jbonewitz
Joined: 24 Jan 2009 Posts: 17 Location: Grapevine, Texas, USA
Posted: Fri Jan 30, 2009 3:11 pm Post subject: Elevator Gap Seal Test Report |
Some Great ideas on Gap Seal materials. Thanks to all of you.
I remember the Ski Tape conversation from years ago. Couldn't find it then. Can't find it now. Figured it was a Texas thing. I really like the idea of the shelf liner. Easy to get, and cheap. If it's lasted 12 years, that's good enough for me! The 3-M material is probably the very best way to go. Their products have never let me down, but I'm sure it will be expensive. The good news is that the mod is so easy to do that if one thing doesn't work, I can just try another.
Someone gave me a roll of heavy, semi-clear tape that they bought from Spruce. It was pretty rubbery and very strong, but even one layer of it was milky. I never applied it because of this. I think I'm going to start with the shelf liner.
I never intended to keep the duct tape on precisely because of the issue some of you described. When it drys out, it's a mess. I almost pulled it off after I flew yesterday, but since the plane is in a hangar, I figured I'd wait a little longer.
When I re-do it, I'll take pictures for you who are interested. How are you guys handling pictures on the list? Are you just sending them as attachments? or do I need to link to a Flickr account or something?
Thanks again,
John Bonewitz
Series 5
jbonewitz
Posted: Fri Jan 30, 2009 3:19 pm Post subject: Elevator Gap Seal Test Report |
Guy, I thought about using packing tape, but wondered how it would hold up to UV. This Sailrite.com ripstop nylon repair tape looks pretty interesting. It's not meant as a permanent repair, so I don't know how it would hold up over time, but it's only $7.50 a roll. It also looks pretty thin (you can actually see though it). Two layers ought to be strong as all get out, but lightweight and flexible too.
John Bonewitz
Series 5
On Fri, Jan 30, 2009 at 1:41 PM, Guy Buchanan <bnn(at)nethere.com (bnn(at)nethere.com)> wrote:
[quote] --> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com (bnn(at)nethere.com)>
At 06:54 PM 1/29/2009, you wrote:
Quote: | What should I replace the duct tape with? One thought was to purchase some vinyl sign material (the stuff they cut letters out of to put on banners or vehicles) pre-cut to the width I need. Though not as thick as duct tape, it is strong and should hold up to the elements. Any other suggestions?
I use clear heavy duty packing tape. You could also look on www.sailrite.com for colored sail repair tape. I found the gap seal made a significant difference, but in an insignificant configuration. When I 3-point full flaps I can't get the tailwheel on the ground first without the gap seal. With- it's easy.
Guy Buchanan
San Diego, CA
st" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
jbonewitz
Posted: Fri Jan 30, 2009 3:34 pm Post subject: Elevator Gap Seal Test Report |
Paul,
Regarding placement of the tape. I went from top of stab. to bottom of elevator, but in reality, the tape edge starts about where the radius of the trailing edge tube begins. The tape really doesn't show on top of the stab. In fact if it were color matched, it would barely show. Whether to start on the bottom rather than the top? Probably doesn't matter.
As to whether any exposed adhesive would attract dirt? I don't really think it will be a problem. I suppose it kind of depends on the tape you use.
I promise I'll get some pictures for you guys.
John Bonewitz
Series 5
On Fri, Jan 30, 2009 at 11:53 AM, Paul Franz - Merlin GT <paul(at)eucleides.com (paul(at)eucleides.com)> wrote:
[quote] --> Kitfox-List message posted by: "Paul Franz - Merlin GT" <paul(at)eucleides.com (paul(at)eucleides.com)>
On Fri, January 30, 2009 7:28 am, kirk hull wrote:
> Does anybody have pictures of the gap seal installation?
I too would be interested in seeing photos. I'm interested in details of shape,
overlap and what happens to the slack when you run neutral or down elevator.
Does the slack start to peel a tiny bit on either the stabilizer or the elevator with
dirt and debris sticking to the small exposed bit of adhesive?
Which way is better to put them on - leading edge on top or bottom of the stabilizer?
I assume this is determined by which elevator position you want when the gap seal is
tight and is determined by position.
Pictures would really help me see what's being done too.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
MS -
e -
Lynn Matteson
Posted: Fri Jan 30, 2009 4:03 pm Post subject: Elevator Gap Seal Test Report |
If you want stickier...not sure of durable...and uglier, use Gorilla
tape. You will be cussing just trying to get it off the roll!
