Lynn Matteson
Posted: Thu Feb 19, 2009 11:29 am Post subject: New issue, turtle deck security |
The only problem there...the two links you mentioned...is that the
K1000 anchor nuts, and any anchor nuts that I've seen, require 3/32"
rivets to attach, and the other link, to Avex, don't supply 3/32"
flathead rivets...at least through Spruce...perhaps special order
though. And I wouldn't suggest trying to drill the 3/32" anchor nuts
out to 1/8" just for the convenience of not chasing down the
3/32"...they are harder than hell on drills...ask me. However, you
could use a 3/32" bolt...that'd be a #3 machine screw which mikes out
at .092" by actual measure, or a #4 which is .102" by actual measure.
The hole in one of my anchor nuts is .097" by measure, which means
that the #4 would not go, but could be drilled...maybe. There is a
place called MicroFasteners...not sure of spelling...that might have
the #3 screws, but they've (the #3's) been missing from most charts
that I've seen for quite a while. The ones I have are round head, and
were used on model airplanes. If you could still find them, round
head #3's would work, because the head would disappear into the foam
strip that you are going to apply over the butt rib capstrip, right?
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 19, 2009, at 7:33 AM, fox5flyer wrote:
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Thu Feb 19, 2009 12:37 pm Post subject: New issue, turtle deck security |
All good advice Lynn, but I don't know why there is a resistance out there
to normal solid soft aluminum rivets (the A type). They're very cheap, easy
to install, and extremely strong--way stronger than anything necessary for
the use that this thread is referring to. There is no need to buy an
expensive squeezer or any special tools. It's very simple. Just drill your
screw holes in the cap strip every 3 inches or so, then using a cleco, hold
the anchor nut in place on the top side of the rib cap. When you're
satisfied with it's placement, simply drill the rivet holes using a 3/32 bit
using the anchor nut as a pattern. Reverse the anchor nut to the underside
of the cap strip and rivet it in place. All that is needed for those tiny
rivets is a small ball peen hammer and some sort of small bucking bar on the
bottom side of the rivet. A few taps with the hammer and it's done. It
helps to use the corresponding attaching screw or a cleco to hold the anchor
nut in place while riveting. Very easy and once you get through a couple of
them the process goes very quickly. It's permanent, won't come apart, and
now if you want, can cover the butt rib area without having to worry about
access. I'd recommend #6 anchor nuts and screws. No need for anything
larger than that. Also, buy a rivet cutter (cheap) then order your rivets
at least 3/8-1/2" long and just trim them to size for the job you need. If
you screw one up in the process, those soft rivets drill out easily.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
jcrowder(at)lpbroadband.n Guest
Posted: Thu Feb 19, 2009 12:51 pm Post subject: New issue, turtle deck security |
To adjust for the weight of the handle, one would need to treat the weight
as a distributed load along the whole of the arm. The average arm would be
one half of the total length. As I haven't followed your calculations, you
may already have done this and I then apologize for the clutter of my
comment.
Jim Crowder
[quote] --
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Thu Feb 19, 2009 2:55 pm Post subject: Re: New issue, turtle deck security |
Okay, here is a few things I am hearing; solid rivets are easy to use, you do not need anchor nuts with nylon lock inserts, you do not need a screw every 2" as with the rivets. Is this all accurate for what everyone here is saying. My biggest issue is the solid rivets, from what I have read on other sites it takes a little getting used to to do them right. I can not however find any good illustrated 1. 2. 3. steps and I can not find a place locally that could show me how. The local EAA closed and I can not find one within an hour of here. So if I just go get a bucking bar, ball peen hammer, and some solid rivets, how many tests am I gonna do in scrap aluminum and wood before I will want to go to the butt rib?
(Yes I am mechanically inclined and this will not be like a monkey learning to do needle point.)
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Fox5flyer Guest
Posted: Thu Feb 19, 2009 3:33 pm Post subject: New issue, turtle deck security |
| Quote: | The local EAA closed and I can not find one within an hour of here. So if
go to the butt rib?
James
Ummm. . . . 6?
dgolden(at)golden-consult Guest
Posted: Thu Feb 19, 2009 4:22 pm Post subject: New issue, turtle deck security |
Lynn Matteson wrote:
The only problem there...the two links you mentioned...is that the K1000
anchor nuts, and any anchor nuts that I've seen, require 3/32" rivets to
attach, and the other link, to Avex, don't supply 3/32" flathead
rivets...at least through Spruce...perhaps special order though. And I
wouldn't suggest trying to drill the 3/32" anchor nuts out to 1/8" just
for the convenience of not chasing down the 3/32"...they are harder than
hell on drills...ask me. However, you could use a 3/32" bolt...that'd be
a #3 machine screw which mikes out at .092" by actual measure, or a #4
which is .102" by actual measure. The hole in one of my anchor nuts is
.097" by measure, which means that the #4 would not go, but could be
drilled...maybe. There is a place called MicroFasteners...not sure of
spelling...that might have the #3 screws, but they've (the #3's) been
missing from most charts that I've seen for quite a while. The ones I
have are round head, and were used on model airplanes. If you could
still find them, round head #3's would work, because the head would
disappear into the foam strip that you are going to apply over the butt
I have a suggestion. Last year at Oshkosh, I happened by the Click Bond
booth and saw that they have bonded nutplates. There stuff is a little
pricey, but it sure is neat. No rivets, no screws just click and go.
