Posted: Tue Mar 10, 2009 4:51 am Post subject: Rate of climb |
Kolb guys C
I'm curious what you folks experience for rates of climb in your MkIII (MkII C Classics C Xtras)
I've heard of the great climb performance of the Kolb airplanes C but I don't recall seeing very many "real life" established numbers.
One of the reasons for my request is to satisfy my curiosity of the climb performance with various powered engines. Example...Rotax 582.....x# fpm C GEO (HP?)......x# fpm C Rotax 912 UL....x# fpm C Rotax 912 ULS.....x# fpm C VW (HP?) ...x# fpm
Thanks. Your indulgence is appreciated.
BTW. For those that are interested C I completely finished painting my entire MkIII the other day (not including blue and yellow stripes). Engine and propeller are remounted. I fabricated a new dynafocal style radiator mount on Sunday. (pictures available for those who ask)
I want to point out the rate of climb stats I'm asking for aren't to establish bragging rights for the highest. I realize there are a million reasons why there will be some variances. like density altitude C weight of plane and cargo C prop differences C etc.)
Thanks C Mike Welch
MkIII
Windows Live™ Contacts: Organize your contact list. Check it out. [quote][b]
aslsa.rng(at)gmail.com Guest
Posted: Tue Mar 10, 2009 6:08 am Post subject: Rate of climb |
Mike, at 608 lb. dry, my Mk III is a pig. I did climb tests in 2006 right after dawn when the temps were in the 80's. Didn't make any difference whether I climbed at 55 or 70 mph IAS, it came in at 500 fpm every time. Testing method:
Establish climb at 800' agl, start stop watch at 1000' asl and time the climb to 2000'. Repeat twice for each IAS.
Rick
On Tue, Mar 10, 2009 at 7:48 AM, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
| Quote: | Kolb guys,
I'm curious what you folks experience for rates of climb in your MkIII (MkII, Classics, Xtras)
I've heard of the great climb performance of the Kolb airplanes, but I don't recall seeing very many "real life" established numbers.
One of the reasons for my request is to satisfy my curiosity of the climb performance with various powered engines. Example...Rotax 582.....x# fpm, GEO (HP?)......x# fpm, Rotax 912 UL....x# fpm, Rotax 912 ULS.....x# fpm, VW (HP?) ...x# fpm
BTW. For those that are interested, I completely finished painting my entire MkIII the other day (not including blue and yellow stripes). Engine and propeller are remounted. I fabricated a new dynafocal style radiator mount on Sunday. (pictures available for those who ask)
I want to point out the rate of climb stats I'm asking for aren't to establish bragging rights for the highest. I realize there are a million reasons why there will be some variances. like density altitude, weight of plane and cargo, prop differences, etc.)
Thanks, Mike Welch
MkIII
Windows Live™ Contacts: Organize your contact list. [url=http://windowslive.com/connect/post/marcusatmicrosoft.spaces.live.com-Blog-cns!503D1D86EBB2B53C!2285.entry?ocid=TXT_TAGLM_WL_UGC_Contacts_032009]Check it out.[/url] ==== get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution [/b] |
Posted: Tue Mar 10, 2009 6:09 am Post subject: Rate of climb |
PS, it's 582 powered.
Rick
| Quote: | Kolb guys,
Thanks, Mike Welch
MkIII
robcannon
Joined: 22 Jun 2008 Posts: 39 Location: British Columbia
Posted: Tue Mar 10, 2009 6:39 am Post subject: Re: Rate of climb |
My Twinstar mark II with the HKS gets around 900 fpm at 50 to 60 mph. This is at about 700 lbs.
by0ung(at)brigham.net Guest
Posted: Tue Mar 10, 2009 7:11 am Post subject: rate of climb |
Mike Welch
On my mkIII C I have the 912 and 68 inch Warp Drive propl…. And since I have never been to sea level… I went the opposite way and tested at altitude.
Between 9500 ft and 10000 ft. solo takes 1 min or 500 ft/min
Between 9500 ft and 10000 ft. with 2 on board, very near max wt. it takes 2 min. or 250 ft/min
There may be some way to calculate what it would do at sea level… but I don’t know the formula.
