Kits
Kelly McMullen
PostPosted: Thu Feb 05, 2009 7:58 am    Post subject: Kits Reply with quote
I note that on Tim's site for what is in the various kits, there are
listings for a firewall forward kit, separate from finishing kit.
However, Vans only lists empennage, fuselage, wing and finishing kits.
Has Vans changed how they package things? Or is that just a convenient
division of parts in the finishing kit?
Kelly
40866
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
planesmith(at)hotmail.com
PostPosted: Thu Feb 05, 2009 8:17 am    Post subject: Kits Reply with quote
The firewall forward kit is listed in the web store separately. Here's a link: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233850394-2-318&browse=engines&product=FF_Kit
Vern Smith (#324 finishing)
Date: Thu C 5 Feb 2009 08:57:26 -0700
Subject: Kits
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com>
I note that on Tim's site for what is in the various kits C there are
listings for a firewall forward kit C separate from finishing kit.
However C Vans only lists empennage C fuselage C wing and finishing kits.
&gt=====================
Windows Live™: E-mail. Chat. Share. Get more ways to connect. Check it out. [quote][b]
rv(at)thelefflers.com
PostPosted: Thu Feb 05, 2009 12:11 pm    Post subject: Kits Reply with quote
The firewall kit is highly dependent on which engine you get. There are too
many options, so quite a few folks roll their own. Vans does sell a
firewall kit for the 540 models they sell. It's in their catalog. You
can use those as a starting point if you get an engine from another source.
There is no overlap with the finishing kit. You can see the details here:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233864459-434-198&bro
wse=engines&product=FF_Kit The following is off the web store.
The RV-10 Firewall Forward Kits below can be ordered with or without a three
lever throttle/prop/mixture quadrant part number "CT10-3". If you opt for
the NON three lever quadrant, your engine control cables will be supplied as
vernier style.
From December 2007, FWF kits DO NOT contain the wiring harness.
EXAMPLE KIT FOR AN RV-7A, O-360, WITH A CONSTANT-SPEED PROPELLER:
1 VA-138 FUEL SUPPLY HOSE 14.0"
1 VA-139 FUEL SUPPLY HOSE 16.5"
1 CT BLUE VPROP 48 7(ALL)/9(ALL)
1 CT BLK THROTTLE 44 6(ALL)/7(360)/9(320)
1 CT RED VMIXTURE 45 7(360)/9(320)
1 FAB-360/540 FLTRD A/BOX-360 FI320
1 BAF-360 COWL BAFFLE KIT 6/7/8
1 VA-149-360-PC KIT THROTTLE/MIXTURE BRACKET
1 VA-153-PC McCauley or MT governor cable bracket
1 PROP GOV MT P-860-4 (I)O-320/360 LYCOMING
1 AT0-028X3/16X6 ALUMINUM TUBE SOFT
1 AT6-058X5/16X15 7/8 ALUMINUM TUBE HARD
1 SS304-26GAX1/2X9 STAINLESS CLAMP MATERIAL
1 FF 3/4 FIREWALL PL SS FIREWALL PLUG
1 ES PC680 INSTALL KIT BATTERY MOUNT 7/9
1 AS3-063X1X12 ALUMINUM STRIP
1 EA LV-1 HEAT SHIELD EXHAUST HEAT SHIELD
2 CT A-740 BLACK PUSH PULL CABLE BLACK
1 DUCT CBT-5/8 COOLING BLAST TUBE
1 EA CV HOSE 9816 BREATHER HOSE 4 CYL
1 EA DYNA BOLT BOLT SET 4 CYL DYNAFOCAL
4 EA DYNA VI-STD VIB.ISO. ALL EXCEPT-10
1 EA EXH W/MUFF 320/360 EXHAUST SYSTEM
1 EA OIL COOLER II O-320/360 OIL COOLER
1 ES 24021 STARTER SOLENOID RELAY
1 ES 24115 MASTER SOLENOID RELAY
1 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT
1 FF-705 OIL BREATHER TUBE
1 FF-709 OIL COOLER DOUBLER
1 VA-161 GASCOLATOR DOUBLER
1 IE VMP INSTALL KIT MANIFOLD PRESSURE FITTINGS
1 GAS-5 GASCOLATOR
1 PT-035X1/4X12 FUEL OVERFLOW TUBE
1 VA-102 FUEL PRES. HOSE 15.5
1 VA-168 FIREWALL SENDER MOUNT
1 VA-133 OIL PRESS. HOSE 27.25
1 VA-134 OIL COOLER HOSE 19.0
1 VA-135 OIL COOLER HOSE 16.5
1 VENT DL-03 2" ALUMINUM DUCT FLANGE
1 VENT SCAT 2X6' RED SCAT TUBE 2"X 6'
1 VENT TG-10 CABIN HEAT SELECTOR
1 DOC FWF COMPLETE TEXT/DRAWINGS
1 CT BEARING HWR, CARB BOLT, NUT, WASHERS
1 CT BEARING HWR, PROP BOLT, NUT, WASHERS
1 BAG 604-1 FF MISC. HDWRE
1 BAG 607 FF MISC. HDWRE
1 BAG 608 FF MISC. HDWRE
1 BAG 611 FF MISC. HDWRE
1 BAG 613-1 FF MISC. HARDWARE
1 BAG 958 AN426AD3-4
1 BAG 991 AN426AD3-3.5
1 BAG 1907 AN426AD4-7
1 BAG 1916 AN426AD3-4.5
1 BAG 1934 AN426AD3-5
1 BAG 1935 AN426AD3-6
1 BAG 312 AN426AD4-6
1 BAG 1978 AN470AD4-5
Kellym
PostPosted: Thu Feb 05, 2009 7:34 pm    Post subject: Kits Reply with quote
Thanks for the replies. Appreciate all that. I think it is a bit disingenuous of Vans to not list it in the kit prices <http://www.vansaircraft.com/public/kitprice.htm>, and in the price estimator to show $3400-4800 when the current price is $6000. Oh well, won't be the first chunk overlooked in budget. I don't see a whole lot changing in that kit if you stick with a 540 series engine, regardless of source, which is perhaps 98% of all RV-10s? Obviously we can choose to roll own, with the time issues to research, price, order, etc.
Kelly
Bob Leffler wrote:
--> RV10-List message posted by: "Bob Leffler" <rv(at)thelefflers.com> (rv(at)thelefflers.com)
T
[img]cid:part1.08070808.04060009(at)aviating.com[/img]
 Filesize:  1.97 KB
 Viewed:  1930 Time(s)
Kelly McMullen
KCHD
msausen
PostPosted: Fri Feb 06, 2009 5:59 am    Post subject: Kits Reply with quote
There are definitely cheaper and better options for some of the items for the FWF kit. For instance I believe both Bonaco and Aircrafthose.com have kits to replace the Van’s hoses for less money and with integral fire sleeve. I know I went through and deleted probably about half the items in the FWF.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Thursday, February 05, 2009 9:30 PM
Subject: Re: Kits
Kelly
Bob Leffler wrote:
--> RV10-List message posted by: "Bob Leffler" <rv(at)thelefflers.com> The firewall kit is highly dependent on which engine you get. There are toomany options, so quite a few folks roll their own. Vans does sell afirewall kit for the 540 models they sell. It's in their catalog. Youcan use those as a starting point if you get an engine from another source. There is no overlap with the finishing kit.  You can see the details here:http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233864459-434-198&browse=engines&product=FF_Kit The following is off the web store.
 Filesize:  1.97 KB
 Viewed:  1932 Time(s)
