daveleikam(at)wi.rr.com Guest
Posted: Sun Feb 15, 2009 6:38 am Post subject: Stock Lycoming |
I am close to ordering my engine. I originally wanted a BPE engine. In order to save $$ I am now leaning toward a stock XIO-540 and Hartzell prop combo from Van's. I am looking for opinions on this decision regarding engine reliability, LOP operation with Bendix injection system, smoothness and overall performance compared to the BPE or other engine shop engine. I will probably install an ElectroAir ignition with one mag. Thanks in advance for the input.
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
Kelly McMullen
Posted: Sun Feb 15, 2009 7:02 am Post subject: Stock Lycoming |
Hard to go wrong with stock. That doesn't necessarily mean factory
built via Vans. I'd guess that the authorized engine kit shops, like
Barrett and Aerosport and Mattituck could be pretty competitive on
price if you stay with stock components. It is the changing fuel
system, ignition, sump, compression ratio, etc that add to the bottom
line. I'd be inclined to pursue quotes from at least the two shops
closest to you on a real apples to apples comparison so you have
comfort with your decision.
I operate LOP frequently on my IO-360A1A with stock Bendix mags,
Bendix FI with stock injectors. Plenty smooth after I had prop
balanced. Not sure what you mean on performance. With stock setup you
should get 260hp, within +/- 5%.
While I think I want the cold air induction sump, I also realize it
entails extra work if I go that route. I'll try to get Bendix mags
instead of the stock Slick. That's about all the changes I'd go for.
The closer to stock you stay, the quicker you finish....but you
already knew that.
On Sun, Feb 15, 2009 at 7:36 AM, Dave Leikam <daveleikam(at)wi.rr.com> wrote:
| Quote: | I am close to ordering my engine. I originally wanted a BPE engine. In
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
A&P/IA, EAA Tech Counselor
KCHD |
carl.froehlich(at)cox.net Guest
Posted: Sun Feb 15, 2009 7:37 am Post subject: Stock Lycoming |
I went down the same road. I liked the BPA engine but the cost was $8K - $10K more than the deal you get at Van’s. Considering the marginal gain from the cold air induction, I decided BPA did not present a value for me.
I routinely run LOP above 6000’ in my RV-8A, IO-360 (O-360 back fitted with Air Flow Performance fuel injection) and dual electronic ignitions and the Hartzell blended airfoil prop. The engine runs significant cooler and smooth. I expect the same from the XIO-540 from Van’s. I recently completed RV-10 near me runs 20-30 degrees LOP, 176 kts TAS at 12 GPH. This is with a Van’s stock IO-540 (mags) and Hartzell prop.
Bottom line, you can get more engine if you want it – if you have no issue with cost and want to routinely feed it the fuel needed to get that margin of extra performance. For me, and what I want the airplane to do, the Van’s engine/prop deal is the value proposition.
Carl Froehlich
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Sunday, February 15, 2009 9:37 AM
To: RV-10 matronics
Subject: Stock Lycoming
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
AirMike
Posted: Sun Feb 15, 2009 8:54 am Post subject: Stock Lycoming |
You might want to wait for OSH in July/August. Mattituck and Vans always seem to have some kind of deal going the coincides with OSH. Last year Vans had a great deal on a prop/engine combo. I got a fair deal on a Mattituck at OSH 2007. Nice engine, and Mattituck claims a 2500 hr TBO on the TMX-IO540. They throw in the freight and even provided lift gate residential delivery at no extra charge.
_________________ See you OSH '18
Q/B - sold. |
noconwud(at)earthlink.net Guest
Posted: Sun Feb 15, 2009 9:29 am Post subject: Stock Lycoming |
Mike,
I've never been to OSH, but would love to go this year if I thought I could
get a really good deal on an engine. What was the price tag?
