longg(at)pjm.com Guest
Posted: Mon Jan 26, 2009 8:41 am Post subject: Fat Wire Terminals |
I was out soldering fat wire terminals in the hangar yesterday. There I was with Bob’s directions performing the duty as described. I poked the little 14 ga points in to fill the gaps and started adding in the solder – beautiful job, it oozed out the other end with a completely uniform ring of solder around the back edge of the terminal. Ok, nothing to do but add the shrink wrap – oops, here comes another pilot – certain trouble. Hey buddy, you know that solder is really good stuff, but you should crimp the terminal “after” you solder it.
What do you guys think? To me that would simply damage the solder job and add little value to the actual security of the wire.
Glenn
echristley(at)nc.rr.com Guest
Posted: Mon Jan 26, 2009 9:32 am Post subject: Fat Wire Terminals |
longg(at)pjm.com wrote:
The point of crimping is to squash a bunch of pieces of copper into one
airtight lump of copper. The point of soldering is to fill the voids of
a bunch of pieces of copper with a lead/tin mixture. What would be the
point of squashing after everything is already airtight?
I think this is one where you smile, say "Really? I might try it that
way next time.", and let the guy walk away. You might ask him about the
purpose behind the separate processes; but, that might lead to an
argument, which cuts into build time. Gotta protect your build time.
Posted: Mon Jan 26, 2009 10:36 am Post subject: Fat Wire Terminals |
At 10:38 AM 1/26/2009, you wrote:
| Quote: | I was out soldering fat wire terminals in the
Skilled soldering or well designed crimps are
interchangeable in terms of reliability. They
differ only in skill sets, tools and materials
to do the job. Doing both only goes against the
design goals both and runs a risk of degrading
what WAS a perfectly good joint.
Rather than going to the List to take a vote,
why not show the visitor the article and then
as him to make the author's day and show him
where he screwed up?
An too common response to contrary opinions
in our culture is to throw it out to "all
the folks" with some notion that a majority of
common belief is the path to golden information.
It's far better than these things be first argued
by individuals with an understanding of the simple-ideas
that support the technology or process being
discussed. It's almost never useful to debate
such things by participants at large in open forums.
( -Thomas Paine 1776- )
Posted: Mon Jan 26, 2009 10:37 am Post subject: Fat Wire Terminals |
At 11:29 AM 1/26/2009, you wrote:
<echristley(at)nc.rr.com>
<snip>
| Quote: | I think this is one where you smile, say "Really? I might try it
that way next time.", and let the guy walk away. You might ask him
about the purpose behind the separate processes; but, that might
lead to an argument, which cuts into build time. Gotta protect your build time.
Right on! Better yet, sic'em onto me. It's
MY job to field these issues so you guys can
make better use of your $time$ doing a good
job.
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27324 Location: Livermore CA USA
Posted: Mon Jan 26, 2009 11:21 am Post subject: Fat Wire Terminals |
At 10:34 AM 1/26/2009 Monday, you wrote:
>I was out soldering fat wire terminals in the hangar yesterday. There I was with Bob’s directions performing the duty as described. I poked the little 14 ga points in to fill the gaps and started adding in the solder beautiful job, it oozed out the other end with a completely uniform ring of solder around the back edge of the terminal. Ok, nothing to do but add the shrink wrap oops, here comes another pilot certain trouble. Hey buddy, you know that solder is really good stuff, but you should crimp the terminal “after” you solder it.
It would seem that crimping *after* soldering is a sure way to ruin a good termination. However, adding a small dab of well wetted solder to the *lug* end of the terminal after crimping seems like a good belt-n-suspenders approach to me. What do you think of this technique, Bob?
RV-8 #82880/N998RV (res)
135.74 KB |
272 Time(s) |
257.57 KB |
273 Time(s) |
_________________ Matt Dralle
Posted: Mon Jan 26, 2009 12:06 pm Post subject: Fat Wire Terminals |
At 01:20 PM 1/26/2009, you wrote:
| Quote: | At 10:34 AM 1/26/2009 Monday, you wrote:
<nuckolls.bob(at)aeroelectric.com>
<snip>
| Quote: | It would seem that crimping *after* soldering is a sure way to ruin
technique, Bob?
What you've shown us certainly doesn't hurt
as long as you don't get solder on the washer-
surface of the terminal and make it "un-flat".
But I cannot offer that it adds anything
useful.
Posted: Mon Jan 26, 2009 1:07 pm Post subject: Fat Wire Terminals |
Matt Dralle wrote:
Matt, I don't want to scare you, but you do know that the weavers of
certain south-western native american tribes would purposely make a
mistake in the weave. The belief was that if you did something perfect,
it would be an indication that you were ready to join the gods. You
might want to be careful there.
Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Mon Jan 26, 2009 6:04 pm Post subject: Fat Wire Terminals |
So, while on the subject,
I also read Bob's article on soldering those terminals. I ordered a bunch of terminals from B & C and also bought their hammer-crimper. Wasn't sure whether I wanted to crimp or solder. The terminals came and had so much space in them that I wasn't sure I could fill in with a reasonable amount of additional copper wire. There was probably 1/8 th inch extra besides the #4 wire. I spoke with Bill at B&C. Heck of a nice guy. He double checked and thought the terminals were correct. I ended up using their crimper instead of soldering. Got a very tight crimp that I could not pull apart. I am not sure if it is air tight and was scratching my head about adding solder. Overkill, right?
Michael Wynn
RV 8 FWF
San Ramon, CA
In a message dated 1/26/2009 10:39:18 A.M. Pacific Standard Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
| Quote: | --> AeroElectric-List message posted by: Ernest Christley
<snip>
job.
= Use lities y - MATRONICS WEB FORUMS =========================< - List Contribution Web Site ; =========================
A 100000075x1215855013x1201028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
_________________ Michael Wynn
RV 8
San Ramon, CA |
jon(at)finleyweb.net Guest
Posted: Mon Jan 26, 2009 10:08 pm Post subject: Fat Wire Terminals |
Well said Bob. I sure wish this was more widely understood (on a very wide
scale - not just aviation).
Jon
DO NOT ARCHIVE
<snip>
Posted: Tue Jan 27, 2009 5:46 am Post subject: Fat Wire Terminals |
At 08:02 PM 1/26/2009, you wrote:
| Quote: | So, while on the subject,
I also read Bob's article on soldering those terminals. I ordered a bunch of terminals from B & C and also bought their hammer-crimper. Wasn't sure whether I wanted to crimp or solder. The terminals came and had so much space in them that I wasn't sure I could fill in with a reasonable amount of additional copper wire. There was probably 1/8 th inch extra besides the #4 wire. |
If the wire isn't pretty snug on the temrinal
before you "stuff it" with copper wedges, it's
not the terminal for that wire . . .
| Quote: | | I spoke with Bill at B&C. Heck of a nice guy. He double checked and thought the terminals were correct. I ended up using their crimper instead of soldering. Got a very tight crimp that I could not pull apart. I am not sure if it is air tight and was scratching my head about adding solder. Overkill, right? |
If you cannot verify the integrity of the crimp,
then adding solder is not a bad idea.
