Riveting spar caps
dougsire
PostPosted: Thu Feb 12, 2009 8:15 am    Post subject: Riveting spar caps Reply with quote
For those scratch builders out there, what did you use to drive the 5/32" and 3/16" AN470AD rivets in the main spar caps? I'm considering using 5/32" solid rivets in some places and am not sure my rivet gun skills will be predictable enough to assure that I don't mangle some costly 6061-T6. The hand rivet squeezers (and even mildly affordable pneumatic ones) only seem to be able to handle up to 1/8" dia rivets.
Doug Sire
601XL => CH650
Doug Sire 601XL
larry(at)macsmachine.com
PostPosted: Thu Feb 12, 2009 1:18 pm    Post subject: Riveting spar caps Reply with quote
Doug,
I used a 3-lb sledge and a flat end punch with a radius die on the
resting side. This only lasted a short dozen rivets and I bought an air
gun that had the proper
dies for the same applied setup less the sledge. Went much more
smoothly, but always recommend you make a sample piece up with 20 rivets
in it to get the idea
first. Suggest this as best way to keep from dinging good surfaces the
wrong way. That's easy to do too. Air power is much easier to control
with practice.
Doug Sire
601XL => CH650
Doug Sire 601XL
http://forums.matronics.com/viewtopic.php?p 29966#229966
leinad
PostPosted: Thu Feb 12, 2009 4:43 pm    Post subject: Re: Riveting spar caps Reply with quote
Doug,
I made a very simple rivetting tool out of wood, a few bolts and piece of .5 ID tubing. It was the best 1 hour I've spent. I use it to rivet alls sorts of things. You use a half inch steel rod as the driver, and a hammer to set the rivets with. I did all my spar rivets with solid rivets (make sure to get the hardened ones). I'll post a picture. There are a lot more pictures on my website at:
http://daniel.dempseyfamily.us
Dan
Doug Sire
601XL => CH650
This is the rivet tool.
 Filesize:  32.66 KB
 Viewed:  8190 Time(s)
Ron Lendon
PostPosted: Thu Feb 12, 2009 6:06 pm    Post subject: Re: Riveting spar caps Reply with quote
I modified a 1 ton arbor press after seeing this picture in the photo archives:
http://www.matronics.com/photoshare/HeatonHE(at)aol.com.05.07.2006/Wing_Spar_3_001.jpg
Herb Heaton had this idea. I made some modifications using a rubber cushion to hold the metals together before the rivet tools contact the rivet. and using a 3 or 4 lb. rawhide hammer. No damage to the arbor press with the rawhide hammer faces, but I did wear out a set of hammer faces doing the center and both wing spars.
Search for spar in my kitlog to get some ideas.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
carlossa52(at)gmail.com
PostPosted: Thu Feb 12, 2009 7:21 pm    Post subject: Riveting spar caps Reply with quote
Ron, what's that I see on the workbench?!? The dreaded green unmentionable ?!
GASP!!!
Carlos
2009/2/12 Ron Lendon <rlendon(at)comcast.net (rlendon(at)comcast.net)>
[quote]--> Zenith601-List message posted by: "Ron Lendon" <rlendon(at)comcast.net (rlendon(at)comcast.net)>
Ron Lendon
PostPosted: Fri Feb 13, 2009 5:13 pm    Post subject: Re: Riveting spar caps Reply with quote
That's Herb's bench not mine. Must have been before the study. Laughing
Ron Lendon
CH 601 XLB
N601LT - Flying
Heatonhe36(at)msn.com
PostPosted: Fri Feb 13, 2009 5:53 pm    Post subject: Riveting spar caps Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I should have printed the picture in black and white, then nobody would have noticed. It's all Aluminum oxide anyway.
Herb
