Cwehner
Posted: Tue Feb 03, 2009 6:13 pm Post subject: Brake line fittings question... |
I've started work on the Brakes and over the years have managed to lose a few Brass poly-flo fittings. Does it matter if the fittings with the "brass" sleeves OR the "nylon" sleeves are used, or is one one or the other required using the Nylaflo pressure tubing.
Thanks for any suggestions!
_________________ Chris Wehner
Tulsa, Oklahoma
Kitfox IV, 912, Final push for completion! |
Tom Jones
Posted: Thu Feb 05, 2009 7:38 am Post subject: Re: Brake line fittings question... |
| Quote: | | I've started work on the Brakes and over the years have managed to lose a few Brass poly-flo fittings. Does it matter if the fittings with the "brass" sleeves OR the "nylon" sleeves are used, or is one one or the other required using the Nylaflo pressure tubing. |
Clem, at less than a dollar each I would stick with the brass fittings with the captive sleeve. Thats what was supplied with my kit.
Here they are in Aircraft Spruce.
http://www.aircraftspruce.com/catalog/hapages/polyflofittings.php
_________________ Tom Jones
Classic IV
Ellensburg, WA |
larry huntley
Posted: Fri Feb 06, 2009 3:38 am Post subject: Brake line fittings question... |
John McBean has lots of them and they are inexpensive. I just bought some
tube and fittings for mine. Larry Huntley
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
