Lynn Matteson
Posted: Sat Feb 21, 2009 9:51 am Post subject: new bush gear |
I got mine from the Matco booth at Oshkosh....about $25-35 as I
recall. You CAN check the fluid level, but it's harder than just
looking. I use the 3/16" (I think) allen wrench that removes the top
plug. I wrap a short length of tape around the wrench at the
1/2" (from the top) mark...you could also grind a suitable mark on
the wrench to indicate the proper level.
In response to someone who said it's hard to tell when you are going
to overflow the reservoir during bleeding, I counted the pumps that
it took (during bleeding) to get from empty to near the top of
reservoir, and kept checking. When I finally had a number of strokes
it took to get close, I would always stop just sort of this number,
and then suck out all the fluid and begin pressure-bleeding again
until the lines were full. When full and brakes firm, add enough
fluid to 1/2" mark and close it up. Never a drop of spillage, but
certainly the clear reservoir would make life a lot simpler.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis off last week...5 minutes, and probably back on this week...
10 minutes, as it's snowing right now.
On Feb 21, 2009, at 12:28 PM, patrick reilly wrote:
| Quote: | Lynn And Dick, Where do you get the visable reservoir? I thought it
was odd that you can't check brake fluid level on the stock system.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> From: lynnmatt(at)jps.net
> Subject: Re: new bush gear
> Date: Sat, 21 Feb 2009 07:04:46 -0500
> To: kitfox-list(at)matronics.com
> Dick, I have no doubt that yours is in the right place...re-read my
> post. It was in response to Noel, who was responding to Francisco,
> whose plane was the subject of much discussion a few weeks back,
when
> he sent pictures of his plane which looked like he had the gear in
> the wrong place.
> In looking at your pictures just now, it looks like they no longer
> put the front float brackets on the fuselage...yours has 3 on each
> side, as does Francisco's, while mine has 4.
> I too have one of those visible reservoirs...I bought it at
Oshkosh 2
> 1/2 years ago....some things just take a little longer to get
> installed....mine isn't yet! : )
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> New skis done and flying
> On Feb 21, 2009, at 6:16 AM, Catz631(at)aol.com wrote:
> > Lynn,
> > I assure you my gear is not mounted in the wrong place. The gear
> > leg is pretty much identical in build and shape to the original
> > Kitfox leg I took off. The wheel is in the same position it's just
> > a foot further out toward the wing tip so I have to stretch to put
> > my foot on it to get in the aircraft. I am a short guy. The gear
> > weight is just 4 lbs lighter and the spread 2 ft wider. I now have
> > a 6 ft spread vs the original 4 ft (actually 7 ft if you
measure to
> > the outside of the "kingfox" tires)
> > I am not too worried about weight and balance as the 4 lbs
> > difference will equal the 4 lbs of stuff I put in the panel!
> > I am waiting for the polyflow fittings to arrive from Spruce so I
> > can extend the brake lines.
> > Yesterday I installed the "visible reservoir" thick plastic brake
> > fluid reservoir that I obtained a while back. Now I will be
able to
> > see how much fluid is in the reservoir. This will be useful when
> > back bleeding for fill purposes. No more running over the top!
> > I am having a time painting the gear leg fairings! Call me the
> > "orange peel" king. I am using Poly Tone and have tried both
> > methods (primer dry and spraying a mist coat onto drying primer)
> > nothing seems to work. I might have to break down and order a
quart
> > of enamel from Spruce (so expensive for a small amount) I will
give
> > it another shot today.
> > Dick
> > Maddux
> > Fox
> > 4-1200
> > Rotax
> > 912UL
> > Pensacola,Fl
> > Need a job? Find an employment agency near you. _-
> > www.matronics.com/contribution _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Sat Feb 21, 2009 11:50 am Post subject: new bush gear |
I checked the last W&B Francisco sent and the new gear is actually 2 Lb per
main leg lighter. The weight on the tail wheel has increased from 15 lb. to
44 lb. tare. I have asked him to send his weight and the arm of his seat
and the arm of his wing tanks so we can figure out an operation envelope for
him. I expect if he is anything over 150 lb. the lightest load will be with
a CG of around 12 - 12.5 in. Gross should be around 14-15 in. that's a lot
better than it was. I'll bet he'll find it a lot better plane landing. Can
you imagine trying to recover from a stall in a plane with such a light
tail?
