SkySteve
Joined: 16 Dec 2007 Posts: 94 Location: Huntsville, UT
Posted: Fri Mar 13, 2009 8:10 am Post subject: Re: Fuel Flow Display |
Dick,
My meter goes through the same routine as yours when I turn on the mater switch IF it is NOT connected to the transducer. If it is connected to the transducer, the meter does not turn on. It acts like there is a direct short either in the 5 pin connector or in the transducer.
I have called Northstar, and listened to their music for 45 minutes, with no human response from them. I have also sent an email, but no response from that either.
_________________ Steve Wilson
Huntsville, UT
Kitfox Model 1- 85DD
912A / 3 Blade Warp Drive
Convertible Nosewheel & Tailwheel |
akflyer
Posted: Fri Mar 13, 2009 5:55 pm Post subject: Re: Fuel Flow Display |
did you guys try to power up the unit without it being hooked to the ducer first? or was it hooked to ducer, and would not power up on the initial try? Alot of instruments don't like to have power to them without the ducer being installed. If that was the case, and you were impatient and wanted to see what it would do before the ducer was hooked up, you may have toasted a good instrument.
Don't know for sure if you did or not, just tossing it out there.
snake
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Fri Mar 13, 2009 6:40 pm Post subject: Fuel Flow Display |
Kinda like starting the ol' engine up without a prop, eh Snake, just
to see what she sounds like? A little impatience at the wrong time
might not be a good thing.
Speaking of fuel flow, I was flying today, and even into a 10 mph
wind at about 90 mph, I was able to twist the throttle back to see
2.9 gph on my Northstar Fuel Flow meter. It's surprising how just a
little less throttle will gain so much in fuel economy.
Lynn Matteson
Jabiru 2200, #2062, 610 hrs
Sensenich 62x46
Status: flying
On Mar 13, 2009, at 9:55 PM, akflyer wrote:
snake
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 34520#234520
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
SkySteve
Posted: Fri Mar 13, 2009 7:00 pm Post subject: Re: Fuel Flow Display |
The transducer was connected prior to any test or power up.
I have sent several emails to Northstar requesting help. I have also listened to the music on their phone line for over an hour, listening to someone continuously telling me how important my phone call is, and how the next available representative will be on the line soon. No one ever answered their phone. No one ever responded to any email.
Today, in total frustration, I cut the 5 pin connector off the line and hard wired the transducer to the meter. Still the same result. When the transducer is connected to the meter all power is lost. When the transducer is disconnected from the meter the meter works great. I am convinced there is a dead short in the transducer.
I have removed the transducer from the fuel line and am planning on returning the entire unit and will ask for a replacement.
Huntsville, UT
Paul A. Franz, P.E.
Posted: Fri Mar 13, 2009 7:33 pm Post subject: Fuel Flow Display |
On Fri, March 13, 2009 7:00 pm, SkySteve wrote:
| Quote: | ... Still the same result. When the transducer is connected to
Did you try it with the engine running? Might need to initialize with fuel flow first.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
"If Congress can do whatever in their discretion can be done by
money, and will promote the General Welfare, the Government is no
longer a limited one, possessing enumerated powers, but an
indefinite one, subject to particular exceptions."
--James Madison, letter to Edmund Pendleton, 21 January 1792
There is no distinctly native American criminal class...save Congress
-- Mark Twain
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
SkySteve
Posted: Fri Mar 13, 2009 7:41 pm Post subject: Re: Fuel Flow Display |
I have not run the engine with the fuel flow meter installed. Others here have stated that their's power up just fine with only the master switch on.
Huntsville, UT
matronics(at)bob.brennan. Guest
Posted: Sat Mar 14, 2009 5:59 am Post subject: Fuel Flow Display |
On my Jeep Cherokee's "instantaneous fuel mileage" display I can lift my
foot off the pedal and maintain speed and the display goes up to 200 miles
per gallon! Of course that's going downhill... and going up the same hill it
shows 8 mpg...
Sorry Lynn, couldn't resist<g>, sometimes being curious brings out the
smart-ass in me.
