jimpuglise(at)comcast.net Guest
Posted: Tue Feb 17, 2009 7:21 am Post subject: Anyone have info how they mounted wing tip strobe power sup |
Ron-
Mine is on the bottom of the port access panel in the baggage bay. I ran irrigation tubing through the wings containing #18 wire for both the strobes and position lights. I did not want to mount something that weighed as much as the strobe controller in the wing. I have seen a few mounted directly to the spar with an access panel in the wing skin. I did not want to put another panel in the wing. The answer for you might be to use very light weight coaxial cable for the strobe portion with the shields well grounded and your controllers located on the port and starboard baggage bay access panels.
Jim Puglise
jan_de_jong(at)casema.nl Guest
Posted: Tue Feb 17, 2009 9:36 am Post subject: Anyone have info how they mounted wing tip strobe power sup |
Hi Ron,
I put a single strobe power supply on the outboard end of each spar with
an access hole below.
The strobes will be uncoordinated, but I keep the high voltage wires short.
Attached some pictures, quality soso.
Access holes are a little large, because my first plan was putting the
power supplies on the lids.
Power supply attachment using reduxed McMaster-Carr studs and bid.
Light fixtures attached with cut down studs reduxed only.
Jan de Jong
833.93 KB |
4567 Time(s) |
836.21 KB |
4567 Time(s) |
841.5 KB |
4567 Time(s) |
Hi Ron,
The other 3 pictures I thought to send.
Jan de Jong
910.3 KB |
4567 Time(s) |
936.11 KB |
4567 Time(s) |
984.19 KB |
4567 Time(s) |
rlborger(at)mac.com Guest
Posted: Tue Feb 17, 2009 2:20 pm Post subject: Anyone have info how they mounted wing tip strobe power sup |
Ron,
FWIW... Absolutely no noise problems with my Whelen strobe power supply (mounted on the baggage bay bulkhead below "D" door). Power supply is grounded. Strobe HV lines have shields grounded at the power supply end and strobe shields are connected through any connector in the link.
Also, I have the LED/Strobe heads on the Europa. The LEDs are VERY bright! Much brighter than standard incandescent lamps. Everyone who has seen the Nav lights on the aircraft in the air has commented on how bright they are.
Now I have a set of Nav/Strobe heads with incandescent lamps that I'll never use. Was going to put them on my Toot but have changed my mind. From now on, only LED units go on my aircraft!
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Feb 17, 2009, at 10:20, rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us) wrote:
Hi group
Thx. for the replies about strobe power supply positioning.
Jim:
"> Mine is on the bottom of the port access panel in the baggage bay. I ran
| Quote: | irrigation tubing through the wings containing #18 wire for both the
strobes and position lights. A I did not want to mount something that
weighed as much as the strobe controller in the wing."
That's exactly what I did, beautiful installation of my Kuntzleman power supply on the starboard baggage bay rib. When I tested, if there is an antenna cable (RG-400 or RG-142), radio or antenna within 8 feet of power supply, tick, tick, tick. Nothing I tried helps. Power supply is grounded. Supply lines are shielded, I tried no ground, ground on supply side and ground on power supply side. I tried wrapping power supply in 2 layers of aluminium foil figuring RFI leaking out of connectors, no joy grounded or un grounded. I tried wrapping antenna cable with aluminium foil, grounded and un grounded. i tried grounding antenna cable. Nothing works, have to turn squelch up where don't get what it is I want.
The only thing that helps is moving power supply at least 8 feet away. I hear from a local IA that Whelen is the only powers supply he uses because he had noise issues with others.
Kunzleman power supply is pretty small, 10 oz and each one uses ~ 1.5 amps. I have their combo LED/strobe heads already mounted.
When you test yours, let us know if you have good results.
My experience is pretty much identical to this builder:
http://home.hiwaay.net/~langford/antennas.html
Ron Parigoris |
fklein(at)orcasonline.com Guest
Posted: Tue Feb 17, 2009 4:45 pm Post subject: Anyone have info how they mounted wing tip strobe power sup |
On Feb 17, 2009, at 2:18 PM, Robert Borger wrote:
| Quote: | FWIW... Absolutely no noise problems with my Whelen strobe power
What is your set up for your antenna(s)?
