ggower_99(at)yahoo.com Guest
Posted: Fri Feb 06, 2009 11:29 am Post subject: elevator pitch stability. |
All airplanes need to get used to their particular controls... Just practice a little, is part of the learning process.
Some can remember when power steering was first installed in cars, Most people thought that the low efort required to turn the steering wheel could make people over steer and send them out of the road at highway speeds, so they asked for normal steering in their new cars for years... Now almost all cars are power steering and automatic transmission
Saludos
Gary Gower
I rather park in a tight space with power steering...
--- On Fri, 2/6/09, annken100 <annken100(at)aol.com> wrote:
| Quote: | From: annken100 <annken100(at)aol.com>
Subject: Re: elevator pitch stability
Date: Friday, February 6, 2009, 10:49 AM
bryanmmartin
Posted: Fri Feb 06, 2009 12:05 pm Post subject: elevator pitch stability. |
It's not the amount of effort that causes a problem in most cases,
it's the amount of control travel. In a car, as long as the steering
wheel has to be moved the same amount to get the same deflection of
the front tires, there is no problem controlling the car. If you only
had to move the wheel half as far for the same deflection, that would
cause problems. As it is, nearly all cars are designed with about the
same amount of steering wheel travel. That makes it fairly easy to
switch from one car to another without a problem. That's a good thing,
since it seems that a lot of drivers can just barely walk and chew gum
at the same time.
There was a big problem with the early F-16 falcons. The airplane has
a fly-by-wire control system and, in the first few planes, the control
stick did not move at all, it just sensed the force applied to it to
determine how much control deflection to apply. Since the pilots had
no motion feedback from the stick they found it very difficult to
control the airplane. The stick was changed to one that could move a
small amount against spring tension. This gave the pilots enough
motion and force feedback to eliminate the problem.
On Feb 6, 2009, at 2:28 PM, Gary Gower wrote:
| Quote: | All airplanes need to get used to their particular controls...
transmission
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
