pasj66
Joined: 28 Jan 2009 Posts: 7 Location: Gothenburg, Sweden (ESGI)
Posted: Wed Jan 28, 2009 12:25 pm Post subject: 914 w/intercooler induction air heating |
Hi all,
I am searching for some info on the temperature difference between airbox temperature and ambient during flight. JAR 23.1093 states if the temperature rise is more than 56 deg C when ambient temperature is -1 deg C at 60 % power there is no need for carb heating. In JAR-VLA 1093 the temperature rise should be 38 deg C with the same conditions. Has anyone with a 914 w/intercooler done some flight tests? Installing carb heating is a bit of a hassle so I hope anyone have done these tests to find out whether it is necessary. If anyone can share their findings that would be most helpful.
Best regards
Patrik
(MCR R100 914 w/intercooler 85 % finished)
_________________ MCR R100, R914UL3 W/IC |
Gilles.Thesee(at)ac-greno Guest
Posted: Wed Jan 28, 2009 2:06 pm Post subject: 914 w/intercooler induction air heating |
Patrick and all,
| Quote: | I am searching for some info on the temperature difference between airbox temperature and ambient during flight. JAR 23.1093 states if the temperature rise is more than 56 deg C when ambient temperature is -1 deg C at 60 % power there is no need for carb heating. In JAR-VLA 1093 the temperature rise should be 38 deg C with the same conditions. Has anyone with a 914 w/intercooler done some flight tests? Installing carb heating is a bit of a hassle so
Remember those rules have been written by people used to Lyco/Conti
aircooled engines, with hot air as the sole means of avoiding carb ice.
We are flying an MCR 4s with an intercooled 914. Due to our engine
installation peculiarities, our carb temperatures are within the 40-50°C
range in flight. Whatever the air temperature, remember ice cannot build
up on warm metal.
But it all depends on your particular engine installation.
With a proper airbox around the air filter, it is no big deal to devise
a warm air door into the engine compartment.
FWIW,
Best regards,
Gilles
http://contrails.free.fr
rparigor(at)suffolk.lib.n Guest
Posted: Wed Jan 28, 2009 3:30 pm Post subject: 914 w/intercooler induction air heating |
Hi Gilles"our carb temperatures are within the 40-50°C range in flight. Whatever the air temperature, remember ice cannot build up on warm metal."Curiosity question, what is your carb temperature when you pull power to a low power setting or idle and you let the wind turn propellor (turbo not doing much in the way of rammin and jammin / hence warming and the intercooler is bringing down any rise in temp caused by turbo closer to ambient)?Have you ever gotten carb ice?If yes did making some BTUs cure it?Thx.Ron Parigoris [quote][b]
chunk(at)xtra.co.nz Guest
Posted: Wed Jan 28, 2009 8:42 pm Post subject: 914 w/intercooler induction air heating |
Hi guys,
Apparently a 914 powered MCR generates more ambient heat in the engine cowling than the 912 S powered MCR ULC that I have. I have attached a temp. probe to a carburator body and it never rises above 25 degrees C during what appears to be carb ice conditions. If the temp. ever starts to fall below 19 degrees, (displayed on the panel) I know it is time to activate carb heat. I leave it on until the temp. rises above 23 degrees again. As you note, ice will not stick on warm metal.
Here in New Zealand we sometimes have quite pronounced carb ice conditions. After 3 such forced landing events without a carb heat facility I fitted a flap to close off the outside ram air just to have some control over the situation. It is now quite interesting watching the correlation between the rising temp in the airbox, which I also moniter, and the temp of the carb body. Takes a few minutes sometimes - but it is less stressful than looking for somewhere to land with no noise up front!
Evan Gardiner
I am using the Free version of SPAMfighterWe are a community of 5.9 million users fighting spam.SPAMfighter has rot have this message [quote][b]
pasj66
Posted: Wed Jan 28, 2009 11:14 pm Post subject: Re: 914 w/intercooler induction air heating |
Hi Gilles,
I have visited your web site quite often the last year during the assembly of our MCR. Very helpful and informative. Regarding carb heat the JAR specification has to be met somehow in order to get a type certificate, and the fact that Dynaero does not offer a carb heat option to their factory built 914 installations the pre certification flight tests must have shown that it was not needed. I am waiting for a mail from dynaero in this matter. In addition it is interesting to hear other peoples experiences.
Best regards
Patrik
Posted: Thu Jan 29, 2009 2:47 am Post subject: 914 w/intercooler induction air heating |
Hi! Gilles.
Happy New Year ...if not too late !