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 30, 2009, at 5:06 PM, John Bonewitz wrote:
Quote: | Permanent, yes, but I'm not sure how easy it would be to do. For
starters I'd need some fabric. Haven't seen any of that laying
around for about nine years. I would also have to paint it. No, I
think tape will do the trick. I just need something more durable
than duct tape.
On Fri, Jan 30, 2009 at 2:18 PM, JetPilot <orcabonita(at)hotmail.com>
wrote:
Why not just use a piece of PolyFiber attached with Polytack to
seal the gap ??? It would be permanent, easy to do, and look
good ! Much better than tape.
"NO FEAR" - If you have no fear you did not go as fast as you
could have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p 27727#227727
MS -
e -
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Fri Jan 30, 2009 5:37 pm Post subject: Elevator Gap Seal Test Report |
Lynn:
do you have a picture or drawing of the X system?
Second inbibation is starting to cut in and I'm having a problem visualizing your X setup.
Noel
--- On Fri, 1/30/09, Lynn Matteson <lynnmatt(at)jps.net> wrote:
[quote]From: Lynn Matteson <lynnmatt(at)jps.net>
Subject: Re: Elevator Gap Seal Test Report
Received: Friday, January 30, 2009, 6:11 PM
[quote]--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
If you really want to drive yourself nuts over this gap sealing issue, try the
"X" method instead of the "Z" method. We used the
"X" method on our model planes.
The "Z" method has been explained....from under (or over) the
trailing portion of the hort. stab, to over (or under) the leading portion of
the elevator, forming a "Z" when view from the side. The "X"
method is just alternating the placement of lengths of 2" wide tape, over
and under, then under and over, etc., until the gap is sealed. In the
"X" method, you make strips of tape that go, say, 2" wide and
from front to back, instead of the "Z" method where you run the tape
from side of elevator to hinge, then hinge to hinge, and so on.
The jury is still out on whether this is a good method or not...how 'bout
some thoughts?
As an aside, when this method is used in model planes, no hinge is needed, as
the plastic covering material itself is used for the "gap seals" and
in using the "X" method, the elevator operates freely without the use
of hinges...not recommended for "live-in" airplanes.
Lynn Matteson
Sensenich 62x46
On Jan 30, 2009, at 12:53 PM, Paul Franz - Merlin GT wrote:
Quote: | --> Kitfox-List message posted by: "Paul Franz - Merlin GT"
<paul(at)eucleides.com>
of shape,
Quote: | overlap and what happens to the slack when you run neutral or down
elevator.
elevator with
[quote] dirt and debris sticking to the small exposed bit of adhesive?
Which way is better to put them on - leading edge on top or bottom of Get the name you've always wanted ! (at)ymail.com or (at)rocketmail.com. [quote][b]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
propellerdesign(at)tele2. Guest
Posted: Fri Jan 30, 2009 11:56 pm Post subject: Elevator Gap Seal Test Report |
You can use that, but why not take 2 pieces sewn together at the middle and
dope one Vee to stab and other to elevator.
Or use sail fabric that is air tight from start
Jan
Lynn Matteson
Posted: Sat Jan 31, 2009 3:53 am Post subject: Elevator Gap Seal Test Report |
Nope, no picture or drawing. Just visualize...after the inbibation
wears off....the flat surface of the stab and elevator, as viewed
from the side/edge, with the tape starting on the top left, and
crossing to the bottom right. (This of course assumes that you have
properly made the tape with an inch of the sticky surfaces against
each other so that the tape can be stuck down on the top left and
the bottom right) Now another tape from the bottom left crossing to
the top right. Where they pass by each other, they form an "X". Then
imagine a piece of tape 2" wide being placed from top of stab to
bottom of elev. (top left to bottom right), and next to it another
tape placed from bottom left to top right. Continue alternating tapes
until gap is sealed. I can imagine how this would look on a full-size
plane, and I don't like what I imagine. It worked fine on the models
and looked ok, and made an especially lightweight hinge. I personally
don't like the idea of this "over and under" tape application, as it
always leaves a place where junk can collect, no matter which way you
do it. I much prefer to let the elevator hang down, apply the tape
across the gap, and leave it at that. I use "racer's tape" that I
ordered in orange, which is the color of my plane in that area...the
color is not a perfect match...however, I can't see that mismatch
when I'm flying and neither can anybody else. The owners of "hangar
queens" would not like my reasoning, I'm sure.
