new bush gear
Goto page Previous  1, 2, 3
Dick Maddux
PostPosted: Sun Feb 22, 2009 2:48 pm    Post subject: new bush gear Reply with quote
I have a few more pictures of my installation. One of the pictures shows the fairings which I have put on with a couple of Clecos. I will order enamel tomorrow so I can complete this part of the project.
I was going to fly today but a front came through and it was too windy, maybe tomorrow.
        Dick Maddux
        Fox 4-1200
        Pensacola,Fl
Need a job? Find an employment agency near you.
 Filesize:  370.75 KB
 Viewed:  20800 Time(s)
 Filesize:  345.82 KB
 Filesize:  362.55 KB
dcubj3(at)terra.com.br
PostPosted: Sun Feb 22, 2009 3:24 pm    Post subject: new bush gear Reply with quote
Lynn
My aircraft is not Original Kitfox
Is called "Aguia" (eagle) model V. It is Brazilian Kit. More than 200 units sold.
It´s similar KIV with few model V modifications. (speed wing, and Model V estabilizator). Other parts is similar that Model IV.
Total weight is almost 1.400 lbs.
I used KIV W&B xls
Do you think that I have to use Kitfox Model V W&B xls?
Tks
De:owner-kitfox-list-server(at)matronics.com
Para:kitfox-list(at)matronics.com
Cópia:
Data:Sun, 22 Feb 2009 17:13:58 -0500
Assunto:Re: new bush gear
Francisco-
I've lost track of what this plane is...Model IV, 5, 6, 7? The reason
I ask is because in viewing your W&B sheet...Noel forwarded it to
me....it shows the GC range for the planes that are either 1050 or
1200 lbs. Max. Gross Weight, and I would imagine that your plane is a
higher gross weight than either of these. If so, maybe the CG
envelope/range is different than the 10.2" to 16.0" that the form shows
Paul A. Franz, P.E.
PostPosted: Sun Feb 22, 2009 3:49 pm    Post subject: Re: new bush gear Reply with quote
[quote="Dick Maddux"]
.....I will order enamel tomorrow so I can complete this part of the project.
I think you're going to be disappointed. The orange peel problem you're having with Polytone is caused from the relative humidity of the surrounding air being too high. From my experience, enamel will have the same problem, possibly worse. Also, unless it is some kind of polyurethane enamel you're likely to get cracking on it over fabric.
You've got to paint it inside a shop and use some kind of dehumidificaton. If it is warmer in the shop than it is outside, the relative humidity will be lower, presuming the shop has not added additional water to the air from wet floors.
Paul A. Franz, P.E.
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Lynn Matteson
PostPosted: Sun Feb 22, 2009 4:47 pm    Post subject: new bush gear Reply with quote
I would follow whatever the kitmakers suggest as far as what W&B
information to follow. Only they will know. They should at least
advise to as to what the max gross weight should be, and where the
forward most, and where the rearward most extremes of the center of
gravity should be located, and from what point (datum point) should
these measurements be made.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
Status: flying
On Feb 22, 2009, at 6:23 PM, Francisco dcubj3 wrote:
Lynn
200 units sold.
I used KIV W&B xls
Tks
Cópia:
> Francisco-
reason
is a
shows.
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> Status: flying
> On Feb 21, 2009, at 4:06 PM, Francisco Drovetta wrote:
> > Lynn, this is correct!!!
> > Original tailwheel weight: 15 lbs
> > With new "bush landing gear"
> > ( Main wheel axle is 4" closer than datum )
> > New tailwheel weight: 33 lbs
> > MORE 11 lbs = 44 lbs
> > 44 lbs is 5% of total weight (883 lbs), as your instruction "
> > very useful information"
> > Tks very much!!!
> > FD
> > www.dcubj3.com.br
============== V> DIV> V> ============== V> ==============
www.matronics.com/contribution _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
Tom Jones
PostPosted: Sun Feb 22, 2009 5:40 pm    Post subject: Re: new bush gear Reply with quote
Dick, and Fransisco,
The thing that strikes me the most when looking at your pictures is that the Bush Gear makes your airplanes look bigger. I hate it when non airplane people look at my Kitfox and say, "it sure is Little".
You both know that now I have to save up for tw items...a big 4 stroke engine AND a Bush gear.
Tom Jones
Classic IV
Ellensburg, WA
larry huntley
PostPosted: Sun Feb 22, 2009 5:56 pm    Post subject: new bush gear Reply with quote
I have heard the same thing about my Fox. Just like cars. Bigger ain't
neccessarily better,just lots more expensive. Larry Huntley,4-1200 Soob
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
rawheels
PostPosted: Sun Feb 22, 2009 6:50 pm    Post subject: Re: new bush gear Reply with quote
Heck, I like it even without the fairings (the kitfox brand style), and maybe I could save some more money without the sheet-metal and tabs. Hopefully Highwing can beat the grove gear upgrade by more than just $140 like Kitfox does though.
Guess we'll see. I've tried to reach both Mark and Lloyd at Highwing LLC. So, maybe I'll hear something soon.
Ryan
Kitfox IV-1200
Indianapolis, IN
Dick Maddux
PostPosted: Mon Feb 23, 2009 5:38 am    Post subject: new bush gear Reply with quote
Paul,
The humidity is running about 40% and temp in the 60's.I have been able to paint fine with spray cans but cannot get close enough to the Arctic Blue color for my gear fairings so I have tried the Poly Tone.The enamel in the spray cans lays fine.
I am just going to "bite the bullet" and order the Arctic Blue enamal from Spruce and get on with it.I will probably use the extra paint for some other thing I need to paint.
