Bendix PS7BD Pressure Carb
Cate Chagnot
PostPosted: Tue Feb 24, 2009 8:47 am    Post subject: Bendix PS7BD Pressure Carb Reply with quote
Hi Everyone,
Anyone out there know the best place to get a Bendix PS7BD Carb
rebuilt at anything less than the cost of an entire airplane?
The quote I have so far is for around $3,500... Ouch!!!
Any help will be greatly appreciated.
Cate
N4278S Aero Commander 680E
Cate
N4278S 680E
Skywagon N180PK
brcamp(at)windows.microso
PostPosted: Tue Feb 24, 2009 9:09 am    Post subject: Bendix PS7BD Pressure Carb Reply with quote
I had mine done at Precision Engines in Everett, WA for a reasonable amount of money (about $1500) a few years ago. They are more or less the OEM these days.
rambud(at)windstream.net
PostPosted: Tue Feb 24, 2009 11:38 am    Post subject: Bendix PS7BD Pressure Carb Reply with quote
Cate,
I can't guarantee what the price will be, but I had a PS5 pressure carb
rebuilt by a guy in OK that only cost me $869, which included replacing a
diaphragm.
Email off net for more details if you are interested.
Bud
RnJThompson(at)aol.com
PostPosted: Tue Feb 24, 2009 12:22 pm    Post subject: Bendix PS7BD Pressure Carb Reply with quote
Cate,
The price of the kits are unbelievable. The only place you can get them is
from Precision Engines. They on the other hand offer an overhaul for less
money than they sell the kits for. I would send it to them. Once they are
done with the red diaphragms you should not have any grief out of them for
many years. www.precisionengines.com/pages/carburetors.html
They are complex pieces of kit. It took me at least a day per carb to strip
and reassemble the set up on the fuel rig lasted about two days per carb.
Setting them up is a painfully slow process. Each has about ten check points
on the fuel curve. I got mine to within half a pound an hour fuel flow
difference between them across the entire curve. These thing are truly
precision instruments. There are not too many people around these days who
even know what they look like, never mind knowing how to set them up.
Cheers
Richard
PostPosted: Tue Feb 24, 2009 12:34 pm    Post subject: Bendix PS7BD Pressure Carb Reply with quote
The other thing is they have a number of bodies, etc in case your carb has too much wear to ever dial in. Mine had that problem and they were able to provide a better (by no means perfect, but usable) throttle body from spares. Noone else is going to be able to do that.
Cate Chagnot
PostPosted: Tue Feb 24, 2009 1:35 pm    Post subject: Re: Bendix PS7BD Pressure Carb Reply with quote
Thanks Guys,
It's on its way to Precision Engines. They want about $2000 for a basic rebuild now. There's a 10% special on at the moment. Minimum then around $1800 It sure beats the $3500 quote I got earlier. It's a spare that came with the 2 core engines I tracked down for the plane. When it comes back I'll send out the one on the plane now and hopefully should be in good shape.
Cate
 Filesize:  626.31 KB
 Viewed:  5713 Time(s)
Cate
N4278S 680E
Skywagon N180PK