Andy
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27878 Location: Toledo Washington (KTDO) USA
Posted: Sun Feb 15, 2009 9:40 am Post subject: Stock Lycoming |
I can't offer any performance or reliability input at this point, but I can say that the customer service and quality of assembly from Aero Sport Power is excellent ( http://www.aerosportpower.com/ ). They delivered on time and as promised and the IO-390 they built is a work of art. I went with gloss black and chrome and she is a beauty!
Sue and Bart at ASP were great and emailed me photos of the build and break in processes along the way. The engine arrived in perfect condition in a very well constructed, plywood box. The 3-year warrantee from the first flight is also hard to beat.
Here is a link to all of the pictures I received from ASP and also some I took of the delivery:
http://www.mykitlog.com/users/category.php?user=dralle&project=638&category=2972
I also opted for an additional 10 hours of break in to get me past those initial, critical break in hours. The log book shows 11.5 hours of total run time. Also the peace of mind knowing that the engine is running great for that amount of time is comforting. The extra $1k was well worth the investment in my opinion. I won't have to sweat some extended taxi testing now...
Anyway, give Bart or Sue a call at ASP and talk to them about what they can build for you. Great people; great service; great product. http://www.aerosportpower.com/
RV-8 #82880/N998RV
Wiring...
At 07:36 AM 2/15/2009 Sunday, you wrote:
| Quote: | I went down the same road. I liked the BPA engine but the cost was $8K - $10K more than the deal you get at Van’s. Considering the marginal gain from the cold air induction, I decided BPA did not present a value for me.
Carl Froehlich
>To: RV-10 matronics
>Dave Leikam
>RV-10 #40496
>N89DA (Reserved)
>Muskego, WI
134.99 KB |
15528 Time(s) |
146.05 KB |
15528 Time(s) |
130.82 KB |
15528 Time(s) |
167.67 KB |
15528 Time(s) |
_________________ Matt Dralle
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Sun Feb 15, 2009 1:02 pm Post subject: Stock Lycoming |
.. or talk to any number of equally good US based companies and keep the dollars here. I did find when I was looking at engines that the key really is apples to apples comparison. Some throw in services that others charge for like balancing. If you change one component you need to make sure it's the same with everyone. Same thing with the prop, Jim Ayres is great to work with and matches Van's prices. He gave me a really good deal on a new MT that someone ordered and changed their mind on.
The Van's combo deal is a good price and I don't believe that anyone can beat it flat out, but don't expect to change or customize anything. If you want to switch out one component here and there talk to the other shops and you may find they are competitive after having to order the extra components you want. If you really want to save $$ go with a rebuilt for now and a used prop. Oh, and you don't need to actually be at OSH or anywhere else for their "deals", they take the orders like usual and the last couple times they had way more than they actually advertised. It's the old "we only have a couple left so you better order now" sales pitch.
Michael
dlm46007(at)cox.net Guest
Posted: Sun Feb 15, 2009 2:14 pm Post subject: Stock Lycoming |
It all depends whether a builder wants to experiment and build or fly. One
of my buddies has suggested that the RV10/IO540/Hartzell Prop takeoff is
like a cat shot; another just likened it to pedal down on his corvette. I
have nothing against experimenting but recognize that every change you make
from the original plans require adjustments and time to accomplish them. For
me it is the Van's IO540/blended prop. It goes like a bullet but when you
see the fuel flow on takeoff at 22 gal/hr, its time slow down and lean.
robin1(at)mrmoisture.com Guest
Posted: Sun Feb 15, 2009 2:43 pm Post subject: Stock Lycoming |
Dave & I have spoken off line about engine choices. I am VERY pleased
with my BPE engine but it does have a few "extras" vs. the stock Vans
engine. That being said I don't think the base BPE engine was anywhere
near $8-10K more that Vans. In fact I doubt my final engine with cold
induction, custom paint, 9:1 and extra bench break in time was close to
the numbers quoted. Of course I purchased the unit "pre-depression" so
maybe I wasn't looking as hard at some of the invoices. I think the key
as mentioned earlier is comparing apples to apples. In the end I paid a
fair price for a very strong performing engine. BPE went out of their
way to deliver exactly what I wanted at a good price (when considering
we are talking AVIATION). I personally would not change a thing on my
front end (BA Prop). That being said I doubt you can go wrong with 2 or
3 other builders mentioned earlier. Properly flown only time will tell.
http://www.painttheweb.com/rv-10/engine.htm
Robin
Do Not archive
Tim Olson
Posted: Sun Feb 15, 2009 5:59 pm Post subject: Stock Lycoming |
Hundreds of hours running LOP on my Bendix system and all is well.
