Fox5flyer Guest
Posted: Thu Feb 05, 2009 4:03 pm Post subject: Snowshoes on struts |
I would ask my CFI to quote the reg that says it's illegal, Lynn. Actually, it's a pretty good question though. Perhaps, if he's back in town, Snake Man can answer that one.
And, Pat, I believe it's now called "climate change". So it goes...
Deke
NE MI S5 and looking for some snow melt
Yeah, It's a year colder than normal because of global warming Al Gore says.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
| Quote: | --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I think this has been a long, cold winter for a lot of us....we are
on a record-setting pace for snowfall here in southern Lower
Michigan. I'v really been getting my money's worth out of these skis,
unlike the previous 2 years, where half the time I could have chanced
flying without them.
Two feet, eh? That would be enough to make me think twice about
venturing out. Not so much as to whether the plane could handle that
much depth, but whether the pilot could, if he had to get out and
walk. I gotta get some snowshoes to hang on the struts....they look
so cool!! (but probably illegal, so says my CFI, the kill-joy!)
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
[b] |
Lynn Matteson
Posted: Thu Feb 05, 2009 4:48 pm Post subject: Snowshoes on struts |
I seem to recall him saying that anything that is strapped onto the
outside of the plane is "illegal carrying of cargo" or something like
that. No use asking the Snake Man, those guys in the 49th State have
been getting away with murder (figure of speech) for years, so I've
read anyway. The way I've read about the early bush-country flying is
that they have an unspoken rule up there that the FAA looks the other
way and pretty much allow whatever the pilot can get on board as
"legal".
One account I read...I believe it was in "Wager with the wind...the
Don Sheldon story", but I can't be sure....told of an FAA guy who
busted a pilot for carrying either too heavy a load, or carrying it
outside of the plane, or something that the "book" said was against
the rules, and it wasn't too long before the FAA guy was soon
spending his time in some remote God-forsaken outpost doing menial
duty. This may have changed over the years, and maybe someone from
Alaska might shed some light on the current practice....or on the
carrying of cargo outside the plane, for that matter.
Lynn Matteson
Sensenich 62x46
On Feb 5, 2009, at 7:02 PM, fox5flyer wrote:
| Quote: | I would ask my CFI to quote the reg that says it's illegal, Lynn.
Deke
Gore says.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
skis,
chanced
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> do not archive
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
helili(at)chahtatushka.ne Guest
Posted: Thu Feb 05, 2009 4:54 pm Post subject: Snowshoes on struts |
The manufacturer of a certificated aircraft must publish an owner/operator manual, and a certificated aircraft can have no modifications to it that are not in the Type Certificate Data Sheet, unless such modifications are covered by a Supplemental Type Certificate or field approval on a 337 Form. External loads must comply with the above documents on certificated aircraft.
Experimental aircraft do not fall under the above mentioned rules. The manufacturer (builder) of an Experimental aircraft determines the way in which the aircraft may be used, i.e., external loads. If the Operating Limitations for a given Experimental aircraft prohibit external loads, then the prohibition applies. As is the case with tires, floats, etc. that a builder wants to use on an Experimental aircraft, external loads may be carried if the builder wants to determine the safe loading of the external load to include weight and balance, makes the appropriate entries in the logbook, flies the aircraft so loaded the requisite time determined by either the particular configuration (usually 5 hours) or as determined by the FSDO. Once the requisite flight time is completed and the appropriate logbook entries are made, have fun.
This same subject came up while I worked at the Anchorage FSDO concerning hauling a snomachine (snowmobile) bolted to the fuselage of an Experimental copy of a Super Cub. The guy completed the paperwork and as far as I know is still flying his snowmachine out to the bush in the winter in interior Alaska. I quit working there in 1999.
John Hart
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Thursday, February 05, 2009 6:02 PM
Subject: Snowshoes on struts
Deke
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Lynn Matteson
> Sensenich 62x46
> do not archive http://www.matronics.com/Navigator?Kitfox-List | 0123456789
akflyerbob
Joined: 06 Jan 2008 Posts: 30 Location: Soldotna, Alaska
Posted: Thu Feb 05, 2009 10:23 pm Post subject: Re: Snowshoes on struts |
Sorry I posted in the wrong place
Lynn
I have always been told it is not legal to strap, Tye, or attach any
thing to the struts as they are not designed for drag effect.
