HBaker
Posted: Sun Jan 18, 2009 2:30 pm Post subject: Tachometer |
Is there a mechanical tachometer out there that is not in % of rpm that I can put on the M14P, and does it install in the center of the air start?
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
_________________ Currently building a Murphy Moose - any help would be appreciated. |
Posted: Sun Jan 18, 2009 8:21 pm Post subject: Tachometer |
Why not use a Horizon Instruments Tach? You can have it set up any way you want it. http://www.horizoninstruments.com/prod01.htm. Many of the people with CJ6's that have an M14 engine have Horizon Tachs installed.
Dennis
george(at)gesoco.com Guest
Posted: Mon Jan 19, 2009 5:49 am Post subject: Tachometer |
Mechanical tachs generally work on the speed of the camshaft. That is 50%
of the crankshaft speed. The only place that the cam speed is available to
drive a tachometer on the M14 is at the center of the air start. The magneto
rotor is the only other part that rotates at 50% of the crankshaft speed.
There are many tachometers that run from magneto electrical pick up will
also work. Be wary of the ones that actually connect to the "p" lead as a
tachometer failure could result in a magneto failure.
You could also have your Russian tachometer face remarked to actual
RPM instead of % RPM.
George Coy
Coy Aircraft Sales
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com
SKYPE george.coy
Posted: Tue Jan 20, 2009 9:55 am Post subject: Tachometer |
I agree with George that there is always risk involved when you start
messing around with P Leads and connecting anything to them. If not
done with careful design and proper caution, hooking anything (else) to
the P Leads can also easily result in a massive increase in radio noise
as well. That said, this model: HORIZON INSTRUMENTS MODEL P-1000 TACH
has worked extremely well in at least five M-14 equipped aircraft that I
am aware of, and allows you to totally remove the mechanical TACH
TRANSMITTER that attaches to the engine, which in my experiece tends to
have a rather poor track record for long term reliability.
The P-1000 Tach also gives you a safety BENEFIT in that it will
instantly tell you if you have a failed mag. I mean really... How many
of us fly along and check the mags while airborne? This device will
give you an immediate indication of a mag failure, which is a lot better
than finding that out just before taking off when doing your usual mag
check. In addition, it has engine overspeed LED's that will alert you
should your engine go over a certain "limit" speed. And, it also
includes engine time recording, etc., etc. This model includes an
internal opto-isolator design that makes the possibily of it causing a
mag failure to be extremely remote, although of course nothing is
impossible.
Here is a place to read about it. Out of all the "P Lead" tachs, this is
the only one I would recommend. Be advised of one big point though...
In every case where someone else installed one of these things on their
own aircraft, there has been a very real and noticable increase in "P
Lead" induced radio noise. I have had to go back and rip out poor
wiring, and use high quality shielded wire and proper lead bonding and
grounding to deal with this, so it is best the wiring of this device to
an A&P or otherwise highly qualified Avionics type of guy. STRONG
emphasis on this.
http://www.aircraftspruce.com/catalog/inpages/p1000digitaltach.php
Mark Bitterlich
N50YK
HBaker
Posted: Mon Jan 26, 2009 12:32 pm Post subject: Re: Tachometer |
Thanks Dennis I have decided on the Horizon Instruments tachometer on the Moose, since I only need the Tack, a lot simpler.
Thanks Henry
HBaker
Posted: Mon Jan 26, 2009 12:33 pm Post subject: Re: Tachometer |
What markings of the Horizon Instruments Tachometer is standard for the M-14? Green, Caution, Red (RPM's).
HBaker
Posted: Wed Jan 06, 2010 9:05 am Post subject: Re: Tachometer |
Hi Mark
I have a electronics guy hooking up the Horizons tack that I purchased last year, We were going to wire it into the avionics switch, to be turned on after we have started the engine and have switched to mags, because he heard the booster coil is hard on the micro-processor . any thoughts on this??
Henry
Posted: Wed Jan 06, 2010 9:49 am Post subject: Tachometer |
I have no personal experience with problems in this regard. As in...
