saolesen(at)sirentel.net Guest
Posted: Mon Feb 23, 2009 7:34 pm Post subject: GRT Serial Connections |
Bob,
Is this offer still open? When it was first posted back in June I
had no need for it so I saved it just in case. I have pretty much
the same main equipment and I am having some trouble with the
interface between the 480 and 330. I've got a pair of Horizon 1's.
Also the fuel/air data between the GRT and the 480 has been a
problem. How does the 330 get its encoder data from the GRT? I'm
trying to get everything working for a trip to Farmington, NM in mid
March and a trip to avionics shop to upgrade the 480 on Fri.
I've got my hours flown off and took a trip IA to pick up my mother-
in-law for a 2-3 week stay. That 4 hour round trip sure beat a 12
hour car trip. To my surprise the gas going down was about the same
as driving. I been having fun so far.
Sheldon Olesen
N475PV
On Jun 11, 2008, at 3:49 PM, Condrey, Bob (US SSA) wrote:
<bob.condrey(at)baesystems.com>
Using GRT Wx with the WS/HS versions of the GRT requires high speed
serial inputs to each DU (as opposed to using inter-DU communication).
When the new HX displays are on the scene they will use USB
directly to
the Wx receiver (processor box not needed with the HX). Only ports
1 &
2 on the WS/HS support the 115,200 high speed serial rate. For
redundancy there are some cases where a single device (like the
AHRS/ADC) feeds multiple DUs.
I'd be happy to email my connectivity and configuration documents to
those interested. My panel config has the following so it's pretty
complete starting point:
GRT (3 screens)
PMA-8000B
SL-30
GNS-480
GTX-330
TruTrak Digiflight II-VSGV
GRT Weather receiver/processor
CO Guardian 353
AOA Pro
It is a relatively minor wiring difference between the GNS-480 I'm
using
and a 430W and doesn't impact the serial port configuration.
Bob
N442PM
bcondrey
Posted: Tue Feb 24, 2009 5:50 am Post subject: GRT Serial Connections |
Sheldon,
I'm getting ready to head out to COS on a business trip but will send the info tonight.
