Fuel Flow Display
Goto page 1, 2, 3  Next
SkySteve
PostPosted: Thu Mar 05, 2009 8:46 pm    Post subject: Fuel Flow Display Reply with quote
Regarding the Northstar F210 Fuel Flow Display, I have two questions:
1. Can the sending unit be installed upside down? If installed in the fuel line between the gasolator and the fuel pump on a Rotax 912 it needs to be installed upside down to obtain the correct fuel flow direction through the sending unit and to obtain a vertical position.
2. Can the very long wire between the sending unit and the panel display be cut and spliced to shorten the length? Or does that wire have some sort of shielding that should not be cut?
Steve Wilson
Huntsville, UT
Kitfox Model 1- 85DD
912A / 3 Blade Warp Drive
Convertible Nosewheel & Tailwheel
Dick Maddux
PostPosted: Fri Mar 06, 2009 5:17 am    Post subject: Fuel Flow Display Reply with quote
Steve,
My Northstar sending unit is installed vertical a few inches above the gascolator prior to the fuel pump and yes the wire can be shortened as specified by the instructions. I shortened mine to a total length of about 3 1/2 ft spliced it and it works perfect.
I have included a picture but not a good one. It barely shows the installation. If you look at the lower left of the firewall you will see where the fuel line (aluminum goes down to the gascolator and then goes up to the fuel pump [in red fire sleeve). About two inches above the gascolator is the fuel sending unit for the Northstar (also wrapped in fire sleeve) there is a white circle in the line, at that location. I then cut the wire and sent it to the instrument panel for the gauge. Sorry I don't have a better picture but the picture was made to show my bush gear installation.
          Dick Maddux
          Rotax 912UL
          Fox 4
          Pensacola,Fl
Need a job? Find employment help in your area.
 Filesize:  370.1 KB
 Viewed:  18895 Time(s)
SkySteve
PostPosted: Fri Mar 06, 2009 6:36 am    Post subject: Re: Fuel Flow Display Reply with quote
Dick,
Thanks for the info and the photo. My installation is exactly like yours. After I installed it, I got to wondering if I had screwed up by placing it upside down.
Steve Wilson
Huntsville, UT
Float Flyr
PostPosted: Fri Mar 06, 2009 7:24 am    Post subject: Fuel Flow Display Reply with quote
Dick can I get a close-up on how you attached the oil cooler?
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Friday, March 06, 2009 9:45 AM
Subject: Re: Fuel Flow Display
Steve,
          Dick Maddux
          Rotax 912UL
          Fox 4
          Pensacola,Fl
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Fri Mar 06, 2009 7:42 am    Post subject: Fuel Flow Display Reply with quote
If I'm reading Dick correctly, his is right side up, with the outlet
end at the top, right, Dick? And Steve, it sounds like yours is as
you say "upside down" meaning that the outlet is at the bottom? This,
according to the instructions, is not what they want....I don't
think. But if you guys are happy, I'll just shut the hell up. : )
Lynn Matteson
Jabiru 2200, #2062, 610 hrs
Sensenich 62x46
Status: flying
On Mar 6, 2009, at 9:36 AM, SkySteve wrote:
Dick,
Steve Wilson
Huntsville, UT
http://forums.matronics.com/viewtopic.php?p 33459#233459
Lynn
Kitfox IV-Jabiru 2200
N369LM
SkySteve
PostPosted: Fri Mar 06, 2009 8:02 am    Post subject: Re: Fuel Flow Display Reply with quote
Lynn,
Your understanding of my installation is wrong. There is an arrow on the side of the sending unit which indicates which way the fuel should flow through the sending unit. When mounted veritcal and between the gasolator and the fuel pump, that arrow should, and does, point "up". That is how mine is installed.
If, on the other hand, the sending unit was installed below the header tank, the arrow should point "down". I don't have enough room below the header tank to install the sending unit there.
Steve Wilson
Huntsville, UT
Lynn Matteson
PostPosted: Fri Mar 06, 2009 11:41 am    Post subject: Fuel Flow Display Reply with quote
Yup, I gotcha now, Steve....as I was waking up my computer just now,
I got to thinking of how that arrow (I have the same unit as you) is
indicating flow direction, and not necessarily "UP". .....my bad!
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 6, 2009, at 11:02 AM, SkySteve wrote:
Lynn,
Steve Wilson
Huntsville, UT
http://forums.matronics.com/viewtopic.php?p 33466#233466
Lynn
N369LM
Dick Maddux
PostPosted: Sat Mar 07, 2009 5:22 am    Post subject: Fuel Flow Display Reply with quote
Steve,
My sending unit is attached right side up in accordance with the marked arrow on the unit for fuel flow. I don't know how it will work upside down. You will probably get much better gas mileage then I do (in fact making fuel).
