Instrument module access cover
rparigor(at)suffolk.lib.n
PostPosted: Thu Jan 29, 2009 6:12 pm    Post subject: Instrument module access cover Reply with quote
Hi GroupHas anyone installed an instrument module access cover just to the left of the tray on the curved vertical portion?Any pictures / description what you did?Thx.Ron Parigoris [quote][b]
raimo.toivio(at)rwm.fi
PostPosted: Fri Jan 30, 2009 2:09 am    Post subject: Instrument module access cover Reply with quote
Strange! I have not but desided to do and it was just yesterday!
That is because I need access behind the radiorack and also because
my warning buzzers (stall and gear) are there I cannot hear them loud enough.
I am going to do a net covered acces hole and large enough for my hand.
Raimo OH-XRT
hagargs(at)earthlink.net
PostPosted: Fri Jan 30, 2009 6:06 am    Post subject: Instrument module access cover Reply with quote
I put in a cover and located the fuses under there for my main electrical bus.
Steve Hagar
A143
Mesa AZ
paul.the.aviator(at)gmail
PostPosted: Fri Jan 30, 2009 8:14 am    Post subject: Instrument module access cover Reply with quote
Hi Ron,
I put one in the curved area and it has proved very helpful. I also
have two access panels in my firewall.
I was concerned about negatively impacting the strength of this area
so I reviewed the size, location and radius of the corners of these
access panels with Andy. Andy didn't do any formal analysis or mod
approval, it was more of a "that looks about right" kind of analysis.
Let me know if you want to know more information and I can run out to
the hanger and measure it up.
Paul
g-iani(at)ntlworld.com
PostPosted: Fri Jan 30, 2009 10:55 am    Post subject: Instrument module access cover Reply with quote
Mine covers the access to the serial connectors for attaching a computer to various items. Picture attached
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
 Filesize:  33.38 KB
 Viewed:  351 Time(s)
ptag.dev(at)tiscali.co.uk
PostPosted: Fri Jan 30, 2009 12:55 pm    Post subject: Instrument module access cover Reply with quote
Hi! Raimo.
I have to somehow change my radio stack to accommodate my Mode S Transponder and since it is the top unit it is out of sight from the engine side of my FWF removable panel.
I expect that I will cut out a sizeable panel, construct some flanges and make such a flap removable since my panel is not removable. I don’t consider the Europa Panel to be a structural item anyway and provided such cut out is re-enforced I don’t see a problem.
Bob Harrison G-PTAG
PS if Steve Hagar is reading this his reply re:- fuses in such a place concerns me that he can access the fuses from the P1 position if he has to change one in flight?
Bob H
PostPosted: Fri Jan 30, 2009 9:35 pm    Post subject: Instrument module access cover Reply with quote
Hi Paul"Let me know if you want to know more information and I can run out to the hanger and measure it up. "Please do!Thx.Ron Parigoris [quote][b]