Check out this installation sequence drawing:
http://www.clickbond.com/files/Documents/cb9948_techguide.pdf
We actually did some of these while I was there.
Dennis M IV Speedster (someday)
Dennis Golden
Golden Consulting Services, Inc.
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Thu Feb 19, 2009 4:23 pm Post subject: Re: New issue, turtle deck security |
| Quote: | I can not however find any good illustrated 1. 2. 3. steps and I can not find a place locally that could show me how. The local EAA closed and I can not find one within an hour of here. So if I just go get a bucking bar, ball peen hammer, and some solid rivets, how many tests am I gonna do in scrap aluminum and wood before I will want to go to the butt rib?
(Yes I am mechanically inclined and this will not be like a monkey learning to do needle point.) |
I squeezed all the solid rivets in my kit with a pair of vise grips. It took about two test rivets to get the correct setting on the vise grips tension screw. Start with loose tension, squeeze, tighten a quarter turn, squeeze, tighten a quarter turn, squeeze...until it looks good.
The pattern on the vise grip jaws transfers to the rivet. If you don't want it to look like that you can file the jaws of a cheep pair smooth. Get a few solid rivets and give it a try. Its easy.
The small end of the unsqueezed rivet should extend 1-1/2 rivet diameter beyond the parts being riveted. Squeeze until it extends only 1/2 rivet diameter and it should be expanded about 1-1/2 rivet diameter.
Clear as mud?
Oh, and get a 100 degree countersink to make the countersink for the rivet head.
_________________ Tom Jones
Classic IV
Ellensburg, WA
Dan Stanton
Posted: Fri Feb 20, 2009 6:06 am Post subject: Re: New issue, turtle deck security |
Lynn,
Just go down to Fastenall on Page Ave and pick some up. If they don't have them on hand they will order them and have them in two days, max.
_________________ Dan Stanton
801 175 hrs.
701 95% done |
Tom Jones
Posted: Fri Feb 20, 2009 6:51 am Post subject: Re: New issue, turtle deck security |
| Quote: | | Okay, here is a few things I am hearing; solid rivets are easy to use, you do not need anchor nuts with nylon lock inserts, you do not need a screw every 2" as with the rivets. Is this all accurate for what everyone here is saying. |
You need a locking nut on the anchor so you don't have to tighten the screws too tight against the skylight. Stick with a screw every two inches.
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Fri Feb 20, 2009 8:52 am Post subject: New issue, turtle deck security |
Are we talking the 3/32" rivets, or the anchor nuts? I've kinda
forgotten about Fastenall, as the last 3 times I've gone there they
either don't have what I want or they need to sell you a crate of
whatever. While a crate of rivets isn't such a bad idea, a crate of
1/2-13's, 10 inches long might take a few airplanes worth of building
to use up. : )
I'll look into it, Dan....you got 125 hrs on the 801 already? time
for me to dust off the Kitfox, or you'll be catching me...hours that
is, no way in speed! : )
701...only another 80% to go....: )
Lynn Matteson
Sensenich 62x46
On Feb 20, 2009, at 9:06 AM, Dan Stanton wrote:
<daniel_stanton1(at)comcast.net>
Lynn,
days, max.
Dan Stanton
801 125 hrs.
701 80% done
http://forums.matronics.com/viewtopic.php?p 31200#231200
N369LM |
Lynn Matteson
Posted: Fri Feb 20, 2009 10:21 am Post subject: New issue, turtle deck security |
Ok, Guy, I guess you have to be an engineer to solve the code on
those rivets. It says on the Skygeek page "near the bottom of page"
100° flush head, but what size? None of the six offered has a size
printed on the item, and a click on "description" (on the other type
of rivets) gives less information than the one-line
description...which is no description at all. The
recreationalmobility site was even worse...no description
whatsoever...no legend for figuring out the code for a "ccr-264-
ss-3-3" .