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
patreilly43(at)hotmail.co Guest
Posted: Sat Feb 21, 2009 12:06 pm Post subject: new bush gear |
Lynn C Thanks for info. Just ordered mine from Matco on the internet. $38 for the kit. It includes line and hardware to install. I think the modifications on my plane will make the damn think worth 25% more than any other 582 KF Mod 3's the way it stands now.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: lynnmatt(at)jps.net
Date: Sat C 21 Feb 2009 12:50:56 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
recall. You CAN check the fluid level C but it's harder than just
to overflow the reservoir during bleeding C I counted the pumps that
reservoir C and kept checking. When I finally had a number of strokes
it took to get close C I would always stop just sort of this number C
until the lines were full. When full and brakes firm C add enough
fluid to 1/2" mark and close it up. Never a drop of spillage C but
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 605 hrs
Sensenich 62x46
New skis off last week...5 minutes C and probably back on this week..
10 minutes C as it's snowing right now.
On Feb 21 C 2009 C at 12:28 PM C patrick reilly wrote:
> Lynn And Dick C Where do you get the visable reservoir? I thought it
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford C IL
> > Date: Sat C 21 Feb 2009 07:04:46 -0500
> > Dick C I have no doubt that yours is in the right place...re-read my
> > post. It was in response to Noel C who was responding to Francisco C
> > whose plane was the subject of much discussion a few weeks back C
> when
> > the wrong place.
> > In looking at your pictures just now C it looks like they no longer
> > side C as does Francisco's C while mine has 4.
> Oshkosh 2
> > Lynn Matteson
> > Sensenich 62x46
> > On Feb 21 C 2009 C at 6:16 AM C Catz631(at)aol.com wrote:
> > > Lynn C
> measure to
> able to
> quart
> give
> > > Dick
> > > Maddux
> > > Fox
> > > 4-1200
> > > Rotax
> > > 912UL
> > > Pensacola CFl
> ========== _-
> contribution_-
Lynn Matteson
Posted: Sat Feb 21, 2009 12:23 pm Post subject: new bush gear |
You may inspire me to install mine, Pat...but not as long as it's
this snowy and cold and blowing like it is...not too much fun in the
hangar these days. : )
Lynn Matteson
Sensenich 62x46
On Feb 21, 2009, at 3:05 PM, patrick reilly wrote:
| Quote: | Lynn, Thanks for info. Just ordered mine from Matco on the
stands now.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Date: Sat, 21 Feb 2009 12:50:56 -0500
> Lynn Matteson
> Sensenich 62x46
week...
> do not archive
thought it
system.
> > Pat Reilly
> > Mod 3 582 Rebuild
> > Rockford, IL
read my
Francisco,
> > when
gear in
> > > the wrong place.
longer
each
> > Oshkosh 2
> > > Lynn Matteson
> > > Sensenich 62x46
> > > > Lynn,
gear
original
it's just
to put
gear
now have
> > measure to
Spruce so I
brake
> > able to
when
primer)
> > quart
> > give
> > > > Dick
> > > > Maddux
> > > > Fox
> > > > 4-1200
> > > > Rotax
> > > > 912UL
> > > > Pensacola,Fl
> > ========== _-
> > contribution_-
contribution_-
N369LM |
Lynn Matteson
Posted: Sat Feb 21, 2009 12:25 pm Post subject: new bush gear |
As I see it, the 11 lbs he added to the previous 15 = 26, so the 18
lb difference had to come from the wheels now being a bit further
forward.
Lynn Matteson
Sensenich 62x46
2 Lb per
15 lb. to
his seat
envelope for
will be with
that's a lot
landing. Can
light
tail?
Noel
N369LM |
dcubj3(at)terra.com.br Guest
Posted: Sat Feb 21, 2009 1:08 pm Post subject: new bush gear |
Lynn, this is correct!!!
Original tailwheel weight: 15 lbs
With new "bush landing gear"
( Main wheel axle is 4" closer than datum )
New tailwheel weight: 33 lbs
MORE 11 lbs = 44 lbs
44 lbs is 5% of total weight (883 lbs), as your instruction " very useful
information"
Tks very much!!!
FD
www.dcubj3.com.br
146.71 KB |
12194 Time(s) |
148.11 KB |
12194 Time(s) |
145.28 KB |
12194 Time(s) |
147.54 KB |
12194 Time(s) |
Posted: Sat Feb 21, 2009 3:09 pm Post subject: new bush gear |
Mr. Noel:
With pilot e co-pilot I can use 80% fuel tank. equiv 80 litres only (not
total)
In this case, with 40 lbs of bagagge, total weight is almost 1.300 lbs
FD
www.dcubj3.com.br
Lynn
flight level from bottom door, yes!!
I add 11 lbs in tailwheel
With this, 5% of weight in tail, as I read in msg
Tks
FD
Float Flyr
Posted: Sat Feb 21, 2009 3:28 pm Post subject: new bush gear |
You're probably right I think he'll notice the handling on landing right
away.
Noel
Kitfox III-A
Fox5flyer Guest
Posted: Sat Feb 21, 2009 3:32 pm Post subject: new bush gear |
Patrick, at 25% you're probably doing as well as anyone here. The real down side is that a part of the 25% is also weight. So it goes...
