ski saver
larry huntley
PostPosted: Sun Feb 01, 2009 5:39 pm    Post subject: ski saver Reply with quote
Just received this. Does it sound like the same material? Larry
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
patreilly43(at)hotmail.co
PostPosted: Sun Feb 01, 2009 6:11 pm    Post subject: ski saver Reply with quote
Larry C Thanks for the web link. I ordered 5 feed just to have on hand. That price for 14" wide clear tape is unreal. There are many times I wanted some of that tape to protect paint on a car C motorcycle tank C etc. I'll use it on the gap seal C Alla Lynn Matteson top side only. Lynn C if that curls down into the gap C rather than up C I don't know why anybody would use any other method.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: asq(at)roadrunner.com
Subject: Fw: ski saver
Date: Sun C 1 Feb 2009 20:38:03 -0500
--> Kitfox-List message posted by: "Larry Huntley" <asq(at)roadrunner.com>
akflyerbob
PostPosted: Sun Feb 01, 2009 6:49 pm    Post subject: Re: ski saver Reply with quote
Larry
What material are you talking about?
I'm sure every one would like to know.
Bob Wolfe..Soldotna, Alaska
KF Mod I and III
jbonewitz
PostPosted: Sun Feb 01, 2009 9:18 pm    Post subject: ski saver Reply with quote
We have a winner! I'm going to order some of this stuff. There are probably lots of other uses besides gap seal.
John Bonewitz
Series 5
On Sun, Feb 1, 2009 at 7:38 PM, Larry Huntley <asq(at)roadrunner.com (asq(at)roadrunner.com)> wrote:
[quote]--> Kitfox-List message posted by: "Larry Huntley" <asq(at)roadrunner.com (asq(at)roadrunner.com)>
Lynn Matteson
PostPosted: Mon Feb 02, 2009 6:02 am    Post subject: ski saver Reply with quote
I think the amount of "curl down" can be controlled by the amount
that you press down between the tubes themselves....simply press more
into the gap before pressing onto the tubes and it should stay there.
I usually just lay it over the gap equally spaced on both sides and
press it down. I didn't get too worried about whether it went up or
down, although down would be preferred.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 1, 2009, at 9:08 PM, patrick reilly wrote:
[quote] Larry, Thanks for the web link. I ordered 5 feed just to have on
times I wanted some of that tape to protect paint on a car,
motorcycle tank, etc. I'll use it on the gap seal, Alla Lynn
Matteson top side only. Lynn, if that curls down into the gap,
rather than up, I don't know why anybody would use any other method.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> To: kitfox-list(at)matronics.com
> Date: Sun, 1 Feb 2009 20:38:03 -0500
Lynn
Kitfox IV-Jabiru 2200
N369LM
oscardog
PostPosted: Mon Feb 02, 2009 10:54 am    Post subject: ski saver Reply with quote
Didn't you guys see my post from 1 or 2 days ago where I talked about my use of Ski Saver Tape and where to get it ??
George
PostPosted: Mon Feb 02, 2009 5:09 pm    Post subject: ski saver Reply with quote
Lynn C Didn't you say you have elavator at full down and then apply tape. This wouldn't require any pushing tape into groove. Or would having some tape pushed into groove insure the tape would curl into the groove when elevator was raised?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: lynnmatt(at)jps.net
Subject: Re: Kitfox-List: Fw: ski saver
Date: Mon C 2 Feb 2009 08:58:20 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
down C although down would be preferred.
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 605 hrs
Sensenich 62x46
> do not archive
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford C IL
Lynn Matteson
PostPosted: Mon Feb 02, 2009 7:02 pm    Post subject: ski saver Reply with quote
I put my tape on at full down, yes, and like you observed, just
having a little "down into" radius will assure that it stays there
when the 'vator is raised. I may try to apply some from the bottom
side with the 'vator held up, and see how that works...along with the
top being covered.
Lynn Matteson
Sensenich 62x46
On Feb 2, 2009, at 8:06 PM, patrick reilly wrote:
Lynn, Didn't you say you have elavator at full down and then apply
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Lynn
N369LM
PostPosted: Mon Feb 02, 2009 7:20 pm    Post subject: ski saver Reply with quote
Lynn C I was also wondering how covering both sides with your method of full elevator up and down would work. I'm not to that stage yet. As a matter of fact I received today the RAC servo from ACS to use with Lowell Fitts trim tab kit. So C I will be tearing my elevator apart.  Have you got a trim tab on the elevator? Or C do you use the Flaperons to trim?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: Re: Fw: ski saver
Date: Mon C 2 Feb 2009 22:01:43 -0500
I put my tape on at full down C yes C and like you observed C just
side with the 'vator held up C and see how that works...along with the
top being covered.
Lynn Matteson
Sensenich 62x46
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford C IL
&g=======
Lynn Matteson
PostPosted: Mon Feb 02, 2009 7:33 pm    Post subject: ski saver Reply with quote
Factory-built trim tab with RAC servo. Using the flaperons for trim
slows the plane down, which is why one of the Speedster mods was the
electric trim.
Lynn Matteson
Sensenich 62x46
On Feb 2, 2009, at 10:19 PM, patrick reilly wrote:
Lynn, I was also wondering how covering both sides with your method
with Lowell Fitts trim tab kit. So, I will be tearing my elevator
apart. Have you got a trim tab on the elevator? Or, do you use the
Flaperons to trim?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Lynn
N369LM
Dick Maddux
PostPosted: Tue Feb 03, 2009 5:17 am    Post subject: ski saver Reply with quote
Patrick,
You will love that elevator trim tab of Lowell's ! It makes the Kitfox a new airplane ! I have the trim switch(witches hat) on the top of my stick and use it constently. Flaps never come into play for triming purposes as they used too. Best investment I ever made !
        Dick Maddux
        Pensacola,Fl
Stay up to date on the latest news - from sports scores to stocks and so much more.
 Filesize:  361.89 KB
 Viewed:  776 Time(s)
PostPosted: Tue Feb 03, 2009 6:52 am    Post subject: ski saver Reply with quote
Dick C Thanks for the picture I am about to leave for the hanger to pick up my elevator. I will tear into it today. I figure the cost will be about $450 give or take a few. What electrical wire did you use and what was the source?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Tue C 3 Feb 2009 08:16:37 -0500
Subject: Re: ski saver
Patrick C
                                                        Dick Maddux
                                                        Pensacola CFl
