rv8iator
Posted: Sun Mar 15, 2009 11:44 am Post subject: Rotax w/ Perihelion OVM |
Hello All...
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Attached is a PDF of Z-16 with the incorporation of Perihelion OVM into the electrical system for a Rotax powered KitFox. I am new to the Rotax.
I purchased this to provide over voltage protection for the electrics powered by the built-in alternator on the Rotax. I am not entirely clear on the operation of the Rotax alternator nor is the Rotax manual. It contains only a schematic, no “theory of operation”. It has what appear to be two B leads. Per Bob’s schematic breaking one B lead shuts down the alternator. Per Rotax the output is 20A(at)5,000 RPM. Thus a 20A relay would be suitable if each B lead produces 10A max. Since Rotax calls the voltage regulator a rectifier/regulator I am assuming each B lead is single phase AC but I am not clear as to how breaking one B lead would shut down the alternator.
My intent then is to switch the relay per Bob’s Z-16 schematic using your OVM as opposed to the crowbar method.
A couple of questions: Why both a fusable link and 5A CB in series on the master sw/OV disconnect relay? How does breaking one line from the 'dynamo' shut it down, or does it? Per this schematic power is required from the battery to close the OV disconnect relay and bring the 'dynamo' on-line. Thus with a dead battery there is no way to bring the 'dynamo' on-line?
Thanks for your help…
Chris Stone
RV-8 wiring
Kitfox-7 wiring
 Download |
| Filename: |
Z-16_w-OVM.pdf |
45.4 KB |
| Downloaded: |
364 Time(s) |
_________________ C. Stone (RV8iator) |
Posted: Sun Mar 15, 2009 12:20 pm Post subject: Rotax w/ Perihelion OVM |
| Quote: | | I purchased this to provide over voltage protection for the electrics powered by the built-in alternator on the Rotax. I am not entirely clear on the operation of the Rotax alternator nor is the Rotax manual. It contains only a schematic, no theory of operation. It has what appear to be two B leads. Per Bob's schematic breaking one B lead shuts down the alternator. Per Rotax the output is 20A(at)5,000 RPM. Thus a 20A relay would be suitable if each B lead produces 10A max. Since Rotax calls the voltage regulator a rectifier/regulator I am assuming each B lead is single phase AC but I am not clear as to how breaking one B lead would shut down the alternator. |
You have two wires coming out of a wall socket to
power some device, but the ON-OFF switch needs to
open or close only one leg of the wall-power to
control the device. Those are not "B" (battery)
leads coming off the engine. They are as you've
guessed, two leads with single phase, AC power on them.
The B-leads are the "R" and "B+" wires that
come off the rectifier/regulator.
Breaking one of the green ac power input leads
is the same as the single switch on your desk
lamp. The PM alternator continues to develop
voltage but it has no place to go.
| Quote: | | A couple of questions: Why both a fusable link and 5A CB in series on the master sw/OV disconnect relay? |
This is to accommodate some legacy design rules adopted
from certified aircraft . . . since the power to operate
the relay is so small, and since you've elimnated the
need for a pilot accessible circuit breaker, I'll suggest
you eliminate both the fusible link and the 5A breaker.
Power your alternator control circuit directly from a
3A fuse on your main bus.
| Quote: | | How does breaking one line from the 'dynamo' shut it down, or does it? Per this schematic power is required from the battery to close the OV disconnect relay and bring the 'dynamo' on-line. Thus with a dead battery there is no way to bring the 'dynamo' on-line? |
Right. But given what we know about the internals
of the rectifier regulator, it doesn't matter. It's
not self-exciting. I suspect we could do a "band-aid"
not unlike that which was developed for the SD-8 and
shown in the latest z-figures . . . but the proof-of-
concept study has not been accomplished for that
product. If you have a dead battery, the prudent
action is to recharge it from some ground based source
before you start the engine to go flying.
Except for elimination of the fusible link and CB,
what you've proposed should work as advertised.
( -Thomas Paine 1776- )
rv8iator
Posted: Mon Mar 16, 2009 5:05 am Post subject: Rotax w/ Perihelion OVM |
Thanks Bob... et al.
This list is a wonderful resource. Saves me unknown hours researching!
Chris