There are some things you can do to better balance your injectors,
and some places will work with you on it. Bart at Aerosport
has always had an open offer with me to swap injectors to balance
the fuel flows as best I can. He balanced them originally.
They have worked so good I haven't yet taken the time to see
how much more perfect I can get them. It runs really well
LOP.
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
bkbrown(at)minetfiber.com Guest
Posted: Mon Feb 16, 2009 12:33 am Post subject: Stock Lycoming |
How many degrees lean of peak do you normally run at in typical cruise
settings? An example of fuel flow would be helpful. On my 7 for instance, I
typically lean to a fuel flow (say 7.5 gph) at a given cruise power setting
and density altitude, knowing that particular fuel flow will put me 40 or 50
degrees LOP. It's a quicker setup than trying to lean to a specific LOP
number. I was just wondering how many degrees LOP you end up at. It's cool
that your temps (and by inference, your fuel flows) are balanced at those
LOP settings.
Tim Olson
Posted: Mon Feb 16, 2009 5:04 am Post subject: Stock Lycoming |
I try to get the power set to 65% or less, then I lean to at least
25 degrees LOP on the richest cylinder (last to peak). So I may
have it set anywhere from 25-70 degrees LOP depending on the day.
You do feel the power come back if you take it further LOP than
necessary. But, I always lean using the EFIS as an initial starting
point, because then I don't have to worry so much about what
density altitude and conditions I'm in. I do try to avoid EGT's
that stretch too far above 1400, so if that means leaning to
40 or 60 LOP on a particular day, I usually do, and typically
I end up with maybe one or two that are pretty close to 1400.
Considering that I don't run LOP under about 7,000', my fuel
flows are almost always 10gph or less....maybe 10.5 max, but
I don't see that often. Usually 10.1 down into the 7's, depending
on altitude. Common would be 8.5-10gph, as I don't get up in that
14,000-15,000' range too often. At altitudes running 10gph
or so, I may commonly see 160-165kts TAS. If I'm leaner than
normal, or higher, I can get down even to 155kts TAS or
anywhere in that 154-165kt range. It's always an easy 3gph or
more less than if I were running ROP, and generally costs me
somewhere around 8 kts. The range stretches incredibly though,
and I flight plan 160, and use the added range I get with LOP
to give me fuel margins on my planned stops. It's really not
hard to have 4.5-5 hr legs running LOP, or even more. But,
you have to remember you're going to need higher flows once
you start down out of altitude. The temps are nice and cool
on the CHT's all the time running LOP. I would just lean to
a fuel flow, and once I'm set up, I do actually use fuel flow
to manage temps, but I'm hesitant to JUST use fuel flow because
there are just too many variables that affect it. I figure
with today's power in the EFIS's, I should use them. The Chelton's
have a great leaning tool built into the engine page.
LOP settings.
Kelly McMullen
Posted: Mon Feb 16, 2009 6:40 am Post subject: Stock Lycoming |
Hmm,
I guess I worry a bit less with my IO-360. I'll run LOP anytime above
4000 ft and 75% or less. I set the amount LOP based on power
generated. The closer to 75% the leaner I want to be, maybe 40 LOP. At
70% or less, I'll run between 0-10 LOP, because that is where my
engine runs smoothest, EGT and CHT temps are closest together. My
engine runs cool, often in the 280-290 range, rarely above 330 in
cruise. Only if EGT or CHT on a cylinder goes unexpectedly high will
I abandon LOP or go significantly leaner.