Boyd Young
Kolb MKIIIC
Brigham City Ut.
JetPilot
Posted: Tue Mar 10, 2009 8:19 am Post subject: Re: Rate of climb |
At sea level on a hot humid day, my MK III Xtra with the Rotax 912-s climbs at 1000 feet a minute with 2 people, around 1400 FPM when I am alone, and 10 gallons of fuel.
Kolb MK-III Xtra, 912-S |
rlaird
Posted: Tue Mar 10, 2009 10:17 am Post subject: Rate of climb |
At 588 lbs empty, w/ Rotax 912ULS, 3-blade Warp drive prop and just me and 12 gallons, I routinely get 900-1100 fpm, but if I'm trying hard and right on the edge, I can do 1400fpm.
-- Robert
[quote] Kolb guys,
Thanks, Mike Welch
MkIII
Windows Live™ Contacts: Organize your contact list. Check it out. | Quote: |
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
apilot(at)surewest.net Guest
Posted: Tue Mar 10, 2009 10:40 am Post subject: Rate of climb |
Mark III, Classic with a Geo engine with windage tray and Raven furnished cam gets 400 ft/min at density altitude of around 6000' msl. The gross weight is 840 lbs. At a gross weight of 1030 lbs., the rate of climb is 100 ft/min or less. In summary, it is scary. Do not know what it will do at sea level, but the thrust is significantly more. Static thrust at 6000 msl is 307 lbs. and at sea level it is off of my scale which ends at about 320 lbs. The Geo is a super engine and the Raven belt re-drive is very smooth and reliable. Hopefully, I will get the plane down to Sacramento for some sea level testing. I am guessing that my rate of climb will be around 800 ft/min. We shall see. Vic N4201G
Posted: Tue Mar 10, 2009 1:33 pm Post subject: Rate of climb |
I have never measured the climb rate of my VW powered MKIIIC. I would guess it would be right even with or slightly less than a 80HP. Rotax. I also rate my engine at 80HP but that is a guesstimate
Rick Neilsen
Redrive VW powered MKIIIC
Dana
Posted: Tue Mar 10, 2009 2:13 pm Post subject: Rate of climb |
At 08:48 AM 3/10/2009, Mike Welch wrote:
| Quote: | I've heard of the great climb performance of the Kolb airplanes, but I
I know you only asked about MKIII's, but for sake of comparison, my Cuyuna
powered UltraStar does 500fpm at about 40-45mph, on a warm day with 475# AUW.
-Dana
Ever notice how fast Windows runs? Neither did I.
Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Tue Mar 10, 2009 2:43 pm Post subject: Re: Rate of climb |
Mike,
Robert Laird will correct me if I'm wrong on this, but last November we were both in his 912S powered MK III, climbing out at over 1100 fpm on an 80 degree mid-day flight, & I know we have to weigh over 440 lbs combined.
(Pretty evenly split between us by the way, and there won't be any downward corrections regarding the weight!)
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
rlaird
Posted: Tue Mar 10, 2009 3:53 pm Post subject: Rate of climb |
That's correct. Field elevation is about 235 MSL.
On Tue, Mar 10, 2009 at 5:43 PM, Jimmy Young <jdy100(at)comcast.net (jdy100(at)comcast.net)> wrote:
[quote]--> Kolb-List message posted by: "Jimmy Young" <jdy100(at)comcast.net (jdy100(at)comcast.net)>
Mike,
Jimmy Young
FS II, Generac V-Twin
Houston TX area
http://forums.matronics.com/viewtopic.php?p=234129#234========================
Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Kolb-List" target="_blank">http://====
http://forums.mle, List Admin.
