locating the Flap Positioning System box and the Safety Tri
Tim Olson
PostPosted: Fri Feb 20, 2009 11:19 am    Post subject: locating the Flap Positioning System box and the Safety Tri Reply with quote
The Safety trim can go many places. Mine is under the panel.
The FPS mounts well on the inside of the tunnel wall.
Just make sure to tie up any wires so nothing can interfere
with the flap mechanism.
Bob and Karen Brown wrote:
Where have you been putting the FPS box? Unless you cut/splice the FPS
harness (which I really don’t want to do), it would seem it almost has
to go in the tunnel where the flap motor is. How about locating the
Safe trim box? If you can direct me to some sites that would have
photos of this, it would save a thousand words…
MauleDriver(at)nc.rr.com
PostPosted: Fri Feb 20, 2009 3:20 pm    Post subject: locating the Flap Positioning System box and the Safety Tri Reply with quote
Here's what I did with mounting it in the tunnel. Plenty of room in
there. The wires are run forward thru the tunnel. I used some tape
backed wire holders but they will be riveted.
 Filesize:  817.8 KB
 Viewed:  1568 Time(s)
 Filesize:  852.39 KB