I don't worry about how high peak EGT goes, as I have never seen it
over 1500, and it isn't a limiting factor for normally aspirated
engines. Depending on OAT, peak may be anywhere from low to high
1400s.
With the normally aspirated engines, the red box is somewhat smaller
than for turbos, and you mainly are protecting against long term
impacts of high internal combustion pressures, rather than detonation
per se. From what I recall from Walt Atkinson of APS, they haven't
generated true detonation on a normally aspirated engine running 100LL
with stock compression ratios of 8.7 to 1 or less. I would guess you
would have to be more conservative with higher compression ratios.
Kelly
On Mon, Feb 16, 2009 at 5:59 AM, Tim Olson <Tim(at)myrv10.com> wrote:
KCHD |
jim(at)CombsFive.Com Guest
Posted: Mon Feb 16, 2009 6:48 am Post subject: Stock Lycoming |
Tim, You are so right about the EFIS systems and the amount of information they present. I am still learning about the engine and what is "Right". But the informationpresented is fantastic. At first it is overwhelming, but you soon learn what to look at and what to let the computer monitor for you.The Advanced Flight Systems EFIS also has a tool for leaning. It's easy to use. Based on what I have seen of the many EFIS systems, I just can't image anyone building and not going the EFIS route. There are many really fantastic systems out there.Is it time to do another "Poll" of the population and see what people are doing?Jim CombsN312F - Flying - Still in Phase I (32 hours)Do Not Archive--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>I try to get the power set to 65% or less, then I lean to at least25 degrees LOP on the richest cylinder (last to peak). So I mayhave it set anywhere from 25-70 degrees LOP depending on the day.You do feel the power come back if you take it further LOP thannecessary. But, I always lean using the EFIS as an initial startingpoint, because then I don't have to worry so much about whatdensity altitude and conditions I'm in. I do try to avoid EGT'sthat stretch too far above 1400, so if that means leaning to40 or 60 LOP on a particular day, I usually do, and typicallyI end up with maybe one or two that are pretty close to 1400.Considering that I don't run LOP under about 7,000', my fuelflows are almost always 10gph or less....maybe 10.5 max, butI don't see that often. Usually 10.1 down into the 7's, dependingon altitude. Common would be 8.5-10gph, as I don't get up in that14,000-15,000' range too often. At altitudes running 10gphor so, I may commonly see 160-165kts TAS. If I'm leaner thannormal, or higher, I can get down even to 155kts TAS oranywhere in that 154-165kt range. It's always an easy 3gph ormore less than if I were running ROP, and generally costs mesomewhere around 8 kts. The range stretches incredibly though,and I flight plan 160, and use the added range I get with LOPto give me fuel margins on my planned stops. It's really nothard to have 4.5-5 hr legs running LOP, or even more. But,you have to remember you're going to need higher flows onceyou start down out of altitude. The temps are nice and coolon the CHT's all the time running LOP. I would just lean toa fuel flow, and once I'm set up, I do actually use fuel flowto manage temps, but I'm hesitant to JUST use fuel flow becausethere are just too many variables that affect it. I figurewith today's power in the EFIS's, I should use them. The Chelton'shave a great leaning tool built into the engine page.Tim Olson - RV-10 N104CD - Flyingdo not archiveBob and Karen Brown wrote:> --> RV10-List message posted by: "Bob and Karen Brown"> <bkbrown(at)minetfiber.com>>> How many degrees lean of peak do you normally run at in typical cruise> settings? An example of fuel flow would be helpful. On my 7 for> instance, I> typically lean to a fuel flow (say 7.5 gph) at a given cruise power> setting> and density altitude, knowing that particular fuel flow will put me 40> or 50> degrees LOP. It's a quicker setup than trying to lean to a specific LOP> number. I was just wondering how many degrees LOP you end up at. It's> cool> that your temps (and by inference, your fuel flows) are balanced at> those> LOP settings.>> --
Tim Olson
Posted: Mon Feb 16, 2009 6:54 am Post subject: Stock Lycoming |
I agree totally. I am just pretty conservative and don't
fly for best speed...more for economy. I have 8.5:1 pistons.
