RV-8 Flap Sensor - A Simple Installation Design...?
Site Admin
PostPosted: Tue Feb 03, 2009 8:05 pm    Post subject: RV-8 Flap Sensor - A Simple Installation Design...? Reply with quote
Does anyone have a simple, reliable installation design for the little position sensor from MAC Trim when used with the Electric Flap option on the PP QB RV-8? I've scratched my head for few hours now and have some ideas, but nothing that really seems like its simple enough or not prone to jamming. What have other builders done? Pictures would be great!
RV-8 #82880/N998RV (res)
 Filesize:  175.37 KB
 Viewed:  237 Time(s)
 Filesize:  275.05 KB
 Viewed:  219 Time(s)
crowbotham(at)hotmail.com
PostPosted: Wed Feb 04, 2009 4:35 am    Post subject: RV-8 Flap Sensor - A Simple Installation Design...? Reply with quote
Hi Matt C
While Dave and I did not utilize a MAC flap indicator on our 8 C we did install a micro switch for our AOA (now Advanced Flight Systems) to toggle between cruise and landing configuration. We utilized a micro switch that activated at 20 degrees flap extension. It was a simple bracket located on the opposite end of the flap weldment ( right side of the bracket - facing forward). Before Jim Frantz sold his AOA company to Advanced Flight Systems there was a picture of the installation. You might call Advanced and see if they still have a copy of the installation jpegs or le me know and I'll try and find it.
Chuck Rowbotham
(RV-8A sold)
Dave has a RV-9A underconstruction) (Repeat offender)
Date: Tue C 3 Feb 2009 20:03:42 -0800
To: rv-list(at)matronics.com
Subject: RV-8 Flap Sensor - A Simple Installation Design...?
Does anyone have a simple C reliable installation design for the little position sensor from MAC Trim when used with the Electric Flap option on the PP QB RV-8? I've scratched my head for few hours now and have some ideas C but nothing that really seems like its simple enough or not prone to jamming. What have other builders done? Pictures would be great!
Thanks C
Windows Live™: Keep your life in sync. Check it out.
Tailgummer(at)aol.com
PostPosted: Wed Feb 04, 2009 7:13 am    Post subject: RV-8 Flap Sensor - A Simple Installation Design...? Reply with quote
Matt, I simply bent a piece of scrap Al (025 or 032??) to mount my POS-12. Since the screws fastening the support to the bulkhead were inside of the baggage wall (between the baggage wall and the fuselage skin), I used #6 nut plates (for future service). In addition the termination of the wires (pins and barrels) are on the fwd side of the bulkhead (in case I needed to change out the sensor in the future... old photo during construction). You'll need to adjust the length/position of the threaded rod/clevis for the appropriate travel
Pretty simple and has worked well on my AF2500.
                John D'Onofrio
              RV8 N585JD
              (Tailgummer(at)aol.com (Tailgummer(at)aol.com))
In a message dated 2/4/2009 4:36:35 A.M. Pacific Standard Time, crowbotham(at)hotmail.com writes:
PostPosted: Wed Feb 04, 2009 7:14 am    Post subject: RV-8 Flap Sensor - A Simple Installation Design...? Reply with quote
Forgot the photo, sorry.
                  John D'Onofrio
 Filesize:  39.16 KB
 Viewed:  243 Time(s)
aerobubba(at)earthlink.ne
PostPosted: Wed Feb 04, 2009 12:35 pm    Post subject: RV-8 Flap Sensor - A Simple Installation Design...? Reply with quote
Hi Matt-
I've used that sensor in my -8, and would be happy to send you pix. Unfortunately, I'm on the road this week and will not be able to access the pix until the beginning of next week.
GM
Glen Matejcek
