hotwheels
Posted: Thu Jan 29, 2009 9:33 am Post subject: Switches and Relays |
Is there a general rule of thumb regarding max current load through a switch before it is prudent to add a relay to handle switching higher current loads (similar to S704-1 12v/20A)? Maybe this is spelled out in an AEC doc, but if so I couldn't find it.
A couple of components which might require relay switch protection come to mind including: pitot heat, landing lights, standard nav lights, and maybe fuel pump... each appear to draw 5A or more in steady state.
The AN5812 heated pitot might be a strong relay usage contender as it has a hefty initial current spike followed by a sizable current draw (see AEC article "Gauging Pitot Heater Performance" 15 Feb 2005).
1N5400 (3A/50v) diodes are commonly used on Z-diagram contactors across the low current coil side to suppress current spikes. Similar best practice would seem to follow for S704-1 type relays too?
The 1N5400 diode seems like it would be good candidate. Are mil-spec components advised or is the local Radio Shack sufficient?
I'm all for sweating through the load analysis and thinking things out in advance so as to not end up with arc welded switches later.
Jay
Posted: Thu Jan 29, 2009 1:24 pm Post subject: Switches and Relays |
At 11:33 AM 1/29/2009, you wrote:
What particular situation drives this consideration?
Aside from pitot heaters, toe heaters, and klieg lights
for landing and taxi, you're unlikely to overload the
plain vanilla switches offered by most suppliers. See:
http://aeroelectric.com/articles/Switch_Ratings.pdf
| Quote: | A couple of components which might require relay switch protection
Yes, this is an excellent application for a relay . . .
especially a solid state relay.
| Quote: | 1N5400 (3A/50v) diodes are commonly used on Z-diagram contactors
Yeah, except that the lead wires on a 5400 series
device are pretty hefty and may be difficult to
install as shown in . . .
http://www.aeroelectric.com/Pictures/Relays/s704inst.jpg
| Quote: | The 1N5400 diode seems like it would be good candidate. Are mil-spec
The lowly silicon diode rectifier is the oldest
semiconductor device in the marketplace. It's so easy
to make a really good diode that nobody even bothers
to offer parts screened to military specs. Finally
the electrical stresses on spike catcher diodes is
measured in MILLIJOULES . . . a sneeze in a thunderstorm.
Anything from this list of parts offered by RadioShack
and many others can be considered to your tasks.
http://www.aeroelectric.com/Pictures/Misc/RS_Diodes.jpg
| Quote: | I'm all for sweating through the load analysis and thinking things
I've never seen an arc welded switch that's been
"overloaded". Switches fail open after they burn
for a host of reasons not the least of which is
mechanical inadequacies at riveted joints.
What are the current ratings for systems you're
considering?
( -Thomas Paine 1776- )
hotwheels
Posted: Thu Jan 29, 2009 4:02 pm Post subject: Re: Switches and Relays |
Thanks for the reply.
The biggest current users on my panel are AN5812 pitot heat (~8A steady state after the initial inrush spike is done), landing lights (~4A each), Whelen strobes (~7A total), NAV lights (~6A total) and boost fuel pump (~5A).
My take away from reading the AEC Switch article is that there's no need to protect panel switches except those used to operate the high current starter and battery contactors.
The entire topic really boils down to this paragraph:
"The heaviest currents handled by panel switches are landing/
taxi lights (which have their own special inrush values
-see "lamp" ratings in table above), and pitot heat. For most
14-volt airplanes this is about 8 amps. Everything else drops
rapidly from there. I can also tell you that switching an
8-amp landing light with a 4-amp "lamp" rated switch is not
an automatic formula for welding. The 200% "overload" will
indeed reduce the life of the switch. However, let us suppose
the switch was originally rated for 10,000 cycles (a low
estimate) and the reduction was to 10% of rated life(also
very low) . . . How long will it take you to put 1000 cycles
on your landing light switch? "
Does anyone have the definitions of an "Electrical Code Rating" as referenced in the Microswitch Catalog table? The table would probably make better sense then.
There's a reference to switch cycle life above, but switches aren't typically sold with that information easily obtained up front. Maybe someone has a link to a good website as that info could be useful.
I must be missing something. People must be buying S704-1 relays as B&C sells them and you reference them in several docs... but what are they using them for if there's really no utility in it?
Jay
rv-9a-online(at)telus.net Guest
Posted: Thu Jan 29, 2009 5:49 pm Post subject: Switches and Relays |
I've looked at this in some detail. Since I've had multiple switch failures
(long Carling switch thread), I have looked at relays for switching heavy
loads.