I know I could push it a little more, but in general I figure
that if I do it how I am, I'm giving some pretty good margins
against any worry.
Kelly McMullen wrote:
Hmm,
1400s.
Kelly
Posted: Mon Feb 16, 2009 7:51 am Post subject: Stock Lycoming |
Considering all the usual variables, what kind of average range would you
say you get with the 10? Longest ever? Would you say having the cylinders
flow matched etc. has any affect on efficiency or LOP operation?
Dave L.
scottmschmidt(at)yahoo.co Guest
Posted: Mon Feb 16, 2009 8:19 am Post subject: Stock Lycoming |
At 12,500 (about 19 inches) I burn 9.2 gph running just as Tim mentioned.
My cylinder temps drop to 300 or less running this way.
Scott Schmidtscottmschmidt(at)yahoo.com
Sent: Monday, February 16, 2009 5:59:23 AM
Subject: Re: Stock Lycoming
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
[quote] --> RV10-List message posted by: "Bob and Karen Brown" <bkbrown(at)minetfiber.com (bkbrown(at)minetfiber.com)>
LOP settings.
Posted: Mon Feb 16, 2009 8:47 am Post subject: Stock Lycoming |
The GRT EFIS and engine monitor also have a LEAN function which show both graphically and in digital form the first and last cylinders to peak.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com
Sent: Monday, February 16, 2009 7:48 AM
Tim,
there.
Jim Combs
instance, I
setting
or 50
cool
those
LOP settings.
Tim Olson
Posted: Mon Feb 16, 2009 8:58 am Post subject: Stock Lycoming |
I don't know what I've used for a longest range so far. I think
somewhere in the 5 or 5.5 hour leg range, so maybe 750-800nm.
The plane is capable of more if you fly it higher. You'll find
great economies above 12,000', and really good ones between
8,000-12,000'. If a person had the want, it's not hard to do
OSH to Atlanta or more. I know Jesse has done something like
OSH to Florida, right Jesse? I myself have really never landed
with less than 12 gallons or so of fuel, so I don't push the
range as much as I could. If I had extended range tanks I'd
feel better about using up all 60 gallons, but I like knowing
that there is plenty of fuel, more than the legal reserves,
and I consider that at ROP settings....so 12 gallons is just
under an hour....or if you pull back the power, maybe a little
more than an hour. The RV-10 can cover a lot of ground in an
hour. I've often taken off and seen my range be 500-700nm,
but once I have reached cruising altitude (if it were higher),
and started leaning, the range pushes to over 1000nm with
reserves (at that fuel flow). Heck, think about it...at
8.5gph, you're looking at a 6 hour range with 1 hour reserve
at LOP settings, so you could do a 900nm leg if you wish.
I don't know if flow matched cylinders give all that much
benefit. My original ECI Titans had special valve cuts
and stuff done at Aerosport. The new ones I got after the
SB/AD came with a "venturi cut" valve or something like that.
Seems to me the cylinder run the same, and those are stock
ECI Titans. I've heard that the benefits are fairly
minimal on our Lycs. Now, flow matching the injectors
is another story. Bart did mine originally.
you say you get with the 10? Longest ever? Would you say having the
cylinders flow matched etc. has any affect on efficiency or LOP operation?
Dave L.
Dave(at)AirCraftersLLC.co Guest
Posted: Mon Feb 16, 2009 9:12 am Post subject: Stock Lycoming |
I have a stock IO-540 plus porting. LOP fuel flow varies between 10.5-11.0
at 8000 to 9.0-9.5 at 12000. TAS is always about 160 knots, maybe +/- 3
knots. Porting is supposed to get you about a 10% horsepower/effieciency
gain, but I can't say for sure I'm seeing that.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
