william(at)gbta.net Guest
Posted: Sat Mar 14, 2009 3:29 pm Post subject: W-1013A aileron hinge brackets warped |
I started work on the rear wing spars today and noticed that the w-1013a aileron hinge brackets are warped. With them lying flat on the table there's 1/16-3/32" gap in the center off the table on all 4 of them. Has anybody else run into this problem. Looks like it might have happened when they were "stamped" out. Obviously I'll wait 'til monday and see what Vans has to say but does anybody else have any thoughts on this. Surely it's not wise to use them like this, or is it???
Anyhow, pictures are attached.
Thanks in advance,
Bill Britton
RV-10 #40137
750.92 KB |
4378 Time(s) |
![100_3679[1].jpg](files/100_3679_1__131.jpg)
545.42 KB |
4378 Time(s) |
![100_3680[1].jpg](files/100_3680_1__735.jpg)
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sat Mar 14, 2009 4:09 pm Post subject: W-1013A aileron hinge brackets warped |
I would say, treat it as the horizontal tabs that stick up from the tailcone, beat on them in a vice with a rubber mallet to straighten them.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
rnewman(at)tcwtech.com Guest
Posted: Sat Mar 14, 2009 4:42 pm Post subject: W-1013A aileron hinge brackets warped |
I vaguely remember the same issue (I'm kit #40176), I reasonably sure I "flatened" them back out with a little vise and clamp action.
-Bob Newman
Ron B.
Posted: Sat Mar 14, 2009 4:50 pm Post subject: Re: W-1013A aileron hinge brackets warped |
Mine were like your's, I straightened them.
Ron
Tim Olson
Posted: Sat Mar 14, 2009 6:36 pm Post subject: W-1013A aileron hinge brackets warped |
Yep, perfectly normal. Just flatten them back out. They'll straighten
when you rivet them to the other piece anyway.
Bill and Tami Britton wrote:
| Quote: | I started work on the rear wing spars today and noticed that the w-1013a
Thanks in advance,
Bill Britton
RV-10 #40137