Fred
A194
believed to be clean.
Posted: Tue Feb 17, 2009 7:53 pm Post subject: Anyone have info how they mounted wing tip strobe power sup |
Fred,
I have a Bob Archer Model 6 big E antenna in the tail with the coax
running forward to the center seam then down the fuselage port side
seam thence following the fuselage seam to the firewall.
I have an AAE VHF-5T mounted vertically on the port side window frame
down to the floor with the connector at the fuselage seam and the coax
running along the seam forward to the firewall.
I have two Bob Archer Model 7 "V" antennas for VHF Nav.
One mounted on the bottom of the fuselage aft of the baggage bay with
the coax running down the center line to the front of the lower
baggage bay where it turns port and runs up the fuselage to the seam
and then forward to the firewall.
The second is in the area over the baggage bay with the coax running
forward to the back door frame where it turns port and down to the
fuselage seam then forward to the firewall.
Finally, I have a Bob Archer Model 5 Transponder antenna mounted on
the port side of the balance arm containment with the coax running
down to the bottom and up the side of the fuselage to the seam and
All the antenna coax run down the port side fuselage seam All
electrical stuff runs down the starboard side fuselage seam. Not sure
all that is necessary, but it doesn't hurt either.
I have not had the opportunity to work with the VORs yet so I can't
say how that antenna arrangement works for sure.
I hope that helps.
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
On Feb 17, 2009, at 18:43, Fred Klein wrote:
> connector in the link (eg. fuselage to wings).
Fred
A194
Posted: Tue Feb 17, 2009 9:36 pm Post subject: Anyone have info how they mounted wing tip strobe power sup |
Bob...thanks for all this info...sounds like an exquisite
installation...I have a couple questions, inserted and indented below.
| Quote: | I have a Bob Archer Model 6 big E antenna in the tail with the coax
I take it the coax is on the centerline of the "roof" (not the floor)
of the fuselage.
| Quote: | I have an AAE VHF-5T mounted vertically on the port side window
frame down to the floor with the connector at the fuselage seam and
the coax running along the seam forward to the firewall.
ok
| Quote: | I have two Bob Archer Model 7 "V" antennas for VHF Nav.
Why two?...Are you running dual Navs? Are you IFR equipped?
(Note: The Aviator's Guide to GPS sez the FAA's phase-out of the
whole VOR/DME network is expected to be complete by 2010...or has
that been postponed?)
| Quote: | One mounted on the bottom of the fuselage aft of the baggage bay
with the coax running down the center line to the front of the lower
ok
| Quote: | The second is in the area over the baggage bay with the coax running
Is this antenna superimposed over the coax from the Big E?
| Quote: | Finally, I have a Bob Archer Model 5 Transponder antenna mounted on
ok
| Quote: | All the antenna coax run down the port side fuselage seam All
sure all that is necessary, but it doesn't hurt either.
better safe than sorry
| Quote: | I have not had the opportunity to work with the VORs yet so I can't
please let us know
| Quote: | I hope that helps.
indeed it does, especially for this RF-challenged guy...thanks again
Fred
A194
Posted: Wed Feb 18, 2009 1:58 am Post subject: Anyone have info how they mounted wing tip strobe power sup |
Hi Ron,
Don't even have an antenna yet so no results and still counting on luck.
From your link it would appear that the Kunzleman switching power
supply radiates some at radio frequencies.
You probably should determine whether that is your problem too.
Separation will help, orientation may help.
Jan de Jong
johnwigney(at)windstream. Guest
Posted: Thu Feb 19, 2009 8:18 am Post subject: Anyone have info how they mounted wing tip strobe power sup |
Dear Europaphiles,
I know that this may be a little late for those of you who have already
bought their strobe power units, but my installation works well without
any interference. I have Whelen equipment and I mounted an HTS power
supply at each wing tip. They are mounted on removable panels on the
bottom surface. There is a weight penalty of about 1 pound compared to a
single HDA power supply in the fuselage but all the high voltage cables
are short and at the tip. No problems.
Cheers, John
N262WF, mono XS, 912S
