Dave(at)AirCraftersLLC.co Guest
Posted: Sun Feb 15, 2009 7:29 pm Post subject: SilPruf window removal |
A few people have asked about removing a window that was installed with SilPruf.
The weatherman said this would be a good time to take the plane down for a few days, so I decided to replace our sun-damaged window.
I pulled a little plug of sealant out of the groove on the outside. I was able to pretty easily put a piece of .020 safety wire through the sealant from the inside and fish it out from the outside. Then I just pulled the wire around the perimeter of the window. It took 10 minutes to get the window out.
I cleaned up the old sealant with a scraper and some Scotchbrite, and installed the new window like the others.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
84.27 KB |
18456 Time(s) |
102.26 KB |
18456 Time(s) |
48.17 KB |
18456 Time(s) |
59.34 KB |
18456 Time(s) |
carl.froehlich(at)cox.net Guest
Posted: Mon Feb 16, 2009 7:17 am Post subject: SilPruf window removal |
Dave,
Did you use this on the windshield as well? Any photos?
Carl Froehlich
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor
Sent: Sunday, February 15, 2009 10:24 PM
Subject: SilPruf window removal
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
jdriggs49(at)msn.com Guest
Posted: Mon Feb 16, 2009 7:50 am Post subject: SilPruf window removal |
Any suggestions as to where to buy this stuff? Their web site wasn't very helpful. Thanks C Dan
Subject: RE: SilPruf window removal
Date: Mon C 16 Feb 2009 10:15:40 -0500
.ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.EC_EmailStyle17 {font-family:'Times New Roman' C'serif';color:blue;font-weight:normal;font-style:normal;text-decoration:none none;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Dave C
Carl Froehlich
Sent: Sunday C February 15 C 2009 10:24 PM
The weatherman said this would be a good time to take the plane down for a few days C so I decided to replace our sun-damaged window.
I cleaned up the old sealant with a scraper and some Scotchbrite C and installed the new window like the others.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville C CA
831-722-9141
831-750-0284 CL
See how Windows connects the people C informa/MRT/go/msnnkwxp1020093175mrt/direct/01/' target='_new'>See Now
Posted: Mon Feb 16, 2009 8:53 am Post subject: SilPruf window removal |
I didn't use it on the windshield because of the time involved in molding a joggle into the lower section. It could be done, but it would be a lot of work. I might consider it if I ever had to remove the windshield.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Monday, February 16, 2009 7:16 AM
Dave,
Carl Froehlich
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
I get if from these guys:
http://www.halowry.com/
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs
Sent: Monday, February 16, 2009 7:45 AM
Any suggestions as to where to buy this stuff? Their web site wasn't very helpful. Thanks, Dan
Date: Mon, 16 Feb 2009 10:15:40 -0500
.ExternalClass p.EC_MsoNormal, .ExternalClass li.EC_MsoNormal, .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass a:link, .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.EC_EmailStyle17 {font-family:'Times New Roman','serif';color:blue;font-weight:normal;font-style:normal;text-decoration:none none;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Dave,
Carl Froehlich
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
See how Windows connects the people, informa/MRT/go/msnnkwxp1020093175mrt/direct/01/' target='_new'>See Now [quote]
Posted: Mon Feb 16, 2009 10:06 am Post subject: SilPruf window removal |
Thanks!
Date: Mon C 16 Feb 2009 08:52:53 -0800
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass body.EC_hmmessage {font-size:10pt;font-family:Verdana;} I get if from these guys:
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville C CA
831-722-9141
831-750-0284 CL
Sent: Monday C February 16 C 2009 7:45 AM
Dave C
Carl Froehlich
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville C CA
831-722-9141
831-750-0284 CL
See how Windows connects the people C informa/MRT/go/msnnkwxp1020093175mrt/direct/01/' target='_new'>See Now | Quote: |
ttp://www.matronics.com/Navigator?RV10-List
ronics.com
ww.matronics.com/contribution
| Windows Live™: E-mail. Chat. Share. Get more ways to connect. Check it out. [quote][b]
Lenny Iszak
Posted: Mon Feb 16, 2009 10:15 am Post subject: Re: SilPruf window removal |
I just bought some on Amazon.com.