Robert Laird
Houston, TX area
Richard Pike
Posted: Tue Mar 10, 2009 6:53 pm Post subject: Re: Rate of climb |
MKIII Classic. Various mods, center section of wing is separate from fuselage, has VG's, other mods. Empty weight about 535. Using a 582 with a 2 blade 68" Ivo, 2.58:1 B box, solo with full fuel on a summer day typically gives a climb rate of around 800-900'/minute(at)6250 rpm. In the winter, a climb rate of 1000-1200'/min (at) 6250 rpm, all at between 2-3,000 msl.
grantr
Posted: Wed Mar 11, 2009 5:05 am Post subject: Re: Rate of climb |
Mark III Classic: Gross weight full fuel on takeoff 735 pounds powered by a Rotax 503 DCDI Climb is from 600 to 660 fpm solo. I would guess 1/3 that for 2 people.
My average full power climb rate according to the gps during takeoff was 658 feet per minute at an average ground speed of 43.5 miles per hour.
Temperature was about 69 degrees( weather channel says 73o during 3 pm however my house outside thermometer had a overall high of 69.8 for the day.) and the field elevation is around 460 MSL
My average speed on my trip during cruise was 54 mph.
Grant
Here are some more numbers from my gps from 11/9/2008.
My average full power climb rate according to the gps during takeoff was 617 feet per minute at an average ground speed of 41.7 miles per hour. Indicated climb out of 60mph. The plane stalls at 41 indicated.
Temperature was 64 degrees during 4 pm with 9 mph winds gusting to 15 at 280o.
I was using runway 23 so it was a good crosswind.
field elevation around 460msl
My gps took 56 measurements in 5250 feet.
I did a more detailed analysis of my climb rate and the average is 617 feet per minute out of 56 rate calculations :
750.00
720.00
750.00 50 agl 519 msl
720.00
740.00
745.71
742.50
733.33
744.00
763.64
750.00
715.71
701.25
673.33 202 agl 671 msl
651.00
651.43
636.52
619.20
620.00
622.76
624.00
611.25
600.00
591.43 345 agl 814 msl
590.27
592.31
588.00
583.90
581.43
583.26
577.33
577.83
575.74
573.06
563.53
560.77
563.77
569.45
572.14
567.93
568.00
564.19
563.44
565.85
568.66
566.09
559.44
555.62
554.59
554.21
553.08
547.50
544.39
539.29
533.72
530.34 at 769 agl 1238 msl
Posted: Wed Mar 11, 2009 5:34 am Post subject: Rate of climb |
Grant C
Wow! Such detail!
Thanks to you and the other guys that took the time to share your plane's performance. This is valuable information. I'm getting a pretty good idea of the vertical speed capabilities of the different engines on a MkIII (and some other Kolb models).
MkIIICX
Painted C Turbo GEO C mounted and getting final touches (like radiator..done C intercooler...underway C etc)
[quote] Mark III Classic: Gross weight full fuel on takeoff 735 pounds powered by a Rotax 503 DCDI Climb is from 600 to 660 fpm solo. I would guess 1/3 that for 2 people.
Grant
Hotmail® is up to 70% faster. Now good news travels really fast. Find out more.
Dennis.Kirby(at)kirtland. Guest
Posted: Wed Mar 11, 2009 12:47 pm Post subject: Rate of climb |
Classification: UNCLASSIFIED
Mike: Here are my "real life" numbers.
Mark-III “Classic”
Empty wt - 560 lbs
Field elevation (this is important, for comparing) – 6500’ msl
Engine - 912ul (80 hp)
Climb rate (solo) – 700 fpm
RPM – 5200 (wide open throttle)
Indicated Airspeed – 55 mph
I like to think my Kolb would yield higher climb rates at lower elevations, but the lowest-elevation airfield I’ve ever been to was 4830’ msl. Man, I bet my Kolb would do GREAT in Florida!
Dennis Kirby
New Mexico
Posted: Wed Mar 11, 2009 1:10 pm Post subject: Rate of climb |
| Quote: | I like to think my Kolb would yield higher climb rates at lower
elevations, but the lowest-elevation airfield I've ever been to was
4830' msl. Man, I bet my Kolb would do GREAT in Florida!
Dennis Kirby
You would think you had a sky rocket, Dennis!!!
Engine produces a lot more power, and the air lifts a lot more.
_________________ John Hauck
Titus, Alabama |
