Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Tue Nov 20, 2007 3:10 am Post subject: Converting a 6 to a 6a |
On Sun, 2007-11-18 at 21:13 -0500, Jim Blake wrote:
| Quote: | Chuck, I have an RV6 under construction and am planning on changing
it
to a 6A. Per Van all that is needed is to change the engine mount and
gear. I have the mount and gear.
Do not overlook the comment on drawing 31 saying "Note: Install F-6101
instead of F-654 & F-655 if building the tri-gear."
Presumably the tri-gear is referring to the 6A ... !
I am surprised Vans did not mention this as it is a significant change.
Perhaps the -6 family has already fallen off their radar.
Doug Gray
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
Apik
Posted: Fri Feb 06, 2009 3:52 am Post subject: Re: Converting a 6 to a 6a |
The RV-6 made its first flight in 1985. When all the flight testing was done, Van was delighted to find that despite the wide fuselage, it was only three miles per hour slower than the RV-4! The handling qualities and STOL characteristics were so close that a pilot who could not see the altered visual picture caused by sitting off the centerline probably could not tell the RV-4 and RV-6 apart. ...here is my info about RV 6A
_________________ used rv sale |
wdleonard(at)gmail.com Guest
Posted: Fri Feb 06, 2009 8:15 am Post subject: Converting a 6 to a 6a |
In light of the rash of bent nose gear and flipped-over aircraft I just cant understand any reason for wanting to switch to tri-gear. [suspend tailwheel bravado] The RV-aircraft have got to be some of the tamest tail-wheel aircraft ever made. IMHO, the only detractor is the reduced visibility during taxi which is not a big deal. Benifits include better looks, better rough field performance, and a slight edge in speed. [resume tailwheel bravado]
Why would you ruin a perfictly good airplane with a training wheel?
David Leonard
Turbo Rotary RV-6 N4VY
http://N4VY.RotaryRoster.net
http://RotaryRoster.net
On Fri, Feb 6, 2009 at 3:52 AM, Apik <lily_f(at)auswww.com (lily_f(at)auswww.com)> wrote:
| Quote: | --> RV6-List message posted by: "Apik" <lily_f(at)auswww.com (lily_f(at)auswww.com)>
http://forums.matronics.com/viewtopic.php?p=228827#228827
Subscription,
://www.matronics.com/Navigator?RV6-List" target="_blank">http://www.matronics.com/Navigator?RV6-List
ref="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
p; -Matt Dralle, List Admin.
BSchroeder(at)rideuta.com Guest
Posted: Fri Feb 06, 2009 8:44 am Post subject: Converting a 6 to a 6a |
Too funny! However many bent nose gears there have been, there are only 2 kinds of tail wheel pilots. Those that have and those that will. (you know what I’m talking about) we have a local pilot that has 2 tail wheel aircraft and a tricycle gear bird. He ground looped one last fall and did the same with the other one a couple of weeks ago. So I think that I will continue my tricycle gear 6. Thank you very much. lol
From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of David Leonard
Sent: Friday, February 06, 2009 9:15 AM
To: rv6-list(at)matronics.com
Subject: Re: Re: Converting a 6 to a 6a
David Leonard
Subscription,
| Quote: | | http://www.matronics.com/Navigator?RV6-List | 0123456789
Posted: Fri Feb 06, 2009 9:56 am Post subject: Converting a 6 to a 6a |
Bob,
You will probably love the A version. I moved from a 4 to a 6A because I regularly fly into commercial airports and the thought of looping the plane and causing a commercial flight to have to go around regardless of zero damage to my aircraft was enough to make me look at the A’s. Yes the TW models look cooler and are SLIGHTLY faster and cost more to insure (whoops) but landing an A even in difficult conditions is a dream. I often look like a genius laying down my 6A as clean as can be imagined. I never had that feeling in my TW.
If you feel comfortable with a nose wheel (and your manhood) enjoy you’re A model.
Robin
www.painttheweb.com/rv-4 (sold)
www.painttheweb.com/RV-6A (500 hours)
www.painttheweb.com/RV-10 (in Paint Now)
Posted: Fri Feb 06, 2009 10:08 am Post subject: Converting a 6 to a 6a |
Yes, but how many RV aircraft do you know of that have groundlooped? Although I am sure there are many, I personally only know of 1. While I know of many flipped planes and bent nose forks. Perhaps it is because groundloops are usually relatively minor incidents that often don't make the RV news, but that is part of my point as well.
Either way, Good luck
David Leonard
On Fri, Feb 6, 2009 at 8:43 AM, Schroeder, Bob (Parts Clerk) <BSchroeder(at)rideuta.com (BSchroeder(at)rideuta.com)> wrote:
Too funny! However many bent nose gears there have been, there are only 2 kinds of tail wheel pilots. Those that have and those that will. (you know what I'm talking about) we have a local pilot that has 2 tail wheel aircraft and a tricycle gear bird. He ground looped one last fall and did the same with the other one a couple of weeks ago. So I think that I will continue my tricycle gear 6. Thank you very much. lol
From: owner-rv6-list-server(at)matronics.com (owner-rv6-list-server(at)matronics.com) [mailto:owner-rv6-list-server(at)matronics.com (owner-rv6-list-server(at)matronics.com)] On Behalf Of David Leonard
To: rv6-list(at)matronics.com (rv6-list(at)matronics.com)
David Leonard
Subscription,
012 34567 89
yenduc(at)sbcglobal.net Guest
Have you checked the insurance rates for tail vs nose draggers????
