Posted: Tue Feb 24, 2009 9:15 am Post subject: E-bus and sd-8 alternator connections Z-13/8 Q |
At 11:06 AM 2/23/2009, you wrote:
I am laying out my RV-10 wiring based on the Z-13/8 Q. My battery
is behind the bagage area as is my master contactor. Z-13/8 Q shows
the SD-8 going to the battery side of the contactor. My battery bus
will be next to the battery and I will run the e-bus supply wire
from there foward to the panel.
Question: Instead of running another wire all the way back to the
master contactor from the SD-8 could I just run from the SD-8 to
the E-bus which is under the panel?
With this arrangment I would activate e-buss when needed and then
sd-8, otherwise sd-8 would be dormant and only supply power when
e-buss is activated.
I've pondered this a bit . . . I think you will
be okay with that modification.
( -Thomas Paine 1776- )
toaster73(at)embarqmail.c Guest
Posted: Tue Feb 24, 2009 7:21 pm Post subject: E-bus and sd-8 alternator connections Z-13/8 Q |
Thanks, I'll press on.
-Chris
