6K2-3 drawing
alex_001
PostPosted: Fri Jan 30, 2009 3:09 am    Post subject: 6K2-3 drawing Reply with quote
Hello, can some one help me with 6K2-3 drawing as my czaw build xl does not have this panel and also in the drawing set i have this is not included
thank you a lot
 Filesize:  21.85 KB
 Viewed:  759 Time(s)
jonaburns
PostPosted: Fri Jan 30, 2009 4:45 am    Post subject: Re: 6K2-3 drawing Reply with quote
Those are just 2 square pieces of .020 sheet. They were about 1.5 or 2 ft square in my kit. I used them for something else, but some people use them as pictured in the center console area.
Jon Burns
alex_001
PostPosted: Fri Jan 30, 2009 5:09 am    Post subject: Re: 6K2-3 drawing Reply with quote
i am looking for some dim. so i can make them. (i will waterjet them as i have such a tool at my work)
DaveG601XL
PostPosted: Fri Jan 30, 2009 7:54 am    Post subject: Re: 6K2-3 drawing Reply with quote
Alex,
These should probably be field-fitted to ensure they are correct for your installation. I used cardboard and drew the rough outline needed and transferred it to the aluminum sheet.
David Gallagher
Cincinnati, OH area
