Finish and Paint questions ??
Goto page 1, 2  Next
AirMike
PostPosted: Mon Feb 23, 2009 10:41 pm    Post subject: Finish and Paint questions ?? Reply with quote
getting toward the finish line and I would like to get some feed back on paint and finish
1. Cowling - how many are using just smoothprime to finish the cowling prior to painting? Sealing pinholes seems to be a big problem here.
2. PPG DCC Concept seems to be a very popular paint right now. Does anyone who has used it have any feedback - (expensive)
3. I was told today that PPG DCC Concept does not need to follow the traditional : scotch brite (aluminum) - alodine - prime - paint protocol
I was told that you can go right to the paint from the alodine process??
See you OSH '18
Q/B - sold.
Tim Olson
PostPosted: Tue Feb 24, 2009 4:43 am    Post subject: Finish and Paint questions ?? Reply with quote
I found the PPG Concept to be pretty good paint for spraying.
I'm sure there are many good ways to go though. It does
have the advantage of being available locally for me.
I do think you still have to do the necessary steps.
Scotchbrite, etching primer, sealing primer, paint.
Now if the surface was alodined, I'm not positive, but
you probably don't have much exterior alodined metal at
this time I'm guessing. If you did have the body alodined,
maybe it would be possible to skip the etching primer, but
I don't know many who are alodining the exterior first.
A couple nights ago I sat in a chair in the back of the hangar,
looking at the light reflecting off the empennage. It was
overwhelming how pretty it all looked. The paint in some
areas of the plane isn't perfect...after all, it was a DIY+help
job, but boy did that area look good to me.
I'd encourage many people to get some competent help and
give a home spray job a try...you'll save many thousands of
dollars.
on paint and finish
problem here.
protocol I was told that you can go right to the paint from the
alodine process??
-------- OSH '08 or Bust (busted) be there in "09 Q/B Kit -
wiring and FWF
http://forums.matronics.com/viewtopic.php?p 31758#231758
timrvator(at)comcast.net
PostPosted: Tue Feb 24, 2009 5:03 am    Post subject: Finish and Paint questions ?? Reply with quote
The PPG tech line is 1-800-647-6050. They've been instructed to refer
airplane questions to their aircraft paint line (different product), so
I couched my PPG Concept questions to apply to a custom car with
aluminum, fiberglass, steel, and plexiglass components.
I'm taking the route of:
- conversion (DX533/DX503 for aluminum, DX579/DX520 for the steps)
- DP48LF epoxy primer (DP402LF catalyst)
- DCC single stage top coat (DT885 reducer and DCX61 activator), DX73
fisheye eliminator if needed
I'm going to try the single stage (DCC) topcoat on a small piece first
(rudder, perhaps) to see what kind of rivet coverage I get. I've had
lots of problems with Imron not covering rivets properly (10 years ago
on my RV-6A). If the DCC covers the rivets OK I'll press ahead. If
not, I may try PPG's basecoat/clearcoat system.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1000 hrs
RV-10 #40059 under construction
Q/B Kit - wiring and FWF
n223rv(at)wolflakeairport
PostPosted: Tue Feb 24, 2009 6:03 am    Post subject: Finish and Paint questions ?? Reply with quote
I've used DCC on my RV-4 inside and out as have 4 of my friends. Is
is very east to spray and is very durable. I acid etched and primed
prior to paint. I am not sure I'd spray it directly to the aluminum
without primer first....
I also have sprayed the interior of my -10 with DCC, but it Is not
flying yet.
-Mike Kraus
dollars.
> on paint and finish
> problem here.
> alodine process??
> -------- OSH '08 or Bust (busted) be there in &quot;09 Q/B Kit -
> wiring and FWF
ricksked(at)embarqmail.co
PostPosted: Tue Feb 24, 2009 6:53 am    Post subject: Finish and Paint questions ?? Reply with quote
I'm using Mike Loehle's products. Wonderfil is just that, rub it in with a towel and prime..I've never seen such a great product. I'm aslo using Prekote, the newest metal prep product the Airforce is using. Rub it on with a red pad and it preps and conditions in one step. It is enviromentally safe. FWI Mike is the guy who did the article for Van's RVator using Gen Grumpys aka Gen Miller's RV-10 paint job. My total cost for the entire line of products was $2600 plus shipping for four colors. This included everything, primer, filler, thinner, Prekote.
Rick Sked
40185
RandyL
PostPosted: Tue Feb 24, 2009 7:23 am    Post subject: Finish and Paint questions ?? Reply with quote
I'm sure you've read the advice to ALWAYS stay with one family of products.
I've painted three planes now (two were my own) and used PPG for all
including Concept DCC. Use SmoothPrime for the first heavy coat, sand off,
then switch to PPG K38 for subsequent coats.