Lenny
Posted: Mon Feb 16, 2009 11:59 am Post subject: SilPruf window removal |
Is this stuff paintable? Dan
See how Windows connects the people C information C and fun that are part of your life. See Now
Posted: Mon Feb 16, 2009 7:10 pm Post subject: SilPruf window removal |
The instructions say no.
Sent: Monday, February 16, 2009 11:57 AM
Subject: RE: Re: SilPruf window removal
See how Windows connects the people, information, and fun that are part of your life. See Now [quote]
Lenny Iszak
Posted: Mon Feb 16, 2009 8:28 pm Post subject: Re: SilPruf window removal |
Dan,
Here's the Amazon link for Silpruf:
http://www.amazon.com/s/qid=1234844526/ref=sr_nr_seeall_2?ie=UTF8&rs=&keywords=silpruf&rh=i:aps,k:silpruf,i:tools
or you can get it here http://www.dkhardware.com/product-3620-scs2003-black-ge-silpruf-silicone-sealant.html for a couple dollars cheaper. I just trust Amazon a little more...
Lenny
Lenny Iszak
Posted: Tue Feb 17, 2009 9:02 am Post subject: Re: SilPruf window removal |
Dan,
You can get the silpruf in white, black, gray and bronze. I'm planning on using the black one like Dave did.
Before gluing the window in, you apply a very light coat on the glass where the window flange goes, and it will give it a uniform black color. Let that dry for a day and then you glue in the window.
I think it's worth getting the videotape from Airlinktech.
Looks like they sell the silpruf too, but they only have white and gray:
http://mall.igfarm.com/store/merchant.mv?Screen=CTGY&Store_Code=airlinktech&Category_Code=Supplies
I need to mention that i hate VHS. I needed to borrow a VHS player and then the tape was stuck, so i had to open it up and straighten out the guts inside before it would start playing...
Check out Dave's writeup about this at:
http://forums.matronics.com/viewtopic.php?t=39388
For what it's worth, Cirrus uses the aluminum color silicone on their windows.
Lenny
drfred(at)suddenlinkmail. Guest
Posted: Tue Feb 17, 2009 9:29 am Post subject: SilPruf window removal |
Danny;
I bought the black. It is not paintable. If I had to do it again,
paint a small ring of black at the edge where the silpruf meets the
fiberglass. It would help the painters get a crisper line . I really
like the way the windows came out. I think it makes for a very nice
installation. If you are going to paint before you fly, you could leave
out the last fillet until _after_ final paint. That way, you could get
the silpruf to cover the paint as it wraps over the edge of the
fiberglass. It would look really slick then.
Dr Fred.
Danny Riggs wrote:
| Quote: | Thanks for the link. I am doing the windows as soon as I get this
stuff in.
One more question..... there is a flange about 3/4" wide that the
plexiglass will sit on where the Silpruf will be bedded. Since
the Silpruf is white (I presume) what do you do about the white ring
that will be left around each pane where the Silpruf will show thru?
If it's clear then the pink canopy will show thru. Do you paint the
fiberglass first to eliminate this? I'm just trying to visualize the
procedure before applying the $18 per tube stuff. Thanks again, Dan
> Subject: Re: SilPruf window removal
> From: lenard(at)rapiddecision.com
> Date: Mon, 16 Feb 2009 20:28:19 -0800
> To: rv10-list(at)matronics.com
<lenard(at)rapiddecision.com>
> Dan,
> Lenny
> http://forums.matronics.com/viewtopic.php?p 30611#230611
Archive Search & Download, 7-Day Browse, Chat, FAQ,
Get more out of the Web. Learn 10 hidden secrets of Windows Live.
Learn Now
<http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns%21550F681DAD532637%215295.entry?ocid=TXT_TAGLM_WL_getmore_092008>