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Float Flyr
Posted: Sat Feb 21, 2009 3:33 pm Post subject: new bush gear |
Have you flown it with the new wheels yet? What are your thoughts on it's
handling while landing? Better Elevator control?
Kitfox III-A
pulsair(at)mindspring.com Guest
Posted: Sat Feb 21, 2009 5:19 pm Post subject: new bush gear |
Dick,
Can you send me a photo of your door latching mechanism. Thanks. Jeff Classic IV KTZR
Posted: Sat Feb 21, 2009 5:47 pm Post subject: new bush gear |
Noel:
With this gear landing is perfect, like J3 (better)
Before change, landing was dangerous, now is great!!
Less weight, axle more closer than before (4 inches), 5% weight on tail
Landing become perfect!!!!
FD
www.dcubj3.com
Dick Maddux
Posted: Sun Feb 22, 2009 3:25 am Post subject: new bush gear |
Lynn
I do have the forth float bracket. The bush gear bolted to the two that the original did and the sweep forward is the same as the original gear (ie: the wheels are in the same position longitudinally)
Dick Maddux
Pensacola,Fl
Dick Maddux
Posted: Sun Feb 22, 2009 4:10 am Post subject: new bush gear |
Thanks for all your replies and suggestions!
I tried again yesterday to paint the fairings with PolyTone and I am going to abort this! Now they look like a moonscape! I am going by the auto parts store and get some paint remover and I will use enamel to paint the gear fairings.Who would think that after all the work installing my gear that simply painting the fairings would be such a pain in the butt! I want you guys to see what the fairings on the gear look like. They are really nice! Lowell did a fantastic and time consuming job of making these!
As to the cost of the gear, I will leave that to Lowell or John. Suffice it to say it was quite a bit cheaper than the Grove and a whole lot lighter! The Grove gear is a very fine gear and doesn't get any simpler but I was simply trying to save some money and keep the weight down as I am a lard a*s ! (getting much thinner though down 20 lbs , 20 to go to goal) Too many people want me to take them flying so I have to lighten up.
When I was a bit younger everyone at high school had a Cushman Eagle, I had a Lambretta. Later my first car was a Triumph TR3 everyone else had an American hot rod. So there you go.
I received my parts from Spruce so that I can extend the brake lines. Hopefully I can get the aircraft back together today.
Keep in mind that I have not moved or added any weight to my aircraft in relation to the new gear. I have simply bolted it on as it resides in the same place as the old gear. The only difference, other than design, is it weighs 4 lbs less.
I do have a BRS chute canister behind the pax seat which limits my baggage weight to 10 lbs but that was there when I bought the aircraft.
Dick Maddux
Pensacola,Fl
373.36 KB |
12168 Time(s) |
larry huntley
Posted: Sun Feb 22, 2009 4:55 am Post subject: new bush gear |
Dick,
Where did you get the gas springs on your doors? My original clips on the wings work well, but I think I would like to try those.
Thanx. , Larry
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Lynn Matteson
Posted: Sun Feb 22, 2009 6:03 am Post subject: new bush gear |
Thanks, Dick....in looking at both your pictures and Francisco's
pictures I got to thinking that there were no longer 4 sets of float
brackets, but then I looked closer at yours and saw the 4th set.
Lynn Matteson
Sensenich 62x46
Status: flying
On Feb 22, 2009, at 6:24 AM, Catz631(at)aol.com wrote:
| Quote: | Lynn
Dick Maddux
Pensacola,Fl
N369LM |
Float Flyr
Posted: Sun Feb 22, 2009 6:53 am Post subject: new bush gear |
Great to hear Francisco.. Keep reading the mail here you may be able to
help someone some day.
Noel
Kitfox III-A
shinco(at)bright.net Guest
Posted: Sun Feb 22, 2009 9:06 am Post subject: new bush gear |
Would Lowell's new gear fit a Kitfox 2 all so???I may too be interested
in a set...Steve Shinabery KF2 N554KF
Lynn Matteson
Posted: Sun Feb 22, 2009 2:16 pm Post subject: new bush gear |
Francisco-
I've lost track of what this plane is...Model IV, 5, 6, 7? The reason
I ask is because in viewing your W&B sheet...Noel forwarded it to
me....it shows the GC range for the planes that are either 1050 or
1200 lbs. Max. Gross Weight, and I would imagine that your plane is a
higher gross weight than either of these. If so, maybe the CG
envelope/range is different than the 10.2" to 16.0" that the form shows.
Lynn Matteson
Sensenich 62x46
Status: flying
On Feb 21, 2009, at 4:06 PM, Francisco Drovetta wrote:
| Quote: | Lynn, this is correct!!!
very useful information"
Tks very much!!!
FD
www.dcubj3.com.br
N369LM |
