Lynn Matteson
Posted: Sun Feb 01, 2009 11:26 am Post subject: Elevator Gap Seal Test Report |
I just flew my plane today, and during the pre-flight I noticed that
the gap-seal tape...orange Racer's Tape...that I applied on 10-5-2008
is still holding fast. I wrote the date onto the tape to keep track
of how well it held up. The same tape that I applied earlier...God
knows when...is also still holding fas, so maybe we're overthinking
this gap-seal "problem." Of course, mine is applied over the top of
the gap and nothing underneath, so the purists among us...you know
who you are...would not buy this fix.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 1, 2009, at 11:32 AM, Noel Loveys wrote:
Or you could attach the seal, on the elevator side only with good
old 1 in.
Velcro.
Another thing to try is to cover the leading edge of the elevator
and rudder
with the plastic tape then attach the gap seal to that tape so when
you
remove the seal you don't disturb the dope under it.
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
rjdaugh
Posted: Sun Feb 01, 2009 2:02 pm Post subject: Elevator Gap Seal Test Report |
Mike,
Unless you get all the coats and cross coats of poly spray on it it won't
last more than a year or two in the sun. Maybe that is permanent enough,
but I worry that with all the flexing, and enough coats or polyspray, it
will crack.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Lynn Matteson
Posted: Sun Feb 01, 2009 2:22 pm Post subject: Elevator Gap Seal Test Report |
The "grass catcher" is the problem with either the "X" or the "Z" (or
"S") method of applying tape...whether you apply the tape from "under
the front to over the back" or vice versa, there will always be a
wedge of space that wants to collects debris. It's just harder to get
out of the "X" method. That's why I've contented myself with the
"over the front to over the back" method....yes it's aerodynamically
dirty, having a space underneath that can eddy air, but have we a
really "clean" plane otherwise?
Your diagrams are very understandable, Noel...good job. Lost
Saturday? : )
Lynn Matteson
Sensenich 62x46
On Feb 1, 2009, at 1:57 PM, Noel Loveys wrote:
Quote: | Sunday afternoon and I can visualize the X system easy now...
Friday nights
not the best night of the week for me;-).
I agree the X system allows for a light hinge on a model but a
place for
grass and leaves etc. To catch in the "Real thing".
What I was thinking at first was a couple of pieces of say 2 1/2
inch tape
sewn right down the middle and then one half of each tape doped to the
stabilizers with the other halves just finished to match the
plane. They
should be stiff enough to seal the gaps in flight. I'll attach a
couple of
rough diagrams... emphasis on the term rough!
Noel
N369LM |
matronics(at)bob.brennan. Guest
Posted: Sun Feb 01, 2009 3:02 pm Post subject: Elevator Gap Seal Test Report |
I'm glad to see someone else used the just-tape-over-the-top method. When
this topic came up a few months ago I noticed on a magazine cover picture of
my plane I have for my desktop that at that time it had black tape on the
top side of the stabiliser gap, which was not there when I bought the plane.
I assume it was wide electrical tape which is *everywhere* on the plane
including the leading edges and vertical stabiliser gap, and which I am
gradually replacing since it peels.
I was hesitant to post my method since no one else had admitted here to that
simple method. I used a yellow duct tape across the entire topside of the
gaps, installed with the elevator fully down. With the elevator up it tucks
neatly into the gap. I chose the top instead of the bottom so it would not
accumulate anything, and left the bottom open to see the hinges on
pre-flight.
