or petite spouse) to sit inside and buck rivets for you. Someone else mentioned this a while ago and offered their ten year old for rent, luckily I had one available!
Hope this helps.
Kent
#40710 waiting for wing kit
| Quote: | >> "Strasnuts" <sean(at)braunandco.com> 3/18/2009 1:43 PM >>>
--> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com>
A&P, ATP
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=235111#235111
_-============================================================
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?RV10-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
johngoodman
Posted: Wed Mar 18, 2009 11:28 am Post subject: Re: Tailcone Question |
I'd really like to get one of those ten year olds - how much do they cost?
In a more serious vein, this is a good time to think about a couple of Adel Clamp mounts in the aft tailcone area while it's easy to get to it. Even if you run conduit back there, you'll need some way to hold the conduit in place - Adel Clamps.
dmaib@me.com
Posted: Wed Mar 18, 2009 11:48 am Post subject: Tailcone Question |
That is exactly how Mary and I did ours. Worked fantastic and looks
great.
David Maib
40559
the way around.
Phil
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
ogdenk
Posted: Wed Mar 18, 2009 12:55 pm Post subject: Tailcone Question |
This is an outstanding suggestion, and one which I wish I had thought about before finishing the tailcone. Still won't be too hard to do before the tailcone is mounted to the fuse. I wish Van's had put some suggestions in the plans for doing this. You need some wires for the lights, plus the elevator trim at a minimum, is there anything else (magnetometer etc) that might go back there? Looking at some builders sites (Deem's comes to mind) I found some pictures of what they did that gave me some ideas, but I like the conduit idea best as it should provide the best protection for the wire.
On a related note, I wonder if anyone has installed one of these integrated position/strobes in the rudder:
http://www.aircraftspruce.com/catalog/elpages/posistrobe.php (manufacturer at http://www.aveoaviationlights.com/)
Looks pretty cool, no external HV power supply. Kind of expensive though. I looked at the drawings for the light and measured the flat spot on the rudder fairing, the light is exactly the right size. Maybe that's standard for these lights (e.g. the same as the A625 light that Van's sells)?
Kent Ogden
#40710 Waiting for wing kit
| Quote: | >> "johngoodman" <johngoodman(at)earthlink.net> 3/18/2009 3:28 PM >>>
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net>
#40572 QB Fuselage, wings finished. Finish Kit started.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=235130#235130
_-=
_-=
_-=
_-=
millstees(at)ameritech.ne Guest
Posted: Wed Mar 18, 2009 1:33 pm Post subject: Tailcone Question |
I built a shelf for my magnetometer, about 1/2 way back in the tailcone (see picture), and it would of been lots easier to do while building the tailcone. Simply mount it on the top longeron, and it will be very close to level. You can the fine-tune the level and direction, when you install the magnetometer.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kent Ogden
Sent: Wednesday, March 18, 2009 3:47 PM
Subject: Re: Tailcone Question
Kent Ogden
N711JG reserved
http://www.matronics.com=======================
bsp; the Web href="http://forums.matronics.com">http://forums.matronics.com
_p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
&~2
1002.55 KB |
15052 Time(s) |
bkbrown(at)minetfiber.com Guest
Posted: Wed Mar 18, 2009 1:50 pm Post subject: Tailcone Question |
We stood the cone on end, supported it high enough I could stand on a stool. I stood inside (with hearing protection!) and a rivet gun, my wife used a bucking bar to back rivet from the outside. Worked like a champâŚbut donât lose your balance!!
Sent: Wednesday, March 18, 2009 11:56 AM
Hope this helps.
Kent
A&P, ATP
N801VR reserved
href="http://www.matronics.com/Navigator?RV10">http://www.matronics.com/Navigator?RV10-List
bsp; - MATRONICS WEB FORUMS -
bsp; - List Contribution Web Site -
bsp; -Matt Dralle, List Admin.
Œ¡âş~â°Ă²,Ă g(âĹ ĂMĂGq¢zĂÂŽ
Posted: Wed Mar 18, 2009 2:12 pm Post subject: Tailcone Question |
Worlds largest dunce cap.
From: Bob and Karen Brown [mailto:bkbrown(at)minetfiber.com]
Sent: Wednesday, March 18, 2009 4:49 PM
Subject: RE: RV10-List: Tailcone Question
Subject: Re: RV10-List: Tailcone Question
Hope this helps.
Kent
A&P, ATP
N801VR reserved
MauleDriver(at)nc.rr.com Guest
Posted: Wed Mar 18, 2009 2:20 pm Post subject: Tailcone Question |
my 2 more cents.... I did as much of the riveting solo as possible. An
approx 1'x2'x3/8" back rivet plate made most of that possible. It was
all cleco'd together from the beginning
Some of the rivets in the top deck required some 2 person riveting.
Contrary to most, I found it easiest to teach my mate to operate the gun
when back riveting or flush riveting. The bar can be harder to handle
and definitely does the damage... and I want to be the one that does the
damage.
Strasnuts wrote:
A&P, ATP
N801VR reserved
http://forums.matronics.com/viewtopic.php?p 35111#235111
Posted: Wed Mar 18, 2009 3:29 pm Post subject: Tailcone Question |
I too wish I had built a shelf for my dual magnetometers back then. I
built and discarded one I tried to build to hug the very top of the cone
after the fuse was all together.. The challenge is figuring out an
optimal location relative to all the magnetic fields to be installed
later. 1) the elevator trim motor, 2) the pitch trim motor, 3) the
strobe power unit (which assume kicks of some field).
I Installed my tray further forward in the same bay and biased to the
left side of the cone to put it equidistant from the 2 trim motors.
Of course, the unit may not be as sensitive as suggested. Somewhere
down the line some one will have a documented a serviceable location
for the various brands and configs.
Steve Mills wrote:
| Quote: | I built a shelf for my magnetometer, about 1/2 way back in the
Jim Berry
Posted: Wed Mar 18, 2009 5:30 pm Post subject: Re: Tailcone Question |
I would second Rene's recommendation to back rivet the tail cone. I was able to back rivet the entire cone, minus about 6 rivets in the narrowest aft-most portion. A suggestion that I have not seen mentioned before is that I would recommend back riveting the F-1047B-R,L and C stiffeners to the F-1075 skin before clecoing the skin to the bulkheads. It is much easier to do this with the skin flat on your bench. Just leave the rivet holes open where the stiffeners cross the bulkheads. I had some concern that I would not be able to get the stiffeners into the corresponding bulkhead slots, but with a little flexing of the stiffeners it worked out fine. And saved a lot of riveting inside the tail cone.
Jim Berry
40482
N15JB
Posted: Wed Mar 18, 2009 6:14 pm Post subject: Tailcone Question |
I too back riveted almost the entire tail cone and all the side and bottom
skins (except for those few...) wherever I can figure out a way to back
rivet, I do!!
tsts4
Posted: Thu Mar 19, 2009 4:39 am Post subject: Re: Tailcone Question |
I did the saw horse method, turning the tailcone over and from side-to-side as required. I did as much as I could solo and then recruited my wife to shoot while I bucked. Came out fine.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