        Dick Maddux
        Pensacola,Fl
Dick Maddux
PostPosted: Sat Mar 07, 2009 5:35 am    Post subject: Fuel Flow Display Reply with quote
Steve,
I didn't read far enough in the posts.You do have it installed correctly. The unit works well after you get it calibrated. The buttons don't work all that well and it is kind of a pain but doable.
      Dick Maddux
      Pensacola,Fl
SkySteve
PostPosted: Sat Mar 07, 2009 1:46 pm    Post subject: Re: Fuel Flow Display Reply with quote
Have you found a good (ready easy) way to calibrate the fuel meter? I did read the instructions and figured I'll have to fill both wing tanks, fly for awhile, then drain the wing tanks and remeasure the fuel left to figure my real fuel usage.
Steve Wilson
Huntsville, UT
Lynn Matteson
PostPosted: Sat Mar 07, 2009 2:17 pm    Post subject: Fuel Flow Display Reply with quote
I haven't tried to calibrate mine yet...not enough hours on it, or
fuel through it to bother with yet.
Lynn Matteson
Sensenich 62x46
Status: flying
Steve Wilson
Huntsville, UT
http://forums.matronics.com/viewtopic.php?p 33620#233620
Lynn
N369LM
andynfultz(at)bellsouth.n
PostPosted: Sat Mar 07, 2009 9:40 pm    Post subject: Fuel Flow Display Reply with quote
Steve,
Wouldn't it be much easier to top off, go fly and then top off again?
What ever you put in after the flight is what you burned isn't it?
Andy F.
Dick Maddux
PostPosted: Sun Mar 08, 2009 5:39 am    Post subject: Fuel Flow Display Reply with quote
Steve,
Like Lynn, I haven't worried too much about the exact accuracy. What I have been doing is watching the fuel quantity in the tanks vs the amount shown on the gauge. I have been increasing the amount used on the gauge which in turn increases the amount used on the fuel flow. I am now up to 3.8 gph at 5000 rpm which seems to jive pretty good with my sight gauges. I will continue to tweek it. If I get it in the ball park I am ok with it as the sight gauges bounce all over the place in the air and it is nice to have a steady reading off the Northstar. I have been checking the two together (sight gauge and Northstar) as it sits on the ground as that amount is pretty close. I have drained and refilled my airplane many times so I know the sight gauges are pretty close on the ground.
        Dick Maddux
        Fox 4
        Rotax 912 UL
        Pensacola,Fl
Float Flyr
PostPosted: Sun Mar 08, 2009 8:12 am    Post subject: Fuel Flow Display Reply with quote
Fill to the gunwales, go fly a while and refill to the gunwales measuring
the amount for the second fill. Reset the fuel flow meter.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
SkySteve
PostPosted: Sun Mar 08, 2009 8:21 am    Post subject: Re: Fuel Flow Display Reply with quote
Gunwales it is!! Idea
Steve Wilson
Huntsville, UT
Float Flyr
PostPosted: Sun Mar 08, 2009 8:34 am    Post subject: Fuel Flow Display Reply with quote
Good enough for Government work!
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sun Mar 08, 2009 11:49 am    Post subject: Fuel Flow Display Reply with quote
What do you expect from a guy who lives less than 50 feet from the North
Atlantic??? Smile
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
SkySteve
PostPosted: Thu Mar 12, 2009 3:17 pm    Post subject: Re: Fuel Flow Display Reply with quote
NEW PROBLEM: I have installed the transducer in the fuel line. I have also installed the fuel flow meter in the panel and wired it to my electrical system. The meter works great!
HOWEVER, when I connect the transducer to the meter via the 5 pin connector, the meter shuts off, goes dark, no light, shows nothing, blank screen. I am thinking I must either have: a) a bad 5 pin connector (which I can fix by cutting off the connector and hard wiring the transducer to the meter) OR, b) a bad transducer. One more option/question: Does the transducer require fuel to be going through it in order for it to work? I have not yet run the engine.
Steve Wilson
Huntsville, UT
Dick Maddux
PostPosted: Fri Mar 13, 2009 3:55 am    Post subject: Fuel Flow Display Reply with quote
Steve,
When I turn the master switch on in my aircraft the Northstar beeps,red internal light comes on and it indicates GAS followed by the amount in the tanks. The fuel flow button if pushed shows a blank as the engine is not running.
        Dick Maddux
        Pensacola,Fl
akflyer
PostPosted: Fri Mar 13, 2009 6:28 am    Post subject: Re: Fuel Flow Display Reply with quote
I have checked my meter several times and it was close enough out of the box that I have not felt the need to screw with it. I just filled it up with X amount of gas, went flying for a few hours then I always drain gas out of the tanks for trailering... What I sucked out of the tank was really dang close to what the meter said I had remaining.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Page 1 of 3
