Common Wire Diameters
longg(at)pjm.com
PostPosted: Thu Feb 05, 2009 7:08 am    Post subject: Common Wire Diameters Reply with quote
Can any of you point me to a reference describing Tefzel MIL-W-22759/16
wire diameter sizes for those typically used in aircraft? I am
specifically interested in #4, #6, #10 & 12.
Glenn
rjquillin
PostPosted: Thu Feb 05, 2009 7:33 am    Post subject: Common Wire Diameters Reply with quote
At 07:06 2/5/2009, you wrote:
--> AeroElectric-List message posted by: <longg(at)pjm.com>
Glenn
PDF of the official spec, if somewhat dated, when it was MIL and still freely available and not commercial for $$$. But be aware these are specified maximum diameters and stock from differing manufacturers varies. Likely you can visit the manufacturers individual site and get their specs.
Ron Q.
22759_16a.pdf
 Filename:  22759_16a.pdf
 Filesize:  207.55 KB
 Downloaded:  348 Time(s)
bob(at)bob-white.com
PostPosted: Thu Feb 05, 2009 7:41 am    Post subject: Common Wire Diameters Reply with quote
Hi Glenn,
Try http://www.jaguarind.com/products/ptfe/16.html
They have a nice table.
Bob W.
On Thu, 5 Feb 2009 10:06:52 -0500
Glenn
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
3.8 Hours Total Time and holding
Cables for your rotary installation - http://roblinstores.com/
PostPosted: Thu Feb 05, 2009 8:07 am    Post subject: Common Wire Diameters Reply with quote
Diameters can vary depending on the slash number
for the variants. You can access the full spectrum
of data on 22759 and other wires in the catalog
on my website at . . .
http://aeroelectric.com/Mfgr_Data/Wire/Standard_Wire_and_Cable/Std_Wire_Cable.pdf
/16 data is on document page 80 (pdf page 87).
( -Thomas Paine 1776- )
longg(at)pjm.com
PostPosted: Fri Feb 06, 2009 10:35 am    Post subject: Common Wire Diameters Reply with quote
Excellent,
Thanks to all....