So far it has lasted a season and made a difference to control authority on
the short-field-over-trees grass strip that I use. Before sealing the gap my
slowest approach speed was determined by when I started losing pitch control
versus stall speed, which made it tough to flare properly. Possibly the
under-cambered wings and smaller tail made the gap seals more noticeable on
a Model 2 than later Models.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
Lynn Matteson
Posted: Sun Feb 01, 2009 3:19 pm Post subject: Elevator Gap Seal Test Report |
I just tape up to the hinges, then tape again on the other side of
the hinge...all on the top-to-top surfaces...I'm gettin' too old to
bend down and look under there, Bob. : )
Lynn Matteson
Sensenich 62x46
On Feb 1, 2009, at 5:57 PM, Bob Brennan wrote:
<matronics(at)bob.brennan.name>
method. When
picture of
on the
the plane.
plane
I am
here to that
of the
it tucks
would not
pre-flight.
authority on
the gap my
pitch control
the
noticeable on
Wrightsville Pa
N369LM |
larry huntley
Posted: Sun Feb 01, 2009 3:24 pm Post subject: Elevator Gap Seal Test Report |
I did that with ski saver. Worked fin and not too complicated for my brain.
I can make decent 3pt landings with the Soob on front and no
flaps----Barely, But it works. Larry 4-1200 Soob
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Float Flyr
Posted: Sun Feb 01, 2009 5:00 pm Post subject: Elevator Gap Seal Test Report |
Not lost just out of town until later last night.
What did you think of the idea of using Velcro (just on the rudder) Would
make it easy to clean and also easy to remove the rudder for repairs due to
hangar rash.
I'm going to try a gap seal this spring when I get the plane out again. At
least on the rudder to try to give me more authority for slips. Those big
floats hanging three feet or more below the CG really want to right the
plane. So far I've been giving full ruddr and controlling the slip with the
ailerons. Even doing that the slip is more gentle than what I can get with
no problems from a C-172.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lowlead
Posted: Sun Feb 01, 2009 5:01 pm Post subject: Re: Elevator Gap Seal Test Report |
I use a 3M 3372 polyurethane surface protection tape applied on both top and bottom of the gap (previous posts shown as >-<). The tape is very tough and stays flexible for years. I recently changed mine after 10+ years of service. It was a little yellowed from the exhaust but it never peeled or lost adhesion.
I bought mine from mcmaster.com several years ago. They don't appear to list the clear tape online but I'm sure they can get it. A better deal might be the 3M 3372 tape sold by Aircraft Spruce in 12yd lengths for about $17. It appears to be the same tape I use and I *think* it might be the ski-saver tape mentioned in this post. Spruce sells different widths for protecting prop and flying surface leading edges.
http://www.aircraftspruce.com/catalog/cspages/protectiveLeading.php
I bought the 36yd roll from McMaster and found it handy to also stop chafing between the turtledeck and wing roots, chafing around the door skin and door frame, even between the upper cowl and base of windshield.
I have an Avid Mk4 and the 1" wide tape bridged the ~1/2" gap between the tail surfaces. It also comes in 2", 3", 4" widths. It has a paper peel-off over the adhesive side that can be marked with a sharpie in case one would want to trim the width with scissors. It also peels off the fabric with no damage or adhesive residue (mine fabric is painted with Stits Aerothane).
The photo shows a small section, tape on both sides of the stab/elevator, (and I see I should have cleaned the hinge before I took the photo ). BTW the tape is not cracked, it's a reflection, the tape is glossy.
Dan H.
Description: |
Filesize: |
78.88 KB |
Viewed: |
848 Time(s) |
Lynn Matteson
Posted: Sun Feb 01, 2009 5:30 pm Post subject: Elevator Gap Seal Test Report |
That's a good-looking job, LL.
Lynn Matteson
Sensenich 62x46
N369LM |
rexinator
Posted: Sun Feb 01, 2009 8:17 pm Post subject: Elevator Gap Seal Test Report |
That's exactly what I was trying to describe with my >-< symbol and my
little drawn image file. I agree with Lynn that it's a nice job. Can
you elaborate on how you applied so well?
Rex
Colorado M2/582
Lowlead
Posted: Sun Feb 01, 2009 11:46 pm Post subject: Re: Elevator Gap Seal Test Report |
Thanks Rex (and Lynn)! I wish I could say that it's this consistent along the entire length of the gap, but it's not. The gaps tend to be smaller on the outboard ends due to the way the tightened fabric act on the stab and elevator frames.