Excellent product and system. Experience with it here...
http://www.romeolima.com/RV3works/Paint/paint.html
..and here...
http://www.romeolima.com/RV8/Paint.htm
You absolutely need to Scotchbrite the bajeezus out of the aluminum to let
the coatings have both chemical and mechanical adhesion. You can use
self-etching primer in lieu of the etch/alodine process however. PPG makes
such a self-etch primer, DX1791 which is what I used -- no adhesion issues
whatsoever.
Randy Lervold
RV-3B, 170 hrs and a joy to fly
RV-8, 368 hrs, sold
john(at)trollingers.com
PostPosted: Tue Feb 24, 2009 7:50 am    Post subject: Finish and Paint questions ?? Reply with quote
A little off topic from this, but what can you expect from a painter
if you pay to have it done. How much of the finishing work so you
still have to do yourself before taking it to a painter?
thanks,
Tim Olson
PostPosted: Tue Feb 24, 2009 8:14 am    Post subject: Finish and Paint questions ?? Reply with quote
Prices vary, but I think most people end up somewhere in the
$6,000-$8,000 range if I remember right, for a full job.
Some people can take it in rough and bring it home painted,
some need to take it in finished pretty well. Of course,
if you pay by the hour it will be very beneficial to
do as much finishing as you can, and still do a good job.
It's not fun stuff. But, if you finish it yourself, just
like Rick mentioned, I think my paint total was probably
in that $2,000-2,500 range for ever last paint supply,
so you can save a lot. Enough to maybe buy a GNS-430W
or other gizmo, in some cases....and once you're up in the
air, the paint does a lot less in getting you down and home
safe than some of the other cool stuff.
thanks,
tomflysalot
PostPosted: Tue Feb 24, 2009 9:27 am    Post subject: Finish and Paint questions ?? Reply with quote
John,
It really depends on the painter. My painter helped me to do the finish
fiberglass work (sand, fill, prime, sand) to the point of perfection. I
think, mainly, because he has pride of workmanship. In other words, he
didn't want people to see his final product with my building flaws built
in.
Some painters don't care, but most want the finished product to be a
reflection of them.
I had my painter put a coat of black primer on the plane so it would show
any imperfections. Then, together, we work out the flaws. Like
everything else, it's a matter of whose time is more valuable.
Many painters will give the option of "who does what". If they feel
there is a lot of finish work to be done before paint, they may quote it
separately (so you have the option of doing it yourself, or paying them
to do it. Items like exterior window trim, I felt he could do a better
job than me.
Hope this helps.
Tom
970-420-1798
____________________________________________________________
Click here to save cash and find low rates on auto loans.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTLaWzD9WIFeJWdfWQajaUlLG6OBTb5U9vqCdsmHbuc3biU431xIpK/
robin1(at)mrmoisture.com
PostPosted: Tue Feb 24, 2009 11:05 am    Post subject: Finish and Paint questions ?? Reply with quote
I usually agree with Tim on all things but I doubt many builders will
find a professional to paint an RV-10 for $6,000. I would budget $8,000
as the floor for a turnkey paint job. As we all know the floor is NOT
the ceiling.
Robin
AV8ORJWC
PostPosted: Tue Feb 24, 2009 11:14 am    Post subject: Finish and Paint questions ?? Reply with quote
My favorite painter tagged his last job about 35% of his $10,000 fee for
finishing what the builder called "Ready for Topcoat". Randy's post on
aggressive sanding and using the same company and chemistry between
binder then topcoat is critically important. His advice is usually "Rock
Solid" the only point we depart on is the avoidance of clearcoat and
the use of a mist coat of reducer to thin down the "Orange Peel". Yes
Deems, clear does add weight and additional protection. A great painter
will sand a bunch of it off and buff it to lower the final weight.
Anyone want to add the GW of an SR22 and final sales price here?
That $10,000 did not include $5 in chemicals and $3 in custom artistic
airbrushing.
Deems shot is a great example of a delivered aircraft with three to four
color with plenty of clear overcoat protection. To which Randy Lervold
could chime in that some of the weight was the clearcoat, cause his
reducer evaporates like the air in Deems tires and the oxygen in his
tank. I wouldn't do it much different just to save the weight. It is a
chance to re-connect with the plane by doing dozens of hours of sanding
and buffing and sanding a buffing while listening to Jimmy Buffett with
a few cases of cold ones.
Randy Debauw with the first painted RV-10, did it with a friend who does
Harleys in the dead of winter during February "in his driveway" no less.
Tim gave a great encouragement of doing your own. Scott teased us with
his finished "Rocketman" wheel pants even before laying his brothers
beautiful creation down. Scott also used pearlescent white. Robin is
waiting to tease us with his pride and joy. Each to their choice. Just
budget a soda blast strip and repaint if you first choose unwisely or
your golly cool neighbor's newest Stewart System is not to your liking.