In my new A/C (Harmon Rocket), this thinking has led me to a bank of relays
controlled by grounded switches. I need a bunch of relays for the trim
systems and other stick-grip switches anyway, so I went all the way with all
of my electrical loads switched with relays. While not strictly necessary,
it allowed me to place the relays and breakers off-panel where the heavy
gauge wiring runs were shorter. This saves many dozens of feet of heavy
wiring running back and forth to the panel.
Most of the switches on the panel are grounded to activate the corresponding
relay. This allows me to use a single 22 AWG wiring for each relay control.
I can also use lighter weight toggle switches on the panel, which also
happen to be cheaper. The lighter weight switches and shorter heavy gauge
wiring runs should roughly balance out the relay weights.
Another benefit of this approach is that rotary switches can be used instead
of toggles. For example, I plan one rotary switch for my main lights:
OFF-WIGWAG-PULSE-LDG-TAXI-BOTH. This takes one position on my panel and is
configured to drive my two lamp relays as necessary (left and right wingtip
lamps). Also, I plan on connectorizing the panel... it's a lot simpler with
fewer light gauge wires.
So an architecture based on relays has other benfits other than protecting
switches. These benefits must be weighed against the complexity and
potential failure modes of relays compared to switches. Sometimes, you just
want to experiment!
Vern Little
fvalarm(at)rapidnet.net Guest
Posted: Thu Jan 29, 2009 8:49 pm Post subject: Switches and Relays |
Speaking of switch failures,
I think you had mentioned that you would test the practicality and function
of adding JB weld to switch rivets to see if it would prevent them from
loosening without a downside. Any progress there?
Bevan
RV7A wiring
Peter Laurence
Posted: Fri Jan 30, 2009 5:51 am Post subject: Switches and Relays |
Vern,
About 4 years and 500 hundred hours ago, I wired a velocity for a friend as
per Bob's Z drawings. I too was hesitant about running large wires up the
door post to the overhead switch gang.
I made a box with post terminals in the box and a gang of 13 relays on
top. This was mounted on the forward bulkhead close to the battery.
Have not had to replace a relay yet. However he does keep a couple of spares
in the plane.
Peter Laurence
RV9A N60PL
loads.
want to experiment!
Vern Little
Posted: Fri Jan 30, 2009 4:29 pm Post subject: Switches and Relays |
At 10:13 PM 1/29/2009, you wrote:
| Quote: | --> AeroElectric-List message posted by: "B Tomm" <fvalarm(at)rapidnet.net>
loosening without a downside. Any progress there? |
Some.
I have looked at every riveted Carling switch in
the shop (about 25 pcs) and found none with observably
loose joints.
I did do some tests to determine that the contact
material (which includes the formed rivet head)
is solderable - as are the brass fast-on tabs.
The conditions are favorable soldering the rivets
to the tabs and then covering the joint with a dab
of JB Weld.
This still begs the question as to return on investment
for this effort.
We've identified no changes to process or design
that would account for a rash of failures in these
switches. The design has been essentially unchanged
for decades and what must be many millions of devices.
I'll suggest it's pretty clear that the failures
were not a function of failure to observe ratings.
It's clear that the strongest potential for failure
happens under the formed head of the rivet. If it's
too loose, corrosion can begin and failure is
a sure thing given sufficient time.
The soldering process is not a quick-n-easy thing.
I was able to get good flow to the two materials
but it was a bit fussy. Couldn't be sure that I
wasn't degrading the joint quality at the base
of the saddle inside the switch while I was making
them "better" on the outside.
If you've got switches that are not yet installed,
it wouldn't hurt to beef them up with some JB Weld.
Use the slow setting stuff so you've got plenty of
time to work carefully. You can also mix up a larger
quantity of the slow stuff and do a batch of switches.
[img]cid:.0[/img]
Take care to avoid contaminating the tabs.
I'm not confident that soldering the contact to the tabs
is an "improvement". The epoxy beef-up can't hurt anything
and it may be helpful.
153.3 KB |
651 Time(s) |
Posted: Fri Jan 30, 2009 7:18 pm Post subject: Switches and Relays |
Thanks for the reference Peter.
I too plan to have a spare relay or too handy (or I could swap out a
non-critical one such as Pitot Heat or Nav Lights) for emergencies.
I have relays with interlocking sockets that connect together. This should
make for a stable mounting system.
Vern