But seriously, I have yet to install my rather expensive fuel flow meter in
my 582 KF2 so am watching this thread with interest. So - 10 mph into a 90
mph wind - IAS or GPS? IAS you are going a true 90, GPS probably 80. To me
IAS is the only thing that is important for fuel flow, a 10 mph headwind
only affects how much fuel and time it will take to get where you're goin'.
But more importantly "twist[ing] the throttle back" did what? Lowered the
airspeed? You found a convenient "hill" to maintain airspeed? What was the
gph before?
On my KF2 I hope to find a cruise "sweet spot" with the fuel flow meter. At
or below 65 it tends to mush and needs more throttle, once I get it on
"plane" it speeds up, speeding up further I suspect will suck more fuel. At
some IAS, unique to each plane no doubt, there's a best economy cruise.
Welcome to Saturday morning pedantry, but I know you enjoy the challenge!(?)
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade prop
Wrightsville Pa
Float Flyr
Posted: Sat Mar 14, 2009 9:03 am Post subject: Fuel Flow Display |
Lots of filling measuring draining and heavens knows what, but won't tell
going on there. Fill, use and refill from known capacity containers that
way you will know exactly what you are replacing... that quantity is the
quantity used.
Just make sure if you refuel from 2.5 gal containers put as close to 2.5 gal
in each one as you can get.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Sat Mar 14, 2009 11:13 am Post subject: Fuel Flow Display |
Saturday morning pedantrics are fine, but I was flying this am. : )
I never thought of flying down-hill to get a better reading....if I
had, I'm sure the "hurry up and dump some fuel overboard...you're
making fuel" light would have come on. : )
I don't think my airspeed is exactly accurate, but I was showing
about 90 on it and on the GPS groundspeed...and at about 2000 ft AGL,
how do I know what the exact wind was? I didn't, but the ground wind
was 10 mph, 30 miles further back when I departed. At the point where
I saw 90 by 90, I was showing about 3.1 to 3.2 gph usage. I twisted
(vernier throttle) the throttle back and saw 2.9 gph usage, and speed
dropped to about 85 by 85. I was trying to slow enough to just stay
ahead of my friend's 150 Cessna, and by slowing this small amount,
the speed dropped, but the gph use really dropped. The tach was
showing about 2700 at 90 mph, and about 2540 when throttled back..(.I
think I have too much prop, as the Jab's cruise speed should be
2750-2950 rpm). I was straight and level at the time. I've read some
accounts of people getting 2-point something with their Kitfox's, and
seriously doubted them, but it just shows what throttling back can
do. I'm happy if I get about 3.8-4.1gph, but if I'm in a hurry to
get somewhere, I'll open it up more but seeing 4.8-5.0 makes me
realize how much of a rush I SHOULDN'T be in. Incidentally, on
takeoff, I'll see 5.8-6.0 gph use, and that's enough to point the
nose down a bit and twist the throttle back some. : )
The main reason I got the fuel flow gauge was to determine where the
Bing's needle needs to be for best economy, just like you mentioned,
Bob. I've been using the EGT's for this purpose, but I think the flow
meter will be more instantaneous.
By the way, when we got to where we were going, the fuel price was
$3.26/ gallon for 100 LL, and they had just lowered it from $3.79/
gallon.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 14, 2009, at 9:57 AM, Bob Brennan wrote:
<matronics(at)bob.brennan.name>
lift my
200 miles
same hill it
shows 8 mpg...
smart-ass in me.
meter in
into a 90
80. To me
headwind
you're goin'.
Lowered the
was the
gph before?
meter. At
fuel. At
cruise.
challenge!(?)
Wrightsville Pa
N369LM |
Posted: Sat Mar 14, 2009 2:41 pm Post subject: Fuel Flow Display |
According to the Model II POH, with the 65hp 582, fuel consumption at 65mph
is 2.1gph and at 85mph it is 3.7gph; nearly twice as much for an extra
20mph! I have found that I need to maintain around 70mph IAS, at 65 it tends
to "fall off the plane" and lose airspeed quickly. I'm not sure if it's just
my plane or a characteristic of the II but it can be a problem. Seeing the
rating go from 2.1gph to 3.7 within my usable cruise range it makes me want
to see a curve there so I can get the efficiency.
