Outrigger mod.
acrojim7534(at)YAHOO.COM
PostPosted: Mon Feb 09, 2009 2:42 pm    Post subject: Outrigger mod. Reply with quote
Several years ago there was a mod from one of the builders, which consisted of stainless steel tubes,and some washers and grease fittings.This mod would eliminate the side to side play that occurs with useage of the outrigger legs on the monowheel. These tubes were used to take out the loose play on the bolt that the outrigger pivioted on.
Over time and 800 hours the bolt has worn the aluminum sideplates to where there is a fair amount of sideplay in the outrigger legs in my plane.
Does anyone have the instructions on how these stainless steel tubes are assembled on the outrigger ???
Jim Brown
Monowheel
N398JB
h&jeuropa
PostPosted: Tue Feb 10, 2009 4:54 am    Post subject: Re: Outrigger mod. Reply with quote
Hi Jim
The Mod is on the Europa Club website. It is Mod 10661 Version 2, May 2007. Version 2 changes the pivot bolt to AN5.
We've done this Mod and it works fine.
Jim & Heather Butcher
N241BW
Hoping for warm weather!!
