F 1013 Longerons
rwhunter(at)integra.net
PostPosted: Mon Mar 09, 2009 4:43 am    Post subject: F 1013 Longerons Reply with quote
Hi!
I am on page 29-13 step 6. All the drawings sure look like the F 1013 longerons sit on top of the F 1001J gusset at the fire wall, but when you do this you lose the centerline of the longeron with the skin. Does the longeron actually go under the top of the gusset?
Enjoying this section believe it or not until now. After sleeping on this, I think that I may have drilled the longeron wrong because of a misinterpretation of the drawing.
Rob Hunter
40432
Fuselage
DLIUDVINAITIS(at)aol.com
PostPosted: Mon Mar 09, 2009 6:24 am    Post subject: F 1013 Longerons Reply with quote
Rob
Longeron as per plans set on top of gusset than matched drilled with 30 drill. longeron my have to be bent in line a little more to aline with skin holes.go back to page 29-3 and review. my skins line up perfict. good luck.
Dave
#40466 central NJ, Blm
In a message dated 3/9/2009 7:44:57 A.M. Central Daylight Time, rwhunter(at)integra.net writes:
Hi!
Rob Hunter
40432
Fuselage
="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
planesmith(at)hotmail.com
PostPosted: Mon Mar 09, 2009 6:44 am    Post subject: F 1013 Longerons Reply with quote
Hi Rob C
Here are some pictures of what I did. Also look ahead to page 14 for a close-pu.
Vern Smith (#324 finishing)
Subject: RV10-List: F 1013 Longerons
Date: Mon C 9 Mar 2009 07:36:49 -0500
(at)page Section1 {size:8.5in 11.0in;} .ExternalClass P.EC_MsoNormal {font-size:12pt;font-family:'Times New Roman' C'serif';} .ExternalClass LI.EC_MsoNormal {font-size:12pt;font-family:'Times New Roman' C'serif';} .ExternalClass DIV.EC_MsoNormal {font-size:12pt;font-family:'Times New Roman' C'serif';} .ExternalClass A:link {color:blue;text-decoration:underline;} .ExternalClass SPAN.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass A:visited {color:purple;text-decoration:underline;} .ExternalClass SPAN.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass P {font-size:12pt;margin-left:0in;margin-right:0in;font-family:'Times New Roman' C'serif';} .ExternalClass PRE {font-size:10pt;font-family:'Courier New';} .ExternalClass SPAN.EC_HTMLPreformattedChar {font-family:Consolas;} .ExternalClass SPAN.EC_EmailStyle20 {font-weight:normal;color:#1f497d;font-style:normal;font-family:'Arial' C'sans-serif';} .ExternalClass SPAN.EC_EmailStyle21 {color:#1f497d;font-family:'Calibri' C'sans-serif';} .ExternalClass .EC_MsoChpDefault {font-size:10pt;} .ExternalClass DIV.EC_Section1 {page:Section1;} Hi!
I am on page 29-13 step 6.  All the drawings sure look like the F 1013 longerons sit on top of the F 1001J gusset at the fire wall C but when you do this you lose the centerline of the longeron with the skin.  Does the longeron actually go under the top of the gusset?
Enjoying this section believe it or not until now.  After sleeping on this C I think that I may have drilled the longeron wrong because of a misinterpretation of the drawing.
Rob Hunter
40432
Fusela===
Windows Live™: Keep your life in sync. See how it works.Windows Live™: Keep your life in sync. Check it out.
 Filesize:  51.17 KB
 Viewed:  2995 Time(s)
 Filesize:  38.29 KB
 Filesize:  71.13 KB
 Filesize:  78.51 KB
Bldgrv10450(at)comcast.ne
PostPosted: Mon Mar 09, 2009 10:14 am    Post subject: F 1013 Longerons Reply with quote
Rob
The longerons do sit on top of the gusset. I enjoyed this section a great deal myself, even though I made my first two perfect longerons exactly 1" short. Wait until you get to the point of attaching the skin to the longerons over this gusset, it's a real challange.
Paul Grmstad,
RV10 450
Portland, Or.