We, I should say I, have generally tied snow shoes, rifles in a
scabbard and other stuff, "gas cans", and have not been ruffled
over it. Not saying up here is lax, but you can see planes tied at the airport with snow shoes strapped to the struts.
I think all realize a one mile walk in 4 ft of snow at -20 can't be done
without snow shoes. If their destroyed inside the plane, better outside.
I had to remove anything from the struts to have the
airplane annulled.
This is not a confession and I will deny it as a myth
Bob
_________________ Bob Wolfe..Soldotna, Alaska
KF Mod I and III |
Lynn Matteson
Posted: Fri Feb 06, 2009 5:16 am Post subject: Snowshoes on struts |
Gotcha, Bob, and thanks for the observation.
Lynn Matteson
Sensenich 62x46
On Feb 6, 2009, at 1:23 AM, AKFLYERBOB wrote:
<r.wolfejr(at)worldnet.att.net>
Lynn
done
outside.
airplane annulled.
Bob
KF Mod I and III
http://forums.matronics.com/viewtopic.php?p 28818#228818
N369LM |
Guy Buchanan
Posted: Fri Feb 06, 2009 7:22 am Post subject: Snowshoes on struts |
At 04:02 PM 2/5/2009, you wrote:
| Quote: | I gotta get some snowshoes to hang on the struts....they look
That would be strange. One of my flying buddies from up north
routinely flies with his folding chairs strapped to the struts, as do
several that travel to Kitfox fly-ins. They've travelled so many
miles this way without question that, anecdotally speaking, I can't
imagine it's illegal.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Float Flyr
Posted: Fri Feb 06, 2009 7:37 am Post subject: Snowshoes on struts |
I certainly can't speak for U.S. regs but I certainly know it is legal to
fly with loads strapped to floats here in Canada. How do you think most of
the canoes get into the fishing lodges? I know a guy (PPL) who has over the
years had some very nice planes. He has carried everything from canoes to
sheets of plywood to refrigerators on the struts of his floats. His advice
to me was when carrying external loads just dodge along... don't try to
break any speed records.
BTW when you strap a canoe to your struts the plane will want to lift that
wing not drop it because of the extra weight. Thge canoe has an aerodynamic
shape that actually adds lift to the side it's on.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Fri Feb 06, 2009 8:07 am Post subject: Snowshoes on struts |
I like the anecdotal tales, but does anybody know, and can they cite,
the appropriate rule regarding this practice? If I could find my FAR/
AIM, I'd try to look it up.
I just got done reading "Bent props and blow pots" and in it they
talk of trying to get airborne with a set of extra floats strapped
above the existing floats of the low-wing Junkers they were flying.
They had the "to-be-delivered" floats strapped inverted above their
own floats, and could not get up to takeoff speed in this
configuration, so they rotated the floats so they were keels down,
and with this setup finally got airborne. This was in Canada, circa
1930's.
Again, I've heard the stories, but I'd like to know if I'm in
jeopardy of being busted if I do it, and what can I cite in my
defense if I do....and to argue with my CFI friend who loves to have
the law/rule on the tip of his tongue.
Lynn Matteson
Sensenich 62x46
On Feb 6, 2009, at 10:36 AM, Noel Loveys wrote:
legal to
most of
over the
canoes to
His advice
try to
lift that
aerodynamic
Noel
N369LM |
akflyer
Posted: Fri Feb 06, 2009 8:17 am Post subject: Re: Snowshoes on struts |
Snakeman has to side with John Hart on this one... I think that sometimes people confuse rules for certified AC and those for experimentals. I did a bit of searching on the FAA website and could find nothing on external loads for experimental AC.
Personal experience with a kitfox has been 2 shotguns on a strut, 4 fishing poles on a strut, 1 pair snowshoes on a strut. Not all at the same time lol. No adverse effects were noted. I also strapped dry bags with all my duck hunting gear on top of the floats as well as 2- 5 gallon cans on each float. While the extra drag was noted in a speed loss, no adverse effects to the flying qualities of the kitfox were noted.