I was concerned about carb. ice with an intercooler fitted to my 914 installation. Especially when the Intercooler manufacturers (Bell) were claiming 25deg temp drop in Winter and 20deg drop in Summer. I have a crude temperature sensor reduxed into a plastic hollow tube to the port carb throat and have never seen less than 6 deg Celsius. Even descending on low power settings through thin cloud formation from 10,000ft after the wind screen in my Europa began to frost over on the inside with minimal cabin heat facility.
Whilst I do understand that carb ice conditions are very humidity and ambient temperature connected this has left me "fairly" confident that ice is not an issue ( I am reluctant to actually say that since next flight .!)
However Rotax do recommend a carb heat facility even with a turbo fitted …but this may be sales justified or more appropriate to tropical applications in real terms.
My air filter is not of the air box type just a simple washable air canister clipped to the turbo intake.
Bob Harrison G-PTAG Europa Kit 337 Now with Rotax 914.
Posted: Fri Jan 30, 2009 9:04 am Post subject: 914 w/intercooler induction air heating |
Hi Ron and all,
closer to ambient)?
According to my test curves, carb temps during descend never went below
40Celsisus on a cold day (OAT 5Celsius ground, -2 Celsius at altitude).
Of course, low power setting does not last long with our aircraft.
Due to the turbo running at dull red temperature just inches below the
carbs, temps can stay relatively high in a close fitting cowling.
Never noticed anything, although I flew the aircraft in rain and drizzle.
Due to air low thermal capacity, charge air temperature doesn't play
much role compared to the red hot exhausts and turbo case.
Best regards,
Gilles
Posted: Fri Jan 30, 2009 10:39 am Post subject: 914 w/intercooler induction air heating |
Patrick
Thank you for your kind words.
| Quote: | Regarding carb heat the JAR specification has to be met somehow in order to get a type certificate, and the fact that Dynaero does not offer a carb heat option to their factory built 914 installations the pre certification flight tests must have shown that it was not needed. I am waiting for a mail from dynaero in this matter. In addition it is interesting to hear other peoples experiences.
As you may have noticed, our engine installation is quite different from
that of Dyn'Aero. We had to send a report with our carb temp number to
the certification authorities to get our certificate of airworthiness.
During ground tests, we had thick freezing fog to the point I was scared
to taxi on the apron lest we collide with a building, a car or an airplane.
After some time ground running at high power setting, we noticed a
slight vibration up front (no power loss nor MP variation). After
stopping the engine, we discovered that the whole airplane was covered
with frost in the prop wash, the air intake lips as well as the prop
leading edges were covered with several millimeter clear ice.
But the carb temps were as usual, and the vibration was attributed to
the ice buildup on the prop blades.
Best regards,
Gilles
Posted: Fri Jan 30, 2009 12:58 pm Post subject: 914 w/intercooler induction air heating |
Hi Bob,
Best wishes for 2009.
| Quote: | I was concerned about carb. ice with an intercooler fitted to my 914
This about what we get with our installation, with an optimized
intercooler inlet diffuser, and clean air exit nozzle.
If the diffuser is not optimal, or the intercooler cooling air exit has
any obstruction the efficiency will be much less.
| Quote: | I have a crude temperature sensor reduxed into a plastic hollow tube
from 10,000ft after the wind screen *_in_* my Europa began to frost
over on the *_inside_* with minimal cabin heat facility.
flight ..!)
Interesting data. We are no longer monitoring carb temps.
Best regards,
Gilles
pasj66
Posted: Sun Feb 01, 2009 2:24 am Post subject: Re: 914 w/intercooler induction air heating |
Thanks everyone for your informative replies. The experience shows that icing is not a problem. The thing is to convince the authorities. I got a response from DynAero and they are a bit secretive and will only communicate the flight test results with the local CAA. I am a bit paranoid having our project grounded due to red tape so maybe a more proactive approach is to include the same measurements as you, Gilles, in our flight test program. How did you perform the measurements? Measurement points, power settings, ambient temperatures etc. What info did convince the authorities? Could you please describe the setup that would be most helpful. Either in this thread or you can mail me directly.
Best regards
Patrik
Thomas
Posted: Thu Feb 05, 2009 2:17 am Post subject: Re: 914 w/intercooler induction air heating |
Hallo,my name is Thomas and I'm a proud owner of a Dynaero 4S with 914.
I'm looking forward to install an intercooler .I'm not sure if it gives anything to me because I'm satisfied with the performance until 8.000ft.
I would like to know the advantages of the intercooler up to 16.000ft.
Thanks for responses