Lynn Matteson
Sensenich 62x46
Noel
issue, try the
portion of
tape, over
'bout
some thoughts?
needed, as
Lynn Matteson
Sensenich 62x46
details
of shape,
elevator.
or the
elevator with
(at)rocketmail.com. _-
N369LM |
Lynn Matteson
Posted: Sat Jan 31, 2009 3:59 am Post subject: Elevator Gap Seal Test Report |
Good idea, but I'm from the camp that always wants to be able to take
something apart if a problem arises. I guess if a rock passed through
the elevator, you could always MEK the Vee off from the elevator, and
maybe reattach it when the repairs were made. A longer process, by
far, than the tape method, but cleaner-looking.
Lynn Matteson
Sensenich 62x46
On Jan 31, 2009, at 2:37 AM, JC Propeller Design wrote:
<propellerdesign(at)tele2.se>
middle and dope one Vee to stab and other to elevator.
Jan
N369LM |
hflynn46531(at)yahoo.com Guest
Posted: Sat Jan 31, 2009 4:16 am Post subject: Elevator Gap Seal Test Report |
A really good source for gap seal tape is found at (WINGS AND WHEELS Soaring Supplies ) They have everthing that you will ever need for gap seals.
From: JC Propeller Design <propellerdesign(at)tele2.se>
Sent: Saturday, January 31, 2009 2:37:53 AM
Subject: Re: Re: Elevator Gap Seal Test Report
--> Kitfox-List message posted by: "JC Propeller Design" <propellerdesign(at)tele2.se (propellerdesign(at)tele2.se)>
Jan
Posted: Sat Jan 31, 2009 4:24 am Post subject: Elevator Gap Seal Test Report |
A really good source for gap seal tape is (WINGS AND WHEELS soaring supplies) They have everthing that you need.
Sent: Friday, January 30, 2009 6:45:02 PM
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
If you want stickier...not sure of durable...and uglier, use Gorilla tape. You will be cussing just trying to get it off the roll!
Lynn Matteson
Sensenich 62x46
[quote] Permanent, yes, but I'm not sure how easy it would be to do. For starters I'd need some fabric. Haven't seen any of that laying around for about nine years. I would also have to paint it. No, I think tape will do the trick. I just need something more durable than duct tape.
On Fri, Jan 30, 2009 at 2:18 PM, JetPilot <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)> wrote:
--> Kitfox-List message posted by: "JetPilot" <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)>
Why not just use a piece of PolyFiber attached with Polytack to seal the gap ??? It would be permanent, easy to do, and look good ! Much better than tape.
[url=http://forums.matronics.com/viewtopic.php?p 27727#227727]http://forums.matronics.com/viewtopic.php?p 27727#227727[/url]
MS -
e -
Guy Buchanan
Posted: Sat Jan 31, 2009 6:58 am Post subject: Elevator Gap Seal Test Report |
At 03:03 PM 1/30/2009, you wrote:
Quote: | Guy, I thought about using packing tape, but wondered how it would
hold up to UV.
It works OK. I replace it about once a year or so. You have to make
sure it's the heavy duty stuff. Oh yes, we also discovered that it
doesn't stick very well unless the paint's really shiny in that area.
It wouldn't stick to my friend's Poly-tone finish. I suspect sail
repair tape would work much better there.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
rexinator(at)gmail.com Guest
Posted: Sat Jan 31, 2009 10:13 am Post subject: Elevator Gap Seal Test Report |
So has anyone thought of applying tape top and bottom with the adhesive
fully contacting each other in the gap? Something like this: >-<
It would be very difficult to do well unless you could design and
fabricate a special tool, but I think it could be done. I'm imagining
careful measurement of your gap and tape width then positioning the tape
on one side correctly such that it would allow the other side to be
applied and close all of the gap with no significant spaces or air bubbles.
I think a perfect tool might be a stiff rubber block shaped to follow
the half cross section of the intended gap seal. After the 1st side of
tape has been applied (bottom?) then the block could be clamped on that
side to hold the applied tape in the proper shape it would retain for
the gap if the other side was already installed. Then it should be
possible to lay the upper tape like positioning a large pre-cut decal.
Here's an attempt of a drawing of the cross section with the tape red,
block shape in black and a clamping bar in green.
Gap seal image
Anybody following my attempt to describe this concept?
