face book
lcottrell
PostPosted: Wed Feb 04, 2009 9:11 pm    Post subject: face book Reply with quote
For what ever reason Face book is giving me a bad time. I think that the other link that I sent only shows one photo. There are 25 in the album. This one will take you there.
Sorry,
Larry C
http://www.facebook.com/album.php?aid=2009806&l=c03c3&id=1002056194
zeprep251(at)aol.com
PostPosted: Thu Feb 05, 2009 5:34 am    Post subject: face book Reply with quote
Larry,
Great pictures! Want to ask you about the EIS readings.The 2.5 reading and below it the 5? When I was flying my FS there was one page that showed the egts and chts for both cyls on the far right,vsi in the lower middle and alt and rpm on far left.Can you still program the unit yourself?
G Aman
lcottrell
PostPosted: Thu Feb 05, 2009 7:07 am    Post subject: face book Reply with quote
PostPosted: Thu Feb 05, 2009 10:08 am    Post subject: face book Reply with quote
Larry,
? Totally forgot about oil temp and pressure.Still thinking 2 stroke.Still enjoy your photos.
?? Thanx G.Aman
N111KX (Kip)
PostPosted: Thu Feb 05, 2009 6:06 pm    Post subject: Re: face book Reply with quote
Looks like some unfriendly terrain below. You must actually have to have a backup plan if you get stranded out there.
I base my engine out decisions on whose backyard is the biggest...Smile
Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta
lcottrell
PostPosted: Thu Feb 05, 2009 6:35 pm    Post subject: face book Reply with quote
Kip
I took a suggestion from Larry Bourne and bought a "Spot" locator that I take with me, and leave a flight plan with the wife when I go. I also try real hard to stick to it. One of the reasons that I bought the HKS is that I like to go straight line, and this is the best I can do to make it safe or at least stack the odds in my favor. The wife's instructions in case I don't return, is to draw a line from my last known position to where I was supposed to be going and I should be somewhere close to that line. Smile As you can tell most of the places here are few and far between. It isn't very hard at all to be somewhere that it would take you more than a day to walk out of if you weren't injured.
Larry C
N111KX (Kip)
PostPosted: Fri Feb 06, 2009 5:48 am    Post subject: Re: face book Reply with quote
Larry, that's the kind of "plan" that I was thinking!
Way to go.
Is your locator a 406mhz type...?
Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta
lcottrell
PostPosted: Fri Feb 06, 2009 7:03 am    Post subject: face book Reply with quote
My ELT is the old "outdated" one, the other one is a "Find me Spot" that you can buy at Sporting goods stores. I bought it at Christmas and got a $50. rebate. You can send a 911 call, an OK call or a Help call, whichever suits your condition, assuming of course that you are in any kind of condition to do any of the above. The way that I use it is to send a OK call that goes to my computer (and anyone else you designate), that gives the wife a solid time and location of where I was, and that I am heading back. Of course if I decide to deviate, then I can send another one. It just basically narrows down the search requirements, and makes her feel better. Not every one would need it, but here it could be as bad as trying to find Fosset if you didn't show up.
http://www.findmespot.com/en/index.php?cid=1110 In case you would like to check it out.
Larry C
PostPosted: Fri Feb 06, 2009 7:47 am    Post subject: face book Reply with quote
Larry:
Maybe I missed it, but Spot also has the capability of tracking your progress with periodic updates of your position.
"TRACK PROGRESS: Also known as SPOTcastingSM, this feature allows friends and family to follow your progress in real time using your password, or to save waypoints so you can review your entire route at a later date."
I have an ACR 406 Microfix. It has internal GPS. It is to be used in emergency situations of life and death only. Contact is made with National Search and Rescue:
http://www.sarsat.noaa.gov/
I do a lot of ATV and Dirt Bike riding, solo most of the time, in addition to flying. It would be nice to have the other capabilities of the Spot system, i.e., letting folks know I am ok but having mechanical problems, tracking progress, and also contacting 911.
The PLB was about $600.00, but no annual fee and batteries are good for 5 years.
Spot has annual service fee.
They balance out when it comes to capability and money.
Either one is good to have when you get into a position/situation where you need it.
[quote] Of course if I decide to deviate, then I can send another one. It just basically narrows down the search requirements, and makes her feel better. Not every one would need it, but here it could be as bad as trying to find Fosset if you didn't show up.
Larry C
rlaird
PostPosted: Fri Feb 06, 2009 7:52 am    Post subject: face book Reply with quote
FYI, BigLar (Larry Bourne) has had only intermittent luck with the
Spot's periodic updates. Sometimes it works, sometimes it doesn't.
My impression is that Spot's software and website is still in beta
mode.
-- Robert
On Fri, Feb 6, 2009 at 9:45 AM, John Hauck <jhauck(at)elmore.rr.com> wrote:
Larry:
Search and Rescue:
years.
need it.
Larry C
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
PostPosted: Fri Feb 06, 2009 7:58 am    Post subject: face book Reply with quote
-- Robert
Robert:
Is Larry Bourne flying with his Spot?
Might make a difference in reception, whether on the ground or in the air.
rlaird
PostPosted: Fri Feb 06, 2009 8:36 am    Post subject: face book Reply with quote
Nope, not unless you call tearing-across-the-desert-in-a-4-wheeler, flying! Smile
> -- Robert
Robert:
Robert Laird
Houston, TX area
lcottrell
PostPosted: Fri Feb 06, 2009 9:02 am    Post subject: face book Reply with quote
russ(at)rkiphoto.com
PostPosted: Fri Feb 06, 2009 11:07 am    Post subject: face book Reply with quote
I don't think BigLar is flying at all these das
Russ
> Spot's periodic updates. -- Robert
Robert:
the air.
Jim ODay
PostPosted: Sat Feb 07, 2009 10:53 am    Post subject: Re: face book Reply with quote
I have a SPOT unit and I agree the "update" function is "spotty". When it works, it is pretty cool. The "Check In" message is reliable. Have not needed the 911 message (hope I never do either). I am not 100% satisfied with the operation, but I still don't fly without it.
I was in Guatemala a week ago and had it with me and it looked to be working but did not send any messages. Sad So much for that.
I bought a RAM mount for the unit and am going to try to mount it up on the greenhouse roof of my plane and see what happens later today. I have had it on the dash of my Cessna and it works well there.
I have the following emergency message set up:
"This is an aircraft. Either a Blue/White Twin Engine Cessna or a Red/White small single engine aircraft. Cindy will know which one- 701-388-0019, 701-241-7637 or 701-293-2088" Flight Service # 800 992-7433"
I never file a flight plan when I go our fun flying because I never know where I will be going anyway. I figure if I go down and survive, I can push the 911 button to summon help. If I don't survive, I figure the Cindy will check the SPOT website to narrow down the search to a 10 minute flying area.
Fly safe,
Jim
Jim O'Day
Fargo, ND
Former Firestar II Builder/Pilot
Jim ODay
PostPosted: Sun Feb 08, 2009 6:50 pm    Post subject: Re: face book Reply with quote
I flew today and the SPOT worked fine. I mounted it so that it had a clear view of the sky and it sent position reports as promised every 10 minutes. I attached a shot of the SPOT web page that shows the tracking.
SPOT Web Page
 Filesize:  96.45 KB
 Viewed:  531 Time(s)
Jim O'Day
Fargo, ND
