ChangDriver
Posted: Mon Feb 09, 2009 6:04 am Post subject: Blackwell Exhaust |
Is anyone out there flying either a Housai or M-14 with Bill's new tuned exhaust? I am wondering what performance increase you've seen AND what is the change in exhaust noise (how much louder is it).
Craig
MarkWDavis
Joined: 03 Jan 2007 Posts: 104 Location: Syracuse, KS
Posted: Mon Feb 09, 2009 7:53 am Post subject: Blackwell Exhaust |
My concern, after looking at the pictures of the system, on the typical
M-14P without gapless rings is the potential of a hydraulic lock on the
bottom cylinders that can't drain and puke out the occasional glug of oil
they all do when pulling them through. If it didn't cause a lock, the top
of the wings would have a nice slick black walkway after startup.
Mark Davis
N44YK
nigel(at)yakdisplay.com Guest
Posted: Mon Feb 09, 2009 9:18 am Post subject: Blackwell Exhaust |
That's why the oil drain kit is a must - AND it's also a must to be used
CORRECTLY!
i.e. Open after engine shutdown and LEAVE open. Only close after pulling
through before start.
MarkWDavis
Posted: Mon Feb 09, 2009 10:34 am Post subject: Blackwell Exhaust |
Nigel,
Even with the oil drain kit in the lower intake tubes opened up on
shutdown, I still get oil out of the stacks at times. That's the oil I'm
worried about backing up into the cylinders or blowing on top of the wing.
Exhaust side, not intake side. On the stock exhaust system any oil that
leaks down into a cylinder with an open exhaust valve can just let gravity
do its thing and run on out just like the oil does on the intake side with a
drain kit.
Mark Davis
N44YK
Posted: Mon Feb 09, 2009 11:35 am Post subject: Blackwell Exhaust |
Yes, so do I. That oil is from the inlets that can't be sucked up from the
inlets just by pulling through - so it gets pulled into the cylinders on
start. Because of the drain kit, (in theory) the amount of oil left in the
inlets is too small to hydraulic a cylinder.
Even if the oil backs up on the exhaust side, surely the pull through is
going to force it out of the cylinder via the exhaust valve exhaust anyway?
And then the exhaust valve closes stopping that oil coming back in. The next
stroke is induction (exhaust valve still closed), and the next compression
(still closed). The hydraulic lock only happens on the compression - so the
only way oil can come in for that is from the INLET side - hence the drains
being on the inlets.
Or am I missing something here?
Nigel.
tjyak50
Posted: Mon Feb 09, 2009 12:03 pm Post subject: Re: Blackwell Exhaust |
The Blackwell exhaust system has a drain built into it.
Any headers with a low spot are connected to the exhaust drains.
Different from the intake drain since it is high temp.
It prevents any oil from ever building up in the exhaust system.
T-28 has a similar system if I recall, although they just have holes in the exhaust. Blackwells system drains to a common point.
Actually makes the airplane very tidy.
Posted: Mon Feb 09, 2009 1:56 pm Post subject: Blackwell Exhaust |
All true Nigel. But what happens if the piston is already on the compression stroke while pulling the prop through and there is sufficient oil collected in the combustion chamber when the piston gets to close to TDC? Then it's too late for an opening exhaust valve to be of any benefit.
Dennis
ChangDriver
Posted: Tue Feb 10, 2009 11:10 am Post subject: Re: Blackwell Exhaust |
Are there considerations for having exhaust heat a) close to the firewall, b) exiting onto paint, etc. I can't imagine this is a good thing.
Dennis: if the engine is on the compression stroke, both valves are closed. So, on pull through, if oil were pulled in via the exhaust valve, wouldn't it get pushed out on the next phase of the cycle...intake.
Craig
Posted: Tue Feb 10, 2009 1:13 pm Post subject: Blackwell Exhaust |
Oil will not get pulled in via the exhaust valve. The intake stroke is suction. So oil can not get "pushed" out. However, if one feels the prop stop caused by a hydraulic lock, if you move the prop backwards and allow the intake valve to open on the locked cylinder (remember intake comes before compression), it can let the oil run out into the lower intake tubes which hopefully have the intake drain kit installed or just plugs installed in the intake tubes. Otherwise you really should pull the rear spark plugs on the lower cylinders to clear the lock.
Dennis