Rex Hefferan
Colorado M2/582
Lynn Matteson wrote:
wears off....the flat surface of the stab and elevator, as viewed from
the side/edge, with the tape starting on the top left, and crossing to
the bottom right. (This of course assumes that you have properly made
the tape with an inch of the sticky surfaces against each other so
that the tape can be stuck down on the top left and the bottom right)
Now another tape from the bottom left crossing to the top right. Where
they pass by each other, they form an "X". Then imagine a piece of
tape 2" wide being placed from top of stab to bottom of elev. (top
left to bottom right), and next to it another tape placed from bottom
left to top right. Continue alternating tapes until gap is sealed. I
can imagine how this would look on a full-size plane, and I don't like
what I imagine. It worked fine on the models and looked ok, and made
an especially lightweight hinge. I personally don't like the idea of
this "over and under" tape application, as it always leaves a place
where junk can collect, no matter which way you do it. I much prefer
to let the elevator hang down, apply the tape across the gap, and
leave it at that. I use "racer's tape" that I ordered in orange, which
is the color of my plane in that area...the color is not a perfect
match...however, I can't see that mismatch when I'm flying and neither
can anybody else. The owners of "hangar queens" would not like my
Lynn Matteson
Sensenich 62x46
> Lynn:
> Noel
> To: kitfox-list(at)matronics.com
> issue, try the
> portion of
> over
> 'bout
> some thoughts?
> needed, as
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> of shape,
> elevator.
> the
> elevator with
oscardog
Posted: Sat Jan 31, 2009 10:59 am Post subject: Elevator Gap Seal Test Report |
-- Hi List -- Back in late 05 and again last year I bought Ski Tape from Tognar Toolworks In Oregon.
I have used it on 3 planes and it works great and stands up well.
You can contact them as follows:
Tognar.com
1-800-299-9904
E-Mail --- Info(at)Tognar.com (Info(at)Tognar.com)
I hope this helps !
George --
KF5 100Hp Rotax
KCOE
Lynn Matteson
Posted: Sat Jan 31, 2009 12:27 pm Post subject: Elevator Gap Seal Test Report |
I'm following you, Rex...I just don't see the drawing, just the >-<
that you typed in...and that's basically what I tried to describe
with the top left-to-bottom right explanation that was confusing me,
let alone others. But why any tape at all, if a rubber/neoprene/
whatever block could be made that would fill the gap and be wedged
into place, loose enough to allow movement, but not blow out?
Something shaped like two "C's" in cross section, back-to-back with
an "O" between them, more or less. The tops of the "C's" could be
tangent to one another if that wouldn't make the device too stiff and
want to pop out of the gap. It could be made of extruded rubber and
sold by the foot.
Lynn Matteson
Sensenich 62x46
On Jan 31, 2009, at 12:55 PM, Rexinator wrote:
adhesive fully contacting each other in the gap? Something like
this: >-<
imagining careful measurement of your gap and tape width then
positioning the tape on one side correctly such that it would allow
the other side to be applied and close all of the gap with no
follow the half cross section of the intended gap seal. After the
1st side of tape has been applied (bottom?) then the block could be
clamped on that side to hold the applied tape in the proper shape
it would retain for the gap if the other side was already
installed. Then it should be possible to lay the upper tape like
red, block shape in black and a clamping bar in green.
Gap seal image
Rex Hefferan
Colorado M2/582
N369LM |
jbonewitz
Posted: Sat Jan 31, 2009 7:07 pm Post subject: Elevator Gap Seal Test Report |
I saw what you describe just today. The guy had a strip of this stuff that the Pitts guys use. Problem is, our gap is too wide to use it.
John Bonewitz
Series 5
On Sat, Jan 31, 2009 at 2:09 PM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I'm following you, Rex...I just don't see the drawing, just the >-< that you typed in...and that's basically what I tried to describe with the top left-to-bottom right explanation that was confusing me, let alone others. But why any tape at all, if a rubber/neoprene/whatever block could be made that would fill the gap and be wedged into place, loose enough to allow movement, but not blow out? Something shaped like two "C's" in cross section, back-to-back with an "O" between them, more or less. The tops of the "C's" could be tangent to one another if that wouldn't make the device too stiff and want to pop out of the gap. It could be made of extruded rubber and sold by the foot.
Lynn Matteson
Sensenich 62x46
Quote: | --> Kitfox-List message posted by: Rexinator <rexinator(at)gmail.com (rexinator(at)gmail.com)>
So has anyone thought of applying tape top and bottom with the adhesive fully contacting each other in the gap? Something like this: >-<
It would be very difficult to do well unless you could design and fabricate a special tool, but I think it could be done. I'm imagining careful measurement of your gap and tape width then positioning the tape on one side correctly such that it would allow the other side to be applied and close all of the gap with no significant spaces or air bubbles.
I think a perfect tool might be a stiff rubber block shaped to follow the half cross section of the intended gap seal. After the 1st side of tape has been applied (bottom?) then the block could be clamped on that side to hold the applied tape in the proper shape it would retain for the gap if the other side was already installed. Then it should be possible to lay the upper tape like positioning a large pre-cut decal.