Snakeman.... out
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Feb 06, 2009 8:33 am Post subject: Snowshoes on struts |
Noel,
Your post reminds me of some video I saw of a guy carrying in building
materials for a remote cabin strapped to his airplane externally. Obviously
this was a certified airplane and it was documented in video. That I saw it
means everyone else saw it.
Lowell
Lynn Matteson
Posted: Fri Feb 06, 2009 9:32 am Post subject: Snowshoes on struts |
Thanks, Snake...and John. I'll run this info by my CFI. I just love
to get him to go to the "BOOK" and back up what he preaches. : )
My recent "ski tuck" proves that the Kitfox *will* fly with some
pretty good adverse drag.
Lynn Matteson
Sensenich 62x46
On Feb 6, 2009, at 11:17 AM, akflyer wrote:
kitfox were noted.
Snakeman.... out
N369LM |
Posted: Fri Feb 06, 2009 9:40 am Post subject: Snowshoes on struts |
It's not a matter of FAR in this instance. It's a matter of aircraft
certification. Nothing I have ever seen in any regulation specifically
addresses external loads on a given aircraft. There are some rules
pertaining to external loads, but they do not specify which aircraft by
make, model or serial number. FAR 133 pertains to ROTORCRAFT EXTERNAL-LOAD
OPERATIONS, and it applies to holders of commercial operateors external load
certificates. As far as I know. no "regulation" exists for fixed wing.
http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=d500894896c3de5eda5
7b3b87512cc38&rgn=div5&view=text&node=14:3.0.1.1.6&idno=14
There is guidance in the Flight Standards Information Management System,
8900.1 which may be accessed through www.faa.gov .
The following link may be helpful:
http://www.faa.gov/library/manuals/aircraft/media/FAA-H-8083-1A.pdf There
is mention of determining safe loading of experimental aircraft with
external loads.
John Hart
KF IV, NSI Subaru
Wilburton, OK
Fox5flyer Guest
Posted: Fri Feb 06, 2009 11:33 am Post subject: Snowshoes on struts |
I like the anecdotal tales, but does anybody know, and can they cite, the
appropriate rule regarding this practice? If I could find my FAR/ AIM, I'd
try to look it up.
I may be wrong, Lynn, but I I think you'll be wasting your time. Better to
wait and see if anyone can cite a reg, which I doubt.
Now, with a day like this, why are you hen pecking away at the key board
when you could be out taking advantage of this. My hangar is surrounded by
combines getting ready to take off my corn. The snow is so deep they will
have to just skim along the top of the snow to get the cobs.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Float Flyr
I have a piece of black PVc Pipe around 3" I.D. and about six feet long
tied more or less permanently to my left float strut. When fishing with the
fly rod I break it in half and insert it through the tube from the front.
Spinning gear doesn't need to b3e broken down. Air pressure keeps the rods
in the tubes until I land... Makes setting up to fish a lot faster.
Noel
Kitfox III-A
Float Flyr
Posted: Fri Feb 06, 2009 12:17 pm Post subject: Snowshoes on struts |
Deke:
You grow corn through the winter??
Noel
Kitfox III-A
Lynn Matteson
Posted: Fri Feb 06, 2009 12:46 pm Post subject: Snowshoes on struts |
I'm peckin' away because I've got a helluva cold/flu/whatever. I'd
like to be out checking the takeoff-ability of the plane in this
warming snow, but I feel like crap.
Lynn Matteson
Sensenich 62x46
On Feb 6, 2009, at 2:32 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
> cite, the appropriate rule regarding this practice? If I could
> find my FAR/ AIM, I'd try to look it up.
Better to wait and see if anyone can cite a reg, which I doubt.
board when you could be out taking advantage of this. My hangar is
surrounded by combines getting ready to take off my corn. The snow
is so deep they will have to just skim along the top of the snow to
get the cobs.
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
N369LM |
Fox5flyer Guest
Posted: Fri Feb 06, 2009 1:08 pm Post subject: Snowshoes on struts |
No, the land is leased to a big farmer who, I assume has just been waiting
for a good price before taking it off.
Winter is so dry here that it does fine just standing there, except for the
constant pilfering by the coons and deer.
D
Deke:
Noel
