cookflys
Posted: Thu Feb 12, 2009 9:10 pm Post subject: Brake rotors |
I noticed that my model II Matco brakes has a rotor that has lighting holes drilled all over. The newer brake assembly that came off a model IV that I am installing does not. Has anybody heard if there has been a problem with the older rotors?
Charles Cook
N363KF 582
ATL
_________________ Charles Cook
Model II 582
#363 |
akflyer
Posted: Thu Feb 12, 2009 9:40 pm Post subject: Re: Brake rotors |
no problem. They came solid and people drilled them out to save weight. I have a set of each also. I used the drilled ones as they were noticeably lighter.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Fri Feb 13, 2009 6:04 am Post subject: Brake rotors |
My Model IV manual shows the lightening holes in the brake rotors to
be an owner-modified option. I did the drilling and cutting on mine,
and have had no problems whatsoever in over 600 hours.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 13, 2009, at 12:09 AM, charles cook wrote:
| Quote: | I noticed that my model II Matco brakes has a rotor that has
Charles Cook
N363KF 582
ATL
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Roger Lee
Posted: Fri Feb 13, 2009 7:09 am Post subject: Re: Brake rotors |
Matco as of recent has started to lighten up their brake systems. I believe this was due to several factors. One being the LSA Mfg's wanted lighter brakes for aircraft sold overseas. Their weight limit for the plane is 450Kgs instead of our 600kgs. This was an issue for Flight Design planes where these Mfg's count ounces and not lbs.. I am an OEM for Matco brakes. Also it would stand to make since that less material used in the entire Matco brake line products would add up to lowering cost. The older rotors were quite thick and heavy. Now many newer rotors are thinner and have debris/water removing groves cut in. In the last year they have done some redesigning. They have made a flange mount brake for the Flight Design round axle socket so it can be adjusted for toe-in and out plus camber. They have been great to work with.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
clint_bazzill(at)hotmail. Guest
Posted: Fri Feb 13, 2009 9:08 am Post subject: Brake rotors |
I also drilled and cut to save weight. With a 912UL had a hard time holding the airplane on runup. Did fast runups C bought new rotors C cut extra material on outside but drilled no holes. That worked with the 912UL and can hold my 912ULS now. With a 72 inch 3 blade prop and 912ULS a lot of thrust. Should be no problem with a Jabiru.
Clint
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: Kitfox-List: Brake rotors
Date: Fri C 13 Feb 2009 09:03:46 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
be an owner-modified option. I did the drilling and cutting on mine C
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 605 hrs
Sensenich 62x46
> Charles Cook
> N363KF 582
Lynn Matteson
Posted: Fri Feb 13, 2009 10:16 am Post subject: Brake rotors |
I don't know about that last statement, Clint....I was flying the
other day and I held the brakes as hard as I could and I couldn't
hold the Jabiru back. : )
Lynn Matteson
Sensenich 62x46
On Feb 13, 2009, at 12:07 PM, Clint Bazzill wrote:
| Quote: | I also drilled and cut to save weight. With a 912UL had a hard
time holding the airplane on runup. Did fast runups, bought new
rotors, cut extra material on outside but drilled no holes. That
Jabiru.
Clint
N369LM |
Posted: Fri Feb 13, 2009 11:37 am Post subject: Brake rotors |
I have flown in Jabiru 2200 and 3300 powered airplanes. The thrust at take off with a 62 inch wooden prop is nothing like a 912ULS with 3 blades 72 inch. Believe me.
Clint
Date: Fri C 13 Feb 2009 13:15:12 -0500
I don't know about that last statement C Clint....I was flying the
Lynn Matteson
Sensenich 62x46
> Jabiru.
Lynn Matteson
Posted: Fri Feb 13, 2009 12:03 pm Post subject: Brake rotors |
I understand, Clint, and I believe you. But re-read my post....pay
particular attention to the words "was flying"....that's the key here
to my little joke. : )
Lynn Matteson
Sensenich 62x46
On Feb 13, 2009, at 2:36 PM, Clint Bazzill wrote:
| Quote: | I have flown in Jabiru 2200 and 3300 powered airplanes. The thrust
Clint
> Subject: Re: Brake rotors
> Date: Fri, 13 Feb 2009 13:15:12 -0500
> To: kitfox-list(at)matronics.com
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> do not archive
> > Jabiru.
contribution_-
N369LM |
Posted: Fri Feb 13, 2009 12:17 pm Post subject: Brake rotors |
I guess that is what it is.