So I should go out now and install that bloody expensive equipment and get
flying again! We have a disadvantage here in South Central Pa where the
grass strips are either frozen with nasty bumps or melted with mud patches
that'll suck your boots off. And no snow for skis, maybe I should move...
Wrightsville Pa
akflyer
Posted: Sat Mar 14, 2009 2:57 pm Post subject: Re: Fuel Flow Display |
| matronics(at)bob.brennan. wrote: | According to the Model II POH, with the 65hp 582, fuel consumption at 65mph
Wrightsville Pa
Flying my brothers model II and a buddies model I and my Avid C I have not seen anything CLOSE to those numbers. at 85 it is closer to 5.5- 5.8 GPH. To get into the low 4s or high 3s I have to pull it back to about 55-60 mph. I checked this over about 300 hrs on the model II and 30 hrs on the Avid.
The attached pic shows the fuel flow at ~80 IAS and a fuel flow of 5.1
273.84 KB |
14442 Time(s) |
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Posted: Sat Mar 14, 2009 3:52 pm Post subject: Fuel Flow Display |
Interesting - are those numbers from a stock 582, C box, GCS prop? Empty
weight close to the published numbers in the POH at
http://cfisher.com/kitfox/kitfox2poh.pdf of 440 lbs? Slim and fit pilot?
Like I said I have yet to install the fuel flow gauge but while I was
training, with 2 aboard of course, I could easily get 4 hours on a full 15
gallons of fuel, with reserve, which is less than 4 gph. I haven't done
accurate measurements as solo pilot but I usually figure around 2.5 to 3.5
gph depending on what I'm doing.
One of the things that I think makes my KF2 slippery is that I have a
horizontal trim tab and *never* use flaps for trim. Do you trim with flaps
(read "induced drag")?
Wrightsville Pa
akflyer
Posted: Sat Mar 14, 2009 4:51 pm Post subject: Re: Fuel Flow Display |
| matronics(at)bob.brennan. wrote: | Interesting - are those numbers from a stock 582, C box, GCS prop? Empty
Wrightsville Pa
negative ghost rider... little thingy below and to the right of the fuel flow is the electric elevator trim indicator lol.
I think part of my issue is that I am towards the forward CG. I am moving it back to 18" and gonna try that. Dean Wilson said it will make a huge difference in the flight performance, for the better... now I wonder what would happen if I clipped the wings to 26' and moved the CG to the aft edge of the wing......... sorry, had to put that in there.. I have been good lately and that just aint right for a snake oil salesman
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Posted: Sat Mar 14, 2009 5:20 pm Post subject: Fuel Flow Display |
I think that our little hand-tweaked aircraft are *very* sensitive to minor
"adjustments". Especially with that high power to weight ratio. That's why
(among other reasons) this forum is so helpful to me, and even in flight I
am forever searching for that magical "sweet spot". Not to diss(respect)
Cessnas, but the 172's I fly do what they do, and they all do it pretty much
the same. Kitfoxes, they're like ladies.... with all due respect to
Kitfoxes!
Wrightsville Pa
propellerdesign(at)tele2. Guest
Posted: Sun Mar 15, 2009 12:48 am Post subject: Fuel Flow Display |
In general, all airplane, speed for minimum fuel flow isn't the same as the
speed for best range, and non of those speeds is speed stable, you need as
you say be 5 mph or so higher.
There is a speed called Carson (not Carlson) speed, that is best
distance/fuel/time speed, about 1,3 times higher then the best range speed.
on a drag curve this is the speed where a line drawn from origo touch the
curve.
Jan Carlsson
www.jcpropellerdesign.com
Lynn Matteson
Posted: Sun Mar 15, 2009 2:26 am Post subject: Fuel Flow Display |
Up here, it's just that time of year when the bumps are frozen in the
morning, but soft in the afternoon. My field slopes about 20 ft
downhill (according to my altimeter, but at least 10 ft by
"eyeballing" it), and at the low end the field is really soggy...the
pond is swollen to cover half the width of the runway there. So I
only use half the field (half of 1700 ft) for takeoffs and still get
up in half of that...easily. Landing is no problem, as I just glide
over the soft part and time it to land after the halfway mark,
sometimes needing a go-around, but more likely to need a firm
application of brakes as the pucker factor rises when the far end
presents itself rather largely.
