701steering boots
samhord2(at)gmail.com
PostPosted: Tue Mar 03, 2009 9:47 am    Post subject: 701steering boots Reply with quote
I know this has been brought up before, but I can not find it in my papers. What is the Yamaha part number for the snowmobile boots that are used to seal the steering rods through the firewall? Thank you very much. If anyone has an alternative, please let me know.
Sam
dlorrzen701(at)earthlink.
PostPosted: Tue Mar 03, 2009 10:51 am    Post subject: 701steering boots Reply with quote
Here you go.
David L. Orr
EAA430
[quote]--
Steering_Boots1.doc
 Filename:  Steering_Boots1.doc
 Filesize:  293 KB
 Downloaded:  475 Time(s)
john.marzulli(at)gmail.co
PostPosted: Tue Mar 03, 2009 11:13 am    Post subject: 701steering boots Reply with quote
Thanks!
I was just thinking about these...
DO NOT ARCHIVE
John Marzulli
http://www.GenevieveMarzulli.org/
http://marzulli.smugmug.com/
http://701Builder.blogspot.com/
http://www.JohnMarzulli.net/
On Tue, Mar 3, 2009 at 10:49 AM, David L. Orr <dlorrzen701(at)earthlink.net (dlorrzen701(at)earthlink.net)> wrote:
Here you go.
David L. Orr
EAA430
[quote]--
larry(at)macsmachine.com
PostPosted: Tue Mar 03, 2009 12:21 pm    Post subject: 701steering boots Reply with quote
Sam,
There's an easier way if you like working aluminum. I made these for my
601HDS, but the process would be the same.
http://www.macsmachine.com/images/controllinkages/full/steer-rod-air-barrier.gif
http://www.macsmachine.com/images/controllinkages/full/steer-rod-air-barrier-2.gif
They work fine and there's no leakage.
Sam
bobkat
PostPosted: Tue Mar 03, 2009 1:19 pm    Post subject: 701steering boots Reply with quote
Hey Larry! Does that just slide up and down? That looks like an ingenious
way of sealing! I just remembered that mine are still wide open! Was
thinking I had to seal them off come spring! Thanks! Bob
PostPosted: Tue Mar 03, 2009 2:08 pm    Post subject: 701steering boots Reply with quote
Hi Bob,
Yes, the piece is thinner than the sandwich materials and it has a
grommet that fits the rod within the hole and the piece is captured so
it can go up and down
as well as a little sideways for the radial action of the strut. Two
bolts and it's secure, one thru the bottom and one thru the top.
ingenious way of sealing! I just remembered that mine are still wide
open! Was thinking I had to seal them off come spring! Thanks! Bob
Dwight Early
PostPosted: Tue Mar 03, 2009 4:44 pm    Post subject: Re: 701steering boots Reply with quote
I just picked up a set on Ebay for $25.00 shipped and I think there were a couple more pair still showing last week.
Dwight Early
N701EF
Zenith CH701/Revmaster
Daleville, In
lane_jones(at)bellsouth.n
PostPosted: Tue Mar 03, 2009 6:44 pm    Post subject: 701steering boots Reply with quote
Dwight,
What heading were they listed under?
Lane Jones
Dwight Early
PostPosted: Thu Mar 05, 2009 5:32 am    Post subject: Re: 701steering boots Reply with quote
Sorry for the slow reply. Just put in steering boots under the main page and you will get all kinds of different ones. Looks like several of them would work.
Dwight Early
N701EF
Daleville, In