Clint
Date: Fri C 13 Feb 2009 15:02:23 -0500
I understand C Clint C and I believe you. But re-read my post....pay
Lynn Matteson
Sensenich 62x46
> Clint
> > Lynn Matteson
> > Sensenich 62x46
> > do not archive
> > > Jabiru.
> ========== _-
> contribution_-
jcrowder(at)lpbroadband.n Guest
Posted: Fri Feb 13, 2009 3:24 pm Post subject: Brake rotors |
Hey Lynn,
Were you on your skis? ;>)
Jim Crowder
[quote] --
Lynn Matteson
Posted: Fri Feb 13, 2009 6:28 pm Post subject: Brake rotors |
Yes, I was....hey! maybe that's the reason I couldn't stop in mid-
air....my skis were skidding over the clouds! Well, no freakin'
wonder.....
Lynn Matteson
Sensenich 62x46
On Feb 13, 2009, at 6:21 PM, Jim Crowder wrote:
<jcrowder(at)lpbroadband.net>
Hey Lynn,
Jim Crowder
N369LM |
Lynn Matteson
Posted: Fri Feb 13, 2009 8:04 pm Post subject: Brake rotors |
Ooops......hey, Snakeman, better dust off one of those "humorless
darwin awards"...I think we have a candidate.
Lynn Matteson
Sensenich 62x46
On Feb 13, 2009, at 3:16 PM, Clint Bazzill wrote:
| Quote: | I guess that is what it is.
Clint
> Date: Fri, 13 Feb 2009 15:02:23 -0500
here
> Lynn Matteson
> Sensenich 62x46
> do not archive
> > Clint
the
couldn't
> > > Lynn Matteson
> > > Sensenich 62x46
> > > do not archive
new
That
inch 3
with a
> > > > Jabiru.
> > ========== _-
> > contribution_-
contribution_-
N369LM |
akflyer
Posted: Fri Feb 13, 2009 9:39 pm Post subject: Re: Brake rotors |
| Lynn Matteson wrote: | Ooops......hey, Snakeman, better dust off one of those "humorless
Lynn Matteson
Sensenich 62x46
Me thinks some one is trying to get me black listed again.... I nibbled, but ya didnt get me to swallow the hook.
Who am I kidding.....
You sir, have just been nominated, seconded and now handed out..
wait for it
A humorless Darin award.
as you are still breathing, this one is just for killing humor, in a unique way.
who wants one in 2010
Snake
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
patreilly43(at)hotmail.co Guest
Posted: Sat Feb 14, 2009 12:48 am Post subject: Brake rotors |
Chuck C The lightening holes in the rotors is an owner install option. It is described in my model 3 assembly book. The original owner / builder did not drill the rotors. I drilled them in my rebuild. Could be wrong but C I don't believe you will find any of the OEM rotors already drilled. Automotive race applications all use cross drilled rotors with much greater forces applied to the rotors. Should be fine on a KF.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Lynn Matteson
Sensenich 62x46
> Charles Cook
> N363KF 582
> ATL
_-===============================================
&g=======
Lynn Matteson
Posted: Sat Feb 14, 2009 3:48 am Post subject: Brake rotors |
I offer the following as a substitute for a NASA Form 277 (get out of
jail free)...Snake will know what I mean....and maybe Guy will too. : )
Charles-
Here is what the lightened rotors look like....as you can see, just
cutting off the material that just goes along for the ride quite a
bit of relative weight is saved. I weighed mine at the time of the
operation, and the original disc weighed 1#, 10 oz. and after
drilling and cutting weighed 13 oz., so the weight is cut in half.
For further lightening, you can drill the axles, also shown on the
original drawing in the builder's manual. I did this as well, and
saved a further 6 oz., but I didn't record at the time if this was
one axle or both...either way is wasn't much.
Lynn Matteson
Sensenich 62x46
came
> > Charles Cook
> > N363KF 582
> > ATL
436.66 KB |
14769 Time(s) |
N369LM |
Posted: Sat Feb 14, 2009 11:18 am Post subject: Brake rotors |
Lynn C I drilled mine. But C was wondering how you cut off the outside edge between the mounting tabs. Can't use a lathe C which I don't have anyway C because you'd cut off the tab also. I imagine I removed a little less than 1/2 the weight you did by removing the outside edge.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: lynnmatt(at)jps.net
Date: Sat C 14 Feb 2009 06:43:58 -0500
Charles-
Here is what the lightened rotors look like....as you can see C just
operation C and the original disc weighed 1# C 10 oz. and after
drilling and cutting weighed 13 oz. C so the weight is cut in half.