Booster coil energy damaging the Tach. No one that I know of who has
installed this Tach has EVER had this problem. But, he may know
something I do not! Who knows?
Keep this in mind if you will.
The electrical path of the energy supplied by the booster coil for
starting, follows a completely different path than the energy that comes
from the mag AFTER starting. This is important to understand, so let's
continue.
The very only things that are used during starting in the mag are:
1. A retarded rotor point that makes contact with the BOOST COIL energy
through a slip ring.
2. The mag cap, where the spark plug wires actually connect.
THAT IS IT! Nothing else in the mag is used during starting except for
the mechanical parts that make the thing rotate when the engine turns.
With a good system, you can actually start and run the engine with the
starting circuit alone. I am not recommending that you DO this,
although I have for testing purposes.
There is a very brief period of time during starting where the starter
button is pushed, the engine has started on the booster coil energy
firing the spark plugs, the mags are turned on (P LEADS BECOME
UN-GROUNDED) and there is spark energy from both the mag itself (going
to a DIFFERENT contact point on the rotor) AND the boost coil retarded
rotor point.
So how is this going to impact the P leads and damage a Horizon Tach? I
don't see any way that it could, except for one thing, shielding. More
on that in a moment.
Also, there is no electrical "surge" in these aircraft because there is
no collapsing inductive magnetic field pulse from an electrical starter.
But now we come to shielding.
If you have bad shielding in ANYTHING... That means Booster Coil High
Voltage, it is ....in theory .....possible that it could get into the
main 28 VDC power source and cause damage to any kind of Avionics.
That said, let's go in a different direction for a second. The Horizon
Tach hooks to the P leads. The P leads contain a TON of RF noise from
the mags. That is why they are shielded. However, the actual P leads
themselves... BOTH OF THEM... Run into this Tach. It is entirely
possible for this noise energy to go into the Tach, and come back out on
the main 28 volt wiring that POWERS this Tach. Now you have this crap
getting into everything. Especially if you connect these wires to the
exact same circuits that are powering your RADIOS.
I am not saying this will happen. The engineers who designed this TACH
just HAD to take great efforts to try and prevent this. But I am saying
that more than one person has had significant noise problems when using
a Horizon Tach, and most ESPECIALLY with Becker Radios. Not ALL mind
you, but some.
So, my thoughts are that if you are going to hook it up this way, it
would be wise to put an RF noise filter on the power leads to the
Horizon Tach. Not to keep outside stuff from getting into the Horizon,
but to keep stuff in the Horizon from getting out and onto main aircraft
power wiring.
This can be as simple as using a torroidal core with the power wires
wrapped through them several times. Can't find one of those? Go look
around for an old computer monitor. Not the flat screen type, the old
big ones with a CRT. Look at the cables going to it. One of them will
have a big BULGE in the cable. Chop this off and carefully slice it
apart. Inside you will find a torroidal core with the wires wrapped
through it. They put it there for the same reason I am suggesting
putting it on the Horizon Tach power leads. You can also wrap the P
leads through one too.
Mark
HBaker
Posted: Thu Jan 07, 2010 12:16 pm Post subject: Re: Tachometer |
Mark
First , thanks for clearing up so many things . I guess maybe I should wire it straight in, to prevent it going to the radio circuit at all. I'll will talk it over with the avionics guy.
Henry
Posted: Thu Jan 07, 2010 2:26 pm Post subject: Tachometer |
No problem. Use a few toroids on the power leads. Even if they are just plain ole donut types. Your Avionics guys SHOULD know what I am talking about.
Mark
 Download |
| Filename: |
smime.p7s |
5.09 KB |
| Downloaded: |
1050 Time(s) |
HBaker
Posted: Thu Jan 07, 2010 6:52 pm Post subject: Re: Tachometer |
Yes Mark, he knew exactly what you were talking about as soon as I mentioned it , me I never had the foggy est clue:oops:
Posted: Fri Jan 08, 2010 12:34 pm Post subject: Tachometer |
Nothing to be embarrassed about. I do this kind of thing for a living.
Mark
 Download |
| Filename: |
smime.p7s |
5.09 KB |
| Downloaded: |
1001 Time(s) |
