gear weight
Goto page Previous  1, 2
Fox5flyer
PostPosted: Sun Mar 08, 2009 9:47 am    Post subject: gear weight Reply with quote
Same here, but the humor didn't come through. Tone is difficult in emails.
Please... do not archive
Deke
Storm coming in NE MI
Lynn Matteson
PostPosted: Sun Mar 08, 2009 10:52 am    Post subject: gear weight Reply with quote
Off topic:
I wonder how much longer phrases like "carbon copy" will be around?
Also, "clockwise" and "counter-clockwise" (whaddya mean,
clockwise?...mine just blinks "12:00" : )
Lynn Matteson
Jabiru 2200, #2062, 610 hrs
Sensenich 62x46
Status: flying
On Mar 8, 2009, at 12:13 PM, fox5flyer wrote:
[quote] My mistake for poor use of cliché terms. Maybe, "close copy" would
have worked better?
Deke
Lynn
Kitfox IV-Jabiru 2200
N369LM
Paul A. Franz, P.E.
PostPosted: Sun Mar 08, 2009 10:57 am    Post subject: gear weight Reply with quote
Deke
Deke,
Who do you think is listening to "do not archive"? Maybe some archive I don't know about?
It certainly doesn't block the posting or archiving on Matronics:
<http://forums.matronics.com/viewtopic.php?t=55884&postdays=0&postorder=asc&start >
Is this a carry over from when Don was running the list? I don't believe appending "do
not archive" to a list posting does anything at all that I know of.
Paul Franz
425.440.9505 (O)
425.241.1618 (C)
Paul A. Franz, P.E.
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
matronics(at)bob.brennan.
PostPosted: Sun Mar 08, 2009 12:47 pm    Post subject: gear weight Reply with quote
From the Matronics Kitfox List FAQ:
*** The "DO NOT ARCHIVE" Message Flag ***
At times, your message may concern something that is revelent only
to a very
small number of persons or to a limited area, and you may not wish
to archive
it. In such a case, simply put the following phrase anywhere in
the
message:
Your message will not be appended to the archive, but will be sent
to List
email distribution as normal.
I tried searching for "do not archive" in the archive but the search engine
does not seem capable of matching 3 words in sequence. I personally always
assumed that an email marked with "do not archive" is distributed via email
and listed in the most recent posts, but then automatically discarded at
some point as the message is added to the archives.
Being anal<g>, and an engineer (no points to the first that say that's
redundant), I am including the word donotarchivethis which does not as yet
exist anywhere in the list, just for sh*ts and grins...
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade prop
Wrightsville Pa
Fox5flyer
PostPosted: Sun Mar 08, 2009 1:04 pm    Post subject: gear weight Reply with quote
Paul, click the link below and look about 1/3 the way down the page to the
http://www.matronics.com/FAQ/Kitfox-List.htm
jcrowder(at)lpbroadband.n
PostPosted: Sun Mar 08, 2009 3:42 pm    Post subject: gear weight Reply with quote
I just returned to Colorado and am catching up on my email. I have the
original aluminum gear from Skystar on my Model 5. It is taller than the
Grove gear now sold. I am told it was somewhat heavier and designed to meet
drop test which is a part of the requirement for certificated aircraft. I
was also told at that time they were working toward possible certification
of a version of the Model 5. This was from the grapevine and discussed on
the List at that time. If the archives go back that far, there will be
threads of this. In any case this was the first issue of aluminum spring
gear and shipped with the early Model 5's.
Jim Crowder
[quote] --
lcfitt(at)sbcglobal.net
PostPosted: Sun Mar 08, 2009 3:54 pm    Post subject: gear weight Reply with quote
Deke,
I believe your gear is Grove. I recall a friend that had the taller thinner
gear and it was grove, I think it was an early version. I found a picture
of his airplane, (attached) and it was powered, incidentally, by a Franklin
engine. He lives in Marin County, norht of San Francisco.
Lowell
 Filesize:  67.26 KB
 Viewed:  4605 Time(s)
PostPosted: Sun Mar 08, 2009 4:22 pm    Post subject: gear weight Reply with quote
This is interesting to me - the alloy change. I wonder if it is a good
thing. I bought the Hammerhead gear and installed it on my Model IV. My
understanding is that Hammerhead used 7075 T6 and Grove used a different
alloy - I can only guess, so won't. This was from a conversation with
Hammerhead in 2001 or 2 based on fotos of my airplane and the gear change.
