AirMike
Posted: Wed Feb 04, 2009 12:23 pm Post subject: MT prop governor rotation - final position |
I need to position my MT prop governor to set the opening in the fwd baffle on the left front area of the engine. I know that you loosen the six screws that retain the governor arm. You only loosen the screws - DO NOT REMOVE. Then you can rotate the arm part of the prop governor. This related to me by Jurgen at MT.
Question: What is the final position of the arm on the MT prop governor?
It looks like the passive position of the arm should be in the 10:00 position as you look at it from the pilot side. Could anyone already flying please set me straight on this.........
_________________ See you OSH '18
Q/B - sold. |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Sat Feb 07, 2009 6:59 am Post subject: Re: MT prop governor rotation - final position |
| AirMike wrote: | I need to position my MT prop governor to set the opening in the fwd baffle on the left front area of the engine. I know that you loosen the six screws that retain the governor arm. You only loosen the screws - DO NOT REMOVE. Then you can rotate the arm part of the prop governor. This related to me by Jurgen at MT.
It looks like the passive position of the arm should be in the 10:00 position as you look at it from the pilot side. Could anyone already flying please set me straight on this......... |
Did you ever find out the starting 'clocking' position. I want to do this, this weekend also.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
AirMike
Posted: Sat Feb 07, 2009 9:52 am Post subject: MT prop governor rotation - final position |
I looked in my archives from OSH-08 and found some pictures that indicate that the arm should be in the 10:00-10:30 position. See my prior comments on rotation. You want the arm to be able to pull down without too much fore and aft movement on the bushing
One thing that this taught me was that my 200+ pictures of RV10's that I took at OSH were a real help in finishing this project. If you are a newbee, I cannot tell you how valuable the pictures that you take at OSH (of RV10's) are in finishing this plane
1.44 MB |
489 Time(s) |
Q/B - sold. |
AV8ORJWC
Posted: Sat Feb 07, 2009 1:20 pm Post subject: MT prop governor rotation - final position |
Deems and Tim are my baseline when it comes to thousands of pictures.
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of AirMike
Sent: Sat 2/7/2009 9:52 AM
Subject: Re: MT prop governor rotation - final position
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
OSH '08 or Bust (busted) be there in "09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p=229069#229069
http://forumhref="http://www.matronics.com/Navigator?RV10-List">http://www.matronic--> http://forums.matronics.com
p; - List Contribution bsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
orchidman
Posted: Sat Feb 07, 2009 3:13 pm Post subject: Re: MT prop governor rotation - final position |
| AirMike wrote: | | I looked in my archives from OSH-08 and found some pictures that indicate that the arm should be in the 10:00-10:30 position. |
A picture is worth a 1000 words. Thanks
RV10 - # 40674
(N2GB Flying) |