For further lightening C you can drill the axles C also shown on the
original drawing in the builder's manual. I did this as well C and
saved a further 6 oz. C but I didn't record at the time if this was
Lynn Matteson
Posted: Sat Feb 14, 2009 1:20 pm Post subject: Brake rotors |
As you can see by the picture, I drilled a large...can't recall the
size, maybe 7/16"... hole so that the edge was tangent to what would
become the new outer diameter of the rotor proper, then bandsawed the
rest of the material away. Previously, I had "painted" the whole
rotor with Dykem blue layout dye, and marked out each hole and cut-
line with a scribe. Then it was just a simple matter of doing the
drilling and the sawing....pretty standard metal-removing tactics for
a home shop...with a bandsaw, of course. Any local machine shop could
do it if you don't have the saw.
Lynn Matteson
Sensenich 62x46
On Feb 14, 2009, at 2:17 PM, patrick reilly wrote:
| Quote: | Lynn, I drilled mine. But, was wondering how you cut off the
outside edge between the mounting tabs. Can't use a lathe, which I
don't have anyway, because you'd cut off the tab also. I imagine I
outside edge.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
N369LM |
Posted: Sat Feb 14, 2009 2:25 pm Post subject: Brake rotors |
Lynn C OK C thanks for the info. I have a craftsman 12" bandsaw I use on wood and occasionally aluminum. I don't think it is powerful enough to cut steel 1/4" thick. What bandsaw and blade did you use? I drilled mine after laying out per builders manual similar to you. If I take my wheels off and have the time I will either buy a bigger bandsaw or lay it out C drill the holes and have a machine shop saw off the outer rim.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Sat C 14 Feb 2009 16:19:45 -0500
As you can see by the picture C I drilled a large...can't recall the
size C maybe 7/16"... hole so that the edge was tangent to what would
become the new outer diameter of the rotor proper C then bandsawed the
rest of the material away. Previously C I had "painted" the whole
rotor with Dykem blue layout dye C and marked out each hole and cut-
a home shop...with a bandsaw C of course. Any local machine shop could
Lynn Matteson
Sensenich 62x46
> outside edge.
> Pat Reilly
> Mod 3 582 Rebuild
_=====
Lynn Matteson
Posted: Sat Feb 14, 2009 3:54 pm Post subject: Brake rotors |
Pat-
Don't even try to use a wood bandsaw for steel unless you can reduce
the speed from the wood speed of approximately 2500 blade-feet-per-
minute, to about 675 bfpm for the steel. Then you need to use at
least a "general use" saw blade with (at the least) about 18 teeth-
per-inch (TPI). I have an old Delta bandsaw that has a speed reducing
gearbox, and that's about the only good way to get the blade speed
reduced. You can try to make a jackshaft for your machine, but it
takes some pretty big...and small...pulleys to get the speed down to
where it is safe to cut steel. And the blade needs to say on the
package that it's for steel...it will have the aforementioned fine
teeth, and a blue color. There should always be at least two teeth in
contact with the metal at any time during the cutting.
Lynn Matteson
Sensenich 62x46
On Feb 14, 2009, at 5:24 PM, patrick reilly wrote:
| Quote: | Lynn, OK, thanks for the info. I have a craftsman 12" bandsaw I use
bigger bandsaw or lay it out, drill the holes and have a machine
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
contribution_-
N369LM |
edgraydallas
Posted: Sun Feb 15, 2009 9:17 am Post subject: Brake rotors |
Lynn and Patrick, I would remove the outer rim of the rotors by making 4 or 5 radial cuts with an angle grinder and cutoff wheel, up to the outer radius desired for each segment to be removed (like slicing a pie). Then lop of the segments with the cutoff wheel and round off the circumference with a grinder wheel on the same machine and dress with a file. No need for a band saw here. I didn’t bother because the weight savings seemed small, but next time the rotors are off I will. I also drilled my axles one inch and tapped them for a 5/16 bolt for future wheel pants. Then I made a C shaped clip out of thick steel wire to pin the axle bolt and eliminate the cotter. Now I can drill the axle dust caps, and install a stud to stabilize the pants. I want to fly it a bit before adding the wheel pants. Got the engine and radiator in this weekend. I vented the cylinder head into the water line exiting the head above the oil pump since my water fill tank has no nipple. Any 582 guys see any problem with this? I also didn’t like the use of only three bolts for the exhaust manifold, so I put short studs in the upper inside holes and can put nuts on it by tightening the two nuts gradually as the manifold goes on. I had to grind a little weld material from the flange so the nuts are seated flush. Worked great.
I am now debating whether to add a Hacman control before completion. Any comments about this decision are welcome.
Ed Gray, KII, 582 building, Dallas , do not archive
