FUSE BOX
CZ
PostPosted: Tue Feb 24, 2009 2:00 pm    Post subject: FUSE BOX Reply with quote
Does anyone know what the external accessible fuses in the Tb-2 (power supply relay box) to the right of the pilot are for. I believe the bottom one is generator warning light? Does anyone know what they should be labeled.
Thank you in advance,
I do have the wire diagram.
Rob Rowe
PostPosted: Wed Feb 25, 2009 9:20 am    Post subject: Re: FUSE BOX Reply with quote
Not familiar with Tb-2 box nomenclature ... but if you're referring to the YAK-52 DC Power Box then the attached PDF shows the fuse allocations and their respective downstream distribution feeds / breakers.
Hope this helps.
brgds, Rob R
YAK-52 DC Power Box Fuses.pdf
 Filename:  YAK-52 DC Power Box Fuses.pdf
 Filesize:  162.23 KB
 Downloaded:  912 Time(s)
CZ
PostPosted: Wed Feb 25, 2009 9:52 am    Post subject: Re: FUSE BOX Reply with quote
I apologize, I should have specified CJ-6. I appreciate the help.