Installation is hard to describe but not that hard to do. One thing nice about this tape is that it's very pliable and the adhesive is not super-aggressive at first. The tape is applied across the gap (we'll say the top side first) with a very slight 'drape' down and then firmly pressed onto the LE/TE tubes. Then the bottom side tape is applied with a very slight drape up (I used a pc of 1/4" tube to force the drape up) and then pressed onto the LE/TE tubes. The two tapes stick to one another like a champ but leaves a triangular 'bubble' running the entire length . I used a wooden tongue depressor and fingers to press the top and bottom tapes together to eliminate the bubble. (see attached). It's tough stuff and stretches well enough to get a tight installation. There's no worries about tearing or punching through with the tongue depressor.
The control surface (elevator or rudder) must be in the neutral position when tape is applied or else a tension 'bias' might get built into the installation (ex: rudder now pulls left or right due to tape..)
Hope this makes sense...
Dan H.
rexinator wrote: | That's exactly what I was trying to describe with my >-< symbol and my
Rex
Colorado M2/582
Description: |
Filesize: |
29.61 KB |
Viewed: |
744 Time(s) |
lowflyer
Posted: Mon Feb 02, 2009 7:03 am Post subject: Re: Elevator Gap Seal Test Report |
Guys,
Please take a look at the following website.
http://www.aerographic.com/gap_seal.htm
These gap seals are used on Pitts and Eagle aircraft. They have been used on many others as well. There not too expensive, easy to install and they are removable and should last a long, long time! You can cut to length for your application and for fitting around hinges. My buddy uses them on his beautiful Pitts S2B. I will probably be getting some soon.
Chris Budd
N53RJ Kitfox IV Speedster
VW 2180 240hrs
Dick Maddux
Posted: Mon Feb 02, 2009 7:05 am Post subject: Elevator Gap Seal Test Report |
Lowlead,
That looks like an "X" job and a good one at that. I will have to try that when mine peels off.
Dick Maddux
Pensacola,Fl
Stay up to date on the latest news - from sports scores to stocks and so much more.
rexinator
Posted: Mon Feb 02, 2009 7:34 am Post subject: Elevator Gap Seal Test Report |
I think had a small sample sheet of this material back in 1984 which I
used to protect the front of a "chin" fairing on my Honda Interceptor.
It had the characteristics you describe, clear, very tough, designed for
protecting front of sporty cars paint from small rock chips.
Rex
Colorado M2/582
Dan H.
> Rex
> Colorado M2/582
http://forums.matronics.com/viewtopic.php?p 28125#228125
http://forums.matronics.com//files/gapseal2_183.jpg
darinh
Posted: Mon Feb 02, 2009 9:38 am Post subject: Re: Elevator Gap Seal Test Report |
John,
As some have said, use the 3M clear product. I would bet you can find a car accessory shop that applies the "clear bra" to cars and they will sell you this stuff by the foot. I found several local places that had it in widths of 6", 12", 24", etc. I bought the 24" wide stuff and cut it to the length and width I needed for the intended use. I also applied it to the top side and wrapped it around the front of my landing gear for protection and to the front of the struts for about the first 4' from the fuse.
The product is very tough, UV resistant and crystal clear...the adhesive works perfectly on painted surfaces and can be applied using a shot or two of Windex and a small squeegee to remove any air bubbles
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Dick Maddux
Posted: Tue Feb 03, 2009 5:38 am Post subject: Elevator Gap Seal Test Report |
Chris,
I tried to request a sample from that gap seal website in England but it wouldn't work. I suspect they are out of business as it is an old website. The stuff looks good and I sure would like to try a sample.
Dick Maddux
Pensacola,Fl
patreilly43(at)hotmail.co Guest
Posted: Tue Feb 03, 2009 6:40 am Post subject: Elevator Gap Seal Test Report |
Dick & Chris C I tried to order a sample also. I had same result as you did Dick.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Tue C 3 Feb 2009 08:30:49 -0500
Subject: Re: Elevator Gap Seal Test Report
Chris C
Dick Maddux
Pensacola CFl
Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