I see that Grove now uses the 7075-T6, based on their current web site.
The occasional reports of Grove gear bending on hard landings, was a bit of
comfort to me then and more so after suffering a very hard landing. The
Hammerhead gear surviving virtually intact ready to fly again. It was one
of the first things sold by the salvage folks and looked brand new.
I would like to think that the landing gear would be designed to absorb some
of the energy of impact and at least deform a little bit. My airplane
essentially broke at the landing gear with everything panel forward falling
forward, separated from every thing aft except through the lower longerons
and door frame. Three compression fractures proved to me that my back took
a lot of the brunt of the crash.
7075-T6 is tough stuff and does not bend well. I tried to use it on the
Tiedown straps we made for the Rans series airplanes, and I finally had to
get the T0 version and heat treat it after forming. I can see that
repeatedly rebending landing gear at no charge might ultimately cut into the
bottom line, but ....
Just some opinions based on some limited experience.
Lowell
PostPosted: Sun Mar 08, 2009 4:29 pm    Post subject: gear weight Reply with quote
Hammerhead and Grove began much like Kitfox and Avid, except the original
company, Grove survived. I was told by the Hammerhead folks that it was
their founder and former partner of Grove, that developed the gun drilling
equipment for the internal brake lines. As some of you might recall, early
Grove gear had a channel milled into the aft edge of the gear leg, to
accommodate an external brake line that could be glued or strapped into it.
Hammerhaed offered the gun drilling from the get go at no additional charge,
Grove charged extra - my reason for going with Hammerhead.
The rest is history.
Lowell
Fox5flyer
PostPosted: Sun Mar 08, 2009 4:41 pm    Post subject: gear weight Reply with quote
That's it. Thanks, Lowell. At least now I know what I have. As a side
note, I painted mine to match the airplane. It's been good gear, but heavy.
Deke
Fox5flyer
PostPosted: Sun Mar 08, 2009 4:47 pm    Post subject: gear weight Reply with quote
Thanks Jim. Good info and nice to know that my gear should last a long
time.
Deke
pwmac(at)sisna.com
PostPosted: Mon Mar 09, 2009 8:44 am    Post subject: gear weight Reply with quote
Lots of discussion when the 2 alloys were used. pros & cons fro each
- most prominent in my mind :
(1) the 2xxx alloy used for the early Grove will bend sooner than the
7075 just due to strength assuming the dimensional data is the same.
Thus there will more energy absorbed by the 20xx alloy compared to
the stronger alloy. However the different gear lengths change any
ability to compare the various gears.
(2) The 7075-76 is subject to fracture toughness weakness. That means
a small rock chip could lead to complete failure. This can be
mitigated by using a coating for the gear - paint or fabric, etc. for
the leading edge.
Both alloy choices are made in the annealed condition then heat treated.
It is my understanding that Hammerhead used to be the engineer at
Grove when the KF was designed.
Anyway being an engineer I chose the 7075-T6 alloy. I am please that
Grove went to that alloy.
Paul
good thing. I bought the Hammerhead gear and installed it on my
Model IV. My understanding is that Hammerhead used 7075 T6 and
Grove used a different alloy - I can only guess, so won't. This was
from a conversation with Hammerhead in 2001 or 2 based on fotos of
my airplane and the gear change. I see that Grove now uses the
bit of comfort to me then and more so after suffering a very hard
landing. The Hammerhead gear surviving virtually intact ready to
fly again. It was one of the first things sold by the salvage folks
absorb some of the energy of impact and at least deform a little
bit. My airplane essentially broke at the landing gear with
everything panel forward falling forward, separated from every thing
aft except through the lower longerons and door frame. Three
compression fractures proved to me that my back took a lot of the
brunt of the crash.
the Tiedown straps we made for the Rans series airplanes, and I
finally had to get the T0 version and heat treat it after
forming. I can see that repeatedly rebending landing gear at no
charge might ultimately cut into the bottom line, but ....
Lowell
[quote]---
Page 2 of 2