Here's an attempt of a drawing of the cross section with the tape red, block shape in black and a clamping bar in green.
Gap seal image
Rex Hefferan
Colorado M2/582
MS -
e -
MDKitfox(at)aol.com Guest
Posted: Sat Jan 31, 2009 8:01 pm Post subject: Elevator Gap Seal Test Report |
On Jan 31, 2009, at 9:51 PM, John Bonewitz wrote:
Quote: | I saw what you describe just today. The guy had a strip of this stuff that the Pitts guys use. Problem is, our gap is too wide to use it.
John Bonewitz
Series 5
Just a thought, but, how about strips of window/door insulation between the hinge points. The type of weatherstriping that has a tape strip on one side. I use it on a golf cart to keep the windshield from rattling. It also keeps water out, why not air?
It could be attached lengthwise on the horizontal stab, and with the appropriate thickness, press against the leading edge of the elevator. The foam would be squeezed to make a relatively air tight joint. The end against the elevator is slick and won't provide any substantial resistance to the movement of the elevator.
Just a thought.
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
thesupe(at)hotmail.com Guest
Posted: Sat Jan 31, 2009 10:03 pm Post subject: Elevator Gap Seal Test Report |
Funny that you should mention this C as I was just about to post what I've used on my Avid Flyer gaps. It is a foam weatherstriping that measures about 3/8" X 1/2" and has a sticky edge on one side. I stuck the foam to the front of the gaps. It seemed to work just fine and I did notice some improvement in the airplane's handling. Jim Chuk Avid MK IV Mn
Subject: Re: Kitfox-List: Elevator Gap Seal Test Report
Date: Sat C 31 Jan 2009 22:41:17 -0500
On Jan 31 C 2009 C at 9:51 PM C John Bonewitz wrote:
Quote: | I saw what you describe just today. The guy had a strip of this stuff that the Pitts guys use. Problem is C our gap is too wide to use it.
John Bonewitz
Series 5
Just a thought C but C how about strips of window/door insulation between the hinge points. The type of weatherstriping that has a tape strip on one side. I use it on a golf cart to keep the windshield from rattling. It also keeps water out C why not air?
It could be attached lengthwise on the horizontal stab C and with the appropriate thickness C press against the leading edge of the elevator. The foam would be squeezed to make a relatively air tight joint. The end against the elevator is slick and won't provide any substantial resistance to the movement of the elevator.
Just a thought.
Rick Weiss
N39RW Series V Speedster C 912ULS
SkyStar S/N 1
Port Orange C FL
= Quote: |
Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
| Windows Live™: E-mail. Chat. Share. Get more ways to connect. See how it works.
Dick Maddux
Posted: Sun Feb 01, 2009 6:37 am Post subject: Elevator Gap Seal Test Report |
That foam weather striping sounds like a good idea. You could further refine this by putting a strip of teflon antichafe tape on the other side of the weather striping foam(oposite the adhesive side) or on the elevator leading edge for that mater. This stuff is real slick and I bought a roll of it from Spruce as a cowling chafe tape a while back. It works real well.
Only thing is, in the heat the adhesive on weather strip tends to give way into a goo.
That sailplane tape looks interesting also
Dick Maddux
Pensacola,Fl.
From Wall Street to Main Street and everywhere in between, stay up-to-date with the [url=http://aol.com?ncid=emlcntaolcom00000023 ]latest news[/url].
Float Flyr
Posted: Sun Feb 01, 2009 9:01 am Post subject: Elevator Gap Seal Test Report |
Or you could attach the seal, on the elevator side only with good old 1 in.
Velcro.
Another thing to try is to cover the leading edge of the elevator and rudder
with the plastic tape then attach the gap seal to that tape so when you
remove the seal you don't disturb the dope under it.
Noel
Kitfox III-A
Float Flyr
Posted: Sun Feb 01, 2009 11:09 am Post subject: Elevator Gap Seal Test Report |
Sunday afternoon and I can visualize the X system easy now... Friday nights
not the best night of the week for me;-).
I agree the X system allows for a light hinge on a model but a place for
grass and leaves etc. To catch in the "Real thing".
What I was thinking at first was a couple of pieces of say 2 1/2 inch tape
sewn right down the middle and then one half of each tape doped to the
stabilizers with the other halves just finished to match the plane. They
should be stiff enough to seal the gaps in flight. I'll attach a couple of
rough diagrams... emphasis on the term rough!
Noel
Description: |
Filesize: |
107.66 KB |
Viewed: |
495 Time(s) |
Kitfox III-A