So you're saying you've got the "bloody expensive equipment", but
haven't put it in yet? Better get crackin', Bob, life is short, and
Sun 'n' Fun is comin' up. Even the Festival of Flight is well within
your range, I would think.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 14, 2009, at 6:39 PM, Bob Brennan wrote:
at 65mph
it tends
it's just
Seeing the
me want
and get
the
patches
move...
N369LM |
Lynn Matteson
Posted: Sun Mar 15, 2009 8:51 am Post subject: Fuel Flow Display |
I took another flight today in dead calm wind conditions, and showed
2730 rpm, 3.6 gph fuel usage, 3000' altitude, 98 IAS with 103 GPS
groundspeed. I lowered the rpm to 2680 rpm, 3.4 gph usage (at) 2720',
and 96 x 100 (air x ground). On the return flight, after 1 hour
breakfast (slow service), the numbers were: 2740 rpm, 3.7 usage, and
2500', with speeds at 100 x 107. After the trip, my GPS showed
60.2 miles going, and 60.5 miles returning, both taking .6 hours, for
almost exactly a 100 mph average.
Lynn Matteson
Sensenich 62x46
Status: flying
AGL, how do I know what the exact wind was? I didn't, but the
ground wind was 10 mph, 30 miles further back when I departed. At
the point where I saw 90 by 90, I was showing about 3.1 to 3.2 gph
usage. I twisted (vernier throttle) the throttle back and saw 2.9
gph usage, and speed dropped to about 85 by 85. I was trying to
slow enough to just stay ahead of my friend's 150 Cessna, and by
slowing this small amount, the speed dropped, but the gph use
really dropped. The tach was showing about 2700 at 90 mph, and
about 2540 when throttled back..(.I think I have too much prop, as
the Jab's cruise speed should be 2750-2950 rpm). I was straight and
level at the time. I've read some accounts of people getting 2-
point something with their Kitfox's, and seriously doubted them,
but it just shows what throttling back can do. I'm happy if I get
about 3.8-4.1gph, but if I'm in a hurry to get somewhere, I'll
open it up more but seeing 4.8-5.0 makes me realize how much of a
rush I SHOULDN'T be in. Incidentally, on takeoff, I'll see 5.8-6.0
gph use, and that's enough to point the nose down a bit and twist
the Bing's needle needs to be for best economy, just like you
mentioned, Bob. I've been using the EGT's for this purpose, but I
think the flow meter will be more instantaneous.
gallon.
Lynn Matteson
Sensenich 62x46
Status: flying
> lift my
> 200 miles
> same hill it
> shows 8 mpg...
> the
> smart-ass in me.
> meter in
> into a 90
> 80. To me
> headwind
> you're goin'.
> Lowered the
> was the
> gph before?
> meter. At
> it on
> fuel. At
> cruise.
> challenge!(?)
> Wrightsville Pa
N369LM |
akflyer
Posted: Wed Apr 08, 2009 10:54 am Post subject: Re: Fuel Flow Display |
for anyone intersted in these units, here is a site that has them for $116.95 alot less than I paid for mine a couple years ago.
http://www.roguewavemarine.com/store/northstar-fuel-210-f210-pr-12173.html
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
dave
Posted: Wed Apr 08, 2009 12:01 pm Post subject: Re: Fuel Flow Display |
Fuel flow 117 $ here I got mine about 3 years ago from them and got it overnight to Canada .
http://www.boatersland.com/f210.html
Good place to do business with
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
SkySteve
Posted: Wed Apr 08, 2009 1:00 pm Post subject: Re: Fuel Flow Display |
It turned out that mine DID have a direct short in the transducer. I sent it back to Navico (the mfg or importer) in Tulsa, OK and they say they are going to replace it. However, they are out of stock until sometime between April 15-30. Waiting . . . . .
Huntsville, UT