I'm just a shade-tree mechanic working with a Mac, so maybe I need
help....no further comment on that comment is required. : )
Lynn Matteson
Sensenich 62x46
N369LM |
Guy Buchanan
Posted: Mon Feb 23, 2009 12:09 am Post subject: New issue, turtle deck security |
At 10:18 AM 2/20/2009, you wrote:
| Quote: | I'm just a shade-tree mechanic working with a Mac, so maybe I need
help....no further comment on that comment is required. : ) |
Sorry Lynn. I was in a bit of a rush. My house is in some disarray as we move the kid's rooms around so I couldn't find my Cherry catalogue. Some digging revealed the following:
CCR 264 SS -3 -3 is a Cherry Nut Plate Rivet. The codes mean the following:
-3 = Grip Length (maximum grip in 1/16 inch increments)
-3 = Diameter Dash Number (in 1/32 inch increments)
SS - Material Code (in this case 1018 steel)
264 - Head Style (in this case 100 degree flush head)
CCR - Cherry's Basic Part Number (Inch)
My source is: http://www.cherryaerospace.com/files/pdf/catalog/CA-1036.pdf
So the rivets I referenced were all steel 100 degree flathead 3/32 diameter pops in various lengths.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Mon Feb 23, 2009 5:52 am Post subject: New issue, turtle deck security |
Thanks for the followup, Guy. That site you mentioned for the Cherry
Rivets is a treasure trove of info about rivets, and a code-breakers
bible. : ) Now all we need is to find a supplier who is just a bit
lower in standards than Cherry, and will supply an aluminum rivet
with steel mandrel, in various lengths. By the way, it's important to
remember that the first "3" in the code is diameter, and the second
"3" (in your example) is length. Nice to see that if a person was
willing to use the steel-steel (material code SS)
that those ARE available in a 5/16" length and shorter. Maybe I'm
being too anal in thinking that an all-steel rivet is too strong to
use when the base material is wood. Although in the case of the wing
rib cap strips, that wood is pretty tough stuff, and would probably
handle steel rivets, but I still stand by my caution to not use
stainless-stainless rivets, as I feel these are just too strong for
the wood environment. The installation of SS rivets in my firewall...
30-some altogether?...was enough to convince me that those things are
strong!
Lynn Matteson
Sensenich 62x46
Status: flying
following:
CA-1036.pdf
Guy Buchanan
San Diego, CA
www.matronics.com/contribution _-
N369LM |
Tom Jones
Posted: Mon Feb 23, 2009 7:20 am Post subject: Re: New issue, turtle deck security |
Lynn Mattison wrote,
| Quote: | The installation of SS rivets in my firewall...
strong! |
Not to mention the wings, 324 stainless rivets in each wing. That brings back memories of tired hands.
do not archive.
Classic IV
Ellensburg, WA |
Guy Buchanan
Posted: Mon Feb 23, 2009 8:29 am Post subject: New issue, turtle deck security |
At 05:51 AM 2/23/2009, you wrote:
| Quote: | Maybe I'm
I used them to attach my floating nut plates that hold my skylight to
the butt rib cap strip. They are countersunk into the wood and went
in with no problem, with not even a hint of stress to the wood.
Though they are steel they are nothing like stainless pops you might
be used to; they're very easy to install. (After all, they're only 3/32 OD.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Leon Morris
Joined: 31 Jan 2009 Posts: 10 Location: Flower Mound, Texas
Posted: Mon Feb 23, 2009 8:51 am Post subject: New issue, turtle deck security |
O.K., let me get this straight, you need a locking nut on a anchor? I thought an anhcor nut was a locking nut. That's all that holding my wing tips on, just anchor nuts and screws. Leon Morris/Classic 4 Sptr/65%/ Flower Mound,TX
---- Tom Jones <nahsikhs(at)elltel.net> wrote:
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 31207#231207
_________________ Leon Morris/Classic 4 Speedster/65%/Flower Mound,TX |
Lynn Matteson
Posted: Mon Feb 23, 2009 9:35 am Post subject: New issue, turtle deck security |
I think what Tom meant is that you need the anchor nut to have a self-
locking feature, such as the "squeezed nut" in the all-metal anchor
nuts, K1000, MK1000, K2000, MK2000, or K3000, or the elastic-insert
locking device as in the AN366F, NA17, or NA5's as seen in the Spruce
catalog.
Lynn Matteson
Sensenich 62x46
Status: flying
On Feb 23, 2009, at 11:50 AM, <l.morris(at)tx.rr.com> wrote:
> every two inches.
> Tom Jones
> Classic IV
> 503 Rotax, 72 inch Two blade Warp
> Ellensburg, WA
N369LM |
Leon Morris
Posted: Mon Feb 23, 2009 9:55 am Post subject: New issue, turtle deck security |
OK Lynn, that sounds better and makes sense to me now-- Leon
---- Lynn Matteson <lynnmatt(at)jps.net> wrote:
catalog.
Lynn Matteson
Sensenich 62x46
Status: flying
>> every two inches.
>> Tom Jones
>> Classic IV
>> Ellensburg, WA
Float Flyr
Posted: Mon Feb 23, 2009 8:35 pm Post subject: New issue, turtle deck security |
I'm not sure but aren't the Aviex rivets used by Zenith steel core aluminium
rivets? I remember reading somewhere that There is two manufacturing plants
and Zenith only buys from one.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