It really depends on you/and your painter/and the chemistry
503-453-6016
Tim Olson
PostPosted: Tue Feb 24, 2009 11:28 am    Post subject: Finish and Paint questions ?? Reply with quote
That low end is something I'm digging out of old old old
discussions, so you're probably right...I actually was going
to say 6-10K, but I didn't know how accurate that would be
either.
What say the group??? Have many of you found professional
paint for $6000 or less? How about on the high end....has
anyone had to pay over $9000? And we're not talking
special deals that you got from a buddy....regular-guy
prices....what's it costing you folks to get pro paint these
days?
the ceiling.
Robin
PostPosted: Tue Feb 24, 2009 12:21 pm    Post subject: Finish and Paint questions ?? Reply with quote
Is there any benefit or drawback to painting (or getting painted) the
pieces as they are finished vs waiting to paint the whole plane
flying. It seems if I get good paint on it now it will protect it
during storage and spread the cost out over the build. With it being
small pieces could probably get a custom paint shop to do it as well
vs a aircraft paint shop.
PostPosted: Tue Feb 24, 2009 12:35 pm    Post subject: Finish and Paint questions ?? Reply with quote
Ok John, you really want to see my paint...I will give you a sneak
peak... I do plan to add a touch more color.
As for the Tim's question, I am paying $8K but the painter did ALL the
sanding, fill (including wing rivets). That being said I was told 3
weeks, expected 5 weeks and am passing 2 months (insert painter story
here). Oh... and Tim there are several paint jobs over $12K+. Not sure
those people will chime in but they are definitely out there (and may be
worth the difference).
Robin
 Filesize:  623.78 KB
 Viewed:  19278 Time(s)
PostPosted: Tue Feb 24, 2009 12:37 pm    Post subject: Finish and Paint questions ?? Reply with quote
John,
I will only speak to my unusual engine/cowl configuration.
Because I have an untested combination we had to do A LOT of R & D with
the cowl on/off much more than the standard Phase 1. ~100 times is not
an exaggeration. That would have been a bummer with it freshly painted.
Add to that the I installed under side gills, then more, then more lower
cowl mods and the thought of cutting into a painted plane (cowl
especially) would have been a heart wrenching. To my way of thinking
paint then fly may be easier, fly then paint may be better.
Robin
tomflysalot
PostPosted: Tue Feb 24, 2009 1:17 pm    Post subject: Finish and Paint questions ?? Reply with quote
I spoke at length to my painter. He said the range on RV-10 paint jobs
could run from $8,500, up.
Again, it's what you want.
Tom
Click here to increase your salary by earning an online degree.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTKL6dS3TkG2Nt9ChBF37nF85O5kRCSqEC2faRhOxBCJpWrLTTy0bm/
pitts_pilot(at)bellsouth.
PostPosted: Tue Feb 24, 2009 3:17 pm    Post subject: Finish and Paint questions ?? Reply with quote
You get good paint coverage all over the part
or drawback
You can't get good coverage in places like the wing/tail rear spar
because the ailerons/flaps/elevators/rudder is in the way.
If you know what your base color will be, spray that and add the trim
after the plane is assembled.
With it being
Much easier to take the pieces parts to your paint shop if you go that
route.
You've bought tools and learned to rivet, why not buy tools and learn to
paint??? It isn't hat hard!
Linn
PostPosted: Tue Feb 24, 2009 3:56 pm    Post subject: Finish and Paint questions ?? Reply with quote
I would not mind painting myself (and a solid color base coat with the
colors after assembly is what I would do) but I am building in the
garage of my town home and not sure how conducive that is to painting.
I guess I have to research it some or see if anyone has a paint booth
in the northern Virginia area that I could use.
AV8ORJWC
PostPosted: Tue Feb 24, 2009 4:18 pm    Post subject: Finish and Paint questions ?? Reply with quote
What a tease.
Dan has not officially surfaced and Deems has not offered what he invested. I have seen both up close. Will fly to your's to see it close after you approve.
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of Robin Marks
Sent: Tue 2/24/2009 12:29 PM
Subject: RE: Finish and Paint questions ??
Robin
AV8ORJWC
PostPosted: Tue Feb 24, 2009 4:22 pm    Post subject: Finish and Paint questions ?? Reply with quote
Graphics and Number of colors in transition over parts have a BIG impact. The painter, even if that is you, will decide what is best. Good chemistry requests a min/max time to wait before sanding to apply second coats. If done withing a few hours or days, the second application will still etch into the previous without mechanical intervention.
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of John Trollinger
Sent: Tue 2/24/2009 12:20 PM
Subject: Re: Finish and Paint questions ??
--> RV10-List message posted by: John Trollinger <john(at)trollingers.com>
vs a aircraft paint nbsp; - The RV10-List Email Forum href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic--> http://forums.matronics.com
p; - List Contribution bsp;   -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
Goto page 1, 2  Next
Page 1 of 2