Set aside the testosterone issue; let it drop.
best wishes
dave--(bet you guessed it) -RV7A, 55 hours and no ground loops or flip overs so far------------
On Feb 6, 2009, at 8:43 AM, Schroeder, Bob (Parts Clerk) wrote:
| Quote: | Too funny! However many bent nose gears there have been, there are only 2 kinds of tail wheel pilots. Those that have and those that will. (you know what I’m talking about) we have a local pilot that has 2 tail wheel aircraft and a tricycle gear bird. He ground looped one last fall and did the same with the other one a couple of weeks ago. So I think that I will continue my tricycle gear 6. Thank you very much. lol
David Leonard
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV6-List blue; text-decoration: underline; ">http://forums.matronics.com style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution [/b] |
[/quote]
Posted: Fri Feb 06, 2009 10:10 am Post subject: Converting a 6 to a 6a |
I will. I’m currently allowed to fly my buddy’s 9a. it’s a dream to fly and I’ve never had that good of landings in a piper or Cessna. It’s just not fast enough compared to the 6
From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Friday, February 06, 2009 10:55 AM
Subject: RE: Re: Converting a 6 to a 6a
Bob,
Robin
ronlee(at)pcisys.net Guest
Posted: Fri Feb 06, 2009 10:27 am Post subject: Converting a 6 to a 6a |
Exactly, insurance rates will tell the truth. I know of one RV groundloop
with damage at my airport but ZERO RV tri-gear incidents. I suspect that
the fact is that the nose-overs are on unimproved landing areas. So stay off
of them.
Ron Lee
Posted: Fri Feb 06, 2009 10:35 am Post subject: Converting a 6 to a 6a |
None. But one of the 2 was a harmon rocket. I did see the picture of a 7A that was caught mid fall standing on its nose in the grass.
Sent: Friday, February 06, 2009 11:04 AM
David Leonard
David Leonard
Subscription,
| Quote: | | http://www.matronics.com/Navigator?RV6-Listhttp://forums.matronics.com |
| Quote: | | et="_blank">http://www.matronics.com/Navigator?RV6-Lista href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com | 01
-- 23456789 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 0 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 1 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 2 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 3 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 4 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 5 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 6 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 7 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 8 | Quote: | | http://www.matronics.com/Navigator?RV6-List | 9 | Quote: | | http://forums.matronics.com | 0 | Quote: | | http://forums.matronics.com | 1
Posted: Fri Feb 06, 2009 10:36 am Post subject: Converting a 6 to a 6a |
The 9 that I have about 70 hours in is close to 200 total time and just a solid flyer.
From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of David Cudney
Sent: Friday, February 06, 2009 11:07 AM
best wishes
David Leonard
Subscription,
| Quote: | | http://www.matronics.com/Navigator?RV6-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution http://www.matronics.com/Navigator?RV6-Listblue; text-decoration: underline; ">http://forums.matronics.comstyle="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution |
01234567890123456789
chuckhh0208(at)msn.com Guest
Posted: Fri Feb 06, 2009 10:41 am Post subject: Converting a 6 to a 6a |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Please do not send these emails to the entire RV6-list. Thanks
Posted: Sat Feb 07, 2009 6:49 am Post subject: Converting a 6 to a 6a |
Insurance rates are all about experience level (well, a little about how
much the ins company is making in the stock market at the moment).
I started flying lessons about 20 yrs ago with no desire to fly TW, then
stumbled into a great deal on a 1/3 share of a Luscombe & learned to fly
in that. I have almost no time in nosegear planes since then, & I don't
pay any more for TW RV insurance than nosewheel.
To be clear, I'm not talking about *experience*, not ability. The
underwriter just looks at numbers; he doesn't watch you (or me) fly.
Charlie
David Cudney wrote:
| Quote: | Have you checked the insurance rates for tail vs nose draggers????
best wishes
> very much. lol
> *From:* owner-rv6-list-server(at)matronics.com
> <mailto:owner-rv6-list-server(at)matronics.com>
> [mailto:owner-rv6-list-server(at)matronics.com] *On Behalf Of *David Leonard
> *Sent:* Friday, February 06, 2009 9:15 AM
> *To:* rv6-list(at)matronics.com <mailto:rv6-list(at)matronics.com>
> *Subject:* Re: Re: Converting a 6 to a 6a
> David Leonard
> http://RotaryRoster.net <http://rotaryroster.net/>
Posted: Sat Feb 07, 2009 7:18 am Post subject: Converting a 6 to a 6a |
Ron, are you talking about grass strips when you say 'unimproved landing
areas'? You're kidding, right?
Guys, if you only fly off pavement & are happy limiting yourself to that
kind of flying, then TW really does come down to appearance & if you
don't want a TW, don't get one. On the other hand, don't be deceived
into believing you have to have the skills of Chuck Yeager or Bob Hoover
to safely fly a TW.
Charlie
See my previous post about ins.
Ron Lee wrote:
| Quote: | Exactly, insurance rates will tell the truth. I know of one RV groundloop
stay off
of them.
Ron Lee
Posted: Sat Feb 07, 2009 10:26 am Post subject: Converting a 6 to a 6a |
I meant non-paved/concrete.
Ron Lee
