barryhancock
Posted: Tue Feb 03, 2009 4:23 pm Post subject: Yak rudder pedal mod |
Gang,
I just got done flight testing our new rudder pedal brackets in the Yak-50. They're a nice change. The additional 3" of leg room is noticeable and there are no clearance issues.
We need to find a local Yak-52 to confirm that there are not any clearance issues in the front cockpit, and then we'll do our first production run. We currently have about a dozen orders waiting and would like to complete the development stage ASAP. If any local Yak-52's are interested, we will give you a free set ($250 value) plus free installation (another $225 value) for bringing your Yak to Chino for a day.
Please contact me directly if you are interested and we will put it on the schedule.
Happy Yakkin',
Barry
Barry Hancock
Worldwide Warbirds, Inc.
office (909) 606-4444
cell (949) 300-5510
www.worldwidewarbirds.com
Express Mailing address:
7000 Merrill Ave, B-110, Unit J
Chino, CA 91710
Regular Mailing address:
7000 Merrill Ave., Box 91
Chino, CA 91710
The information contained in this e-mail message is intended only for the personal and confidential use of the designated recipients. If the reader of this message is not an intended recipient, you are hereby notified that any review, use, dissemination, forwarding or copying of this message is strictly prohibited. Please notify us immediately by reply e-mail or telephone, and delete the original message and all attachments from your system. Thank you
_________________ Barry Hancock
www.worldwidewarbirds.com |
bu131(at)swbell.net Guest
Posted: Tue Feb 03, 2009 4:50 pm Post subject: Yak rudder pedal mod |
hello Barry: do they fit the 55?
I am still looking for more leg room
andres
From: Barry Hancock <bhancock(at)worldwidewarbirds.com>
To: yak-list(at)matronics.com
Sent: Tuesday, February 3, 2009 6:22:22 PM
Subject: Yak rudder pedal mod
Gang,
Happy Yakkin',
Barry
Barry Hancock
cell (949) 300-5510
Chino, CA 91710
Chino, CA 91710
bpx2horn(at)aol.com Guest
Posted: Tue Feb 03, 2009 4:52 pm Post subject: Yak rudder pedal mod |
Do they work on a 52TW?
Sent from my Verizon Wireless BlackBerry
Date: Tue, 3 Feb 2009 16:49:42 -0800 (PST)
To: <yak-list(at)matronics.com>
Subject: Re: Yak-List: Yak rudder pedal mod
andres
Subject: Yak-List: Yak rudder pedal mod
Gang,
Happy Yakkin',
Barry
Barry Hancock
cell (949) 300-5510
Chino, CA 91710
Chino, CA 91710
| Quote: | | _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The Yak-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?Yak-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - List Contribution Web Site - _-=3D Thank you for your generous support! _-=3D -Matt Dralle, List Admin. _-=3D --> http://www.matronics.com/contribution _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
barryhancock
Posted: Tue Feb 03, 2009 8:05 pm Post subject: Re: Yak rudder pedal mod |
The rudder pedal brackets are designed to fit the original pedal assemblies used in pneumatic systems. I don't know if the -55 has pneumatic brakes or not. They will not work in a -52TW, but will work on a -52TD, provided they are original brakes.
I believe I have someone willing to test the brackets on a -52 in the front seat in the next few weeks. So, we should have a definitive answer on the -52 front cockpit soon.
Cheers,
Barry
Posted: Wed Feb 04, 2009 4:43 am Post subject: Yak rudder pedal mod |
Speaking of rudder pedal mods, as most people know that have ridden in the back seat of a 52, the rudder pedals rearward travel is significantly less than the front cockpit.
If anyone wants more room leg room in the back cockpit of a 52, there is a fairly easy solution to make the rear rudder pedals adjust to the same travel distance as the front.
Remove the adjustment knob.
Remove the oval shaped cover plate just behind the knob by removing the two small screws that hold the cover plate to the assembly.
Reinstall the adjustment knob and the center screw. You will remove it again shortly.
Now pull the jack screw assembly forward using the adjuster knob.
At the back end of the jack screw you will see a metal sleeve about 5/8" in length. Slide this sleeve off the jack screw.
Slide the jack screw back into position.
Remove the adjustment knob again and slide the oval cover plate back into position and secure with the two small screws.
Reinstall the adjustment knob, locking tab and screw.
Now the rear cockpit rudder pedals will move approximately 2" further to the rear with the adjustment knob.
Do check for clearance between the back of the rudder pedal and the main spar. Adjust forward as necessary.
Dennis