Thanks for your suggestion
        Dick Maddux
        Pensacola,Fl
Get a jump start on your taxes. Find a tax professional in your neighborhood today.
patreilly43(at)hotmail.co
PostPosted: Mon Feb 23, 2009 5:24 pm    Post subject: new bush gear Reply with quote
Deke C And C now I'm considering tearing off the brand new landing gear I installed and installing Lowell's bush landing gear C especially after Dick's report. These damn airplanes are worse than streetrods and motorcycles. Old cars are fun C motorcycles are crazy C and airplanes they are reserved for the insane!
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: Re: new bush gear
Date: Sat C 21 Feb 2009 18:31:40 -0500
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} Patrick C at 25% you're probably doing as well as anyone here.  The real down side is that a part of the 25% is also weight.  So it goes...
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory C but progress."
- Joseph Joubert
Dick Maddux
PostPosted: Tue Feb 24, 2009 3:35 pm    Post subject: new bush gear Reply with quote
I installed one of the gear fairings today. It is not completely done but I am getting there.I had to fly a little prior to starting the fairing work.
Here,s a couple of photos to show how they will look.
      Dick Maddux
      Kitfox 4-1200
      Pensacola,Fl
 Filesize:  375.52 KB
 Viewed:  20737 Time(s)
 Filesize:  386.4 KB
Fox5flyer
PostPosted: Tue Feb 24, 2009 5:48 pm    Post subject: new bush gear Reply with quote
Very nice, Dick. It looks great!
Deke
Fox5flyer
rjdaugh
PostPosted: Tue Feb 24, 2009 9:19 pm    Post subject: new bush gear Reply with quote
Thanks Dick,
I was watching for pictures of the fairings. Lowell does nice work and I was wanting to see how the fairings were done.
They look good!
Randy
Do not archive.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Tuesday, February 24, 2009 4:25 PM
    Dick Maddux
    Kitfox 4-1200
    Pensacola,Fl
Randy
Kitfox 5/7 912S
Black Hills, South Dakota
rawheels
PostPosted: Wed Feb 25, 2009 10:25 am    Post subject: Re: new bush gear Reply with quote
Lowell is still on vacation, but I finally got a hold of Mark (at) Highwing LLC. He thinks that the price for the basic type will be $1275. If you want fairings like Dick has they will be extra.
I had kind of a bad connection with their cell phone, but from what I understand the gear are sent all ready to bolt on and you re-use your original axles and wheel assemblies. So, it is just like the Kitfox version just $175 cheaper. $315 cheaper than grove (plus the weight savings).
Kitfox IV-1200
Indianapolis, IN
Av8r3400
PostPosted: Wed Feb 25, 2009 10:39 am    Post subject: Re: new bush gear Reply with quote
Do you think the farings increased the strength at all? Just by eyeball this design doesn't look as strong for off runway use.
(Just the appearance is all.)
Have you seen the design used by this Highlander builder? (I think it is a custom design) Note the use of THREE down tubes.
 Filesize:  65.7 KB
 Viewed:  20700 Time(s)
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos
Dick Maddux
PostPosted: Thu Feb 26, 2009 4:52 am    Post subject: new bush gear Reply with quote
I completed the gear installation with the fairings and will post two more photos.(the fairing from the top of the gear legs to the fuselage is my own build) This will be my last as I don't want to bore you with this topic. As mentioned earlier,I am absolutely thrilled with this new gear and would never want to go back to the old one. The ground handling is fantastic!
The completed fairing installation seems to have added my 3-4 mph speed loss back to my cruise speed. Keep in mind this is not a scientific analysis but is based totally on observed indicated airspeed. The fairings are thin .016 skins attached to the gear legs to "clean up" the installation for aerodynamic purposes, they do not add any strength to the gear as one member had questioned.
I really don't know who came up with the term "bush gear" for this style of gear. It looks like a cub gear with springs and this type of gear has been used on a lot of different aircraft. Is it as strong as a Highlander's? (my favorite aircraft) I doubt it. Is it as strong or stronger than the original. I don't know that either. Is it easier to maintain and look at? YOU BET!
          Dick Maddux
          Fox 4-1200
          Pensacola,Fl
 Filesize:  374.04 KB
 Viewed:  20682 Time(s)
 Filesize:  397.41 KB
PostPosted: Thu Feb 26, 2009 7:10 pm    Post subject: new bush gear Reply with quote
Dick C Beautiful! You aren't boring anybody. The added top fairing looks great. I believe my wheels are about the same size as yours.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Thu C 26 Feb 2009 07:50:51 -0500
I completed the gear installation with the fairings and will post two more photos.(the fairing from the top of the gear legs to the fuselage is my own build) This will be my last as I don't want to bore you with this topic. As mentioned earlier CI am absolutely thrilled with this new gear and would never want to go back to the old one. The ground handling is fantastic!
 The completed fairing installation seems to have added my 3-4 mph speed loss back to my cruise speed. Keep in mind this is not a scientific analysis but is based totally on observed indicated airspeed. The fairings are thin .016 skins attached to the gear legs to "clean up" the installation for aerodynamic purposes C they do not add any strength to the gear as one member had questioned.
        Dick Maddux
        Fox 4-1200
        Pensacola CFl
whizzers
PostPosted: Fri Feb 27, 2009 12:42 am    Post subject: Re: new bush gear Reply with quote
Hello Dick
Nice looking gear.
Could you please post or send me a good photo or sketch of the detail of how the top cabane attaches to the fuselage at the gear lag?
I am trying to fabricate a set of spring gear for my Avid, but keep getting derailed by the top attachment point.
Bob McCaa
Page 3 of 3
