dcubj3(at)terra.com.br Guest
Posted: Sun Jan 25, 2009 4:35 pm Post subject: KF IV Distance from DATUM to center of wheel |
Hi!
Someone knows which is the distance from DATUM line to "center of wheel" in Kitfox Model IV ??
See jpg attached of Highlander (www.justkitplanes.com)
I need the same image of Kitfox IV, to find answer to my question.
Can you help me?
Tks
FD
www.dcubj3.com.br
[img]cid:EAA80A4E759F477B86BDBC9E17027B5B(at)compa563fded83[/img]
31.16 KB |
727 Time(s) |
eskflyer
Posted: Sun Jan 25, 2009 4:52 pm Post subject: Re: KF IV Distance from DATUM to center of wheel |
Need one more answer to answer your question . What landing gear are you using ? wide tall gear ?. Narrow gear?. or the spring gear ?.
ex718PD
New 3579erA
_________________ FLY FUN FLY LOW FLY SLOW
John Perry
Kitfox 2 N718PD
582 cbox 2:62-1 IVO IFA
1220 Full Lotus |
Guy Buchanan
Posted: Sun Jan 25, 2009 5:22 pm Post subject: KF IV Distance from DATUM to center of wheel |
At 04:30 PM 1/25/2009, you wrote:
| Quote: | Someone knows which is the distance from DATUM line to "center of wheel" in Kitfox Model IV ??
| I'll try this again, Francisco,
At 03:15 PM 1/17/2009, you wrote:
| Quote: | IŽd like to know if my spring aluminium (Grove Type) landing gear is in correct position.
with this configuration, could be dangerous to land? |
Francisco,
Sad to say it does appear that your landing gear are further aft than is typical with Grove gear. However, the only thing that matters are the numbers. My plane has its axle 1.875" (48mm) behind the leading edge when in the measurement configuration, which means the lower door sill / fuselage bottom is horizontal, and the plane is "empty". When in that configuration, 7.3% of the weight is on the tail wheel. (The tail wheel is 163" (4140mm) behind the leading edge.) Also in that configuration my CG is 13.68" (347mm) behind the leading edge. Let us know how that compares to yours.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Paul A. Franz, P.E.
Posted: Sun Jan 25, 2009 5:53 pm Post subject: KF IV Distance from DATUM to center of wheel |
On Sun, January 25, 2009 4:30 pm, Francisco Drovetta wrote:
| Quote: | Hi!
Model IV ??
For ease and safety in landing, the gear should be set as far forward as practicable.
The limit is usually dictated by the fuselage structure, that is, you can only mount
it to the forward limit of the fuselage. But in your case with what looks like a
forward mounted and heavy engine, weight and balance might be the limiting factor.
If you can supply the moment arms and weights of your existing setup, I can calculate
what happens when you move the gear.
I would need:
moment arm and weight of the main gear
moment arm and scale weight of tail wheel
moment arm and weight on main gear (empty, no fuel or oil) at tire contact point
moment arm for oil in crankcase
moment arm for fuel in tanks.
moment arm for occupants
moment arm for baggage
If the existing gear is not going to be used then I need the weight of the proposed
gear and location of it's c.g. relative to the fore and aft mounting positions.
Can you help me?
Tks
FD
www.dcubj3.com.br
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Paul A. Franz, P.E.
Posted: Sun Jan 25, 2009 6:07 pm Post subject: KF IV Distance from DATUM to center of wheel |
| Quote: | Hi!
Model IV ??
Check out the photo of Bruce Hoisington's Series 7 KF with what appears to be Grove gear.
<http://www.kitfoxaircraft.com/images/Recent%20Completions/BHoisington.htm>
It looks like the gear is mounted about where yours is, slightly behind the datum
(leading edge of wing).
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Bellevue WA
425.241.1618 Cell
lcfitt(at)sbcglobal.net Guest
Posted: Mon Jan 26, 2009 8:33 am Post subject: KF IV Distance from DATUM to center of wheel |
I suspect that what Francisco actually needs is the location of the axle
relative to the CG. I think the easy way to approximate this is by
tailwheel weight vs. empty weight. My first Kitfox had a tailwheel wt of 44
lbs. vs an empty wt of 704 lbs. - yes a heavy. This gives 6.25% on the
tailwheel. From what I see in the pictures on Francisco's website, I
suspect his emtpy weight in the 850 lb range giving a tailwheel weight in
the range of 53 lbs. This in level attitude.
Lowell
Posted: Mon Jan 26, 2009 5:40 pm Post subject: KF IV Distance from DATUM to center of wheel |
Mr. Lowell Fitt
Mr. Paul Franz
Mr. Guy Buchanan
Tks a lot for useful information.
Attached is excel file W&B of my aircraft info.
Tks
FD
www.dcubj3.com.br
 Download |
| Filename: |
PESO_BALANCEAMENTO_PU-KFV_FRANCISCO_DROVETTA02.xls |
25.5 KB |
| Downloaded: |
676 Time(s) |
Posted: Mon Jan 26, 2009 10:06 pm Post subject: KF IV Distance from DATUM to center of wheel |
Well, Francisco, I wasn't too far off with the empty weight estimate, and it
should fly fine based on your W&B numbers, but the tailwheel wt. should be
much heavier. Since you have the spring gear, could you fabricate an
extension that could be bolted to the gear at the axle attachment, extending
the axle forward in increments until you get the 55 lbs. that you should
have with that empty weight and that then would be your proper axle
location. You could then fabricate new attachment points for the spring
gear or maybe use tube gear that would angle forward to the correct axle
location.
Lowell
Guy Buchanan
Posted: Mon Jan 26, 2009 10:39 pm Post subject: KF IV Distance from DATUM to center of wheel |
At 05:39 PM 1/26/2009, you wrote:
| Quote: | Attached is excel file W&B of my aircraft info.
Tks
Francisco,
My IV build manual shows a CG range of 10.7" - 14.8". The
latter was changed by service letter to 16". Where did you get your
numbers? Also, did you obtain your pilot location by weighing the
aircraft with the pilot in it? When I did my W&B I weighed with and
without pilot. I found the pilot location to be 15.8" behind datum.
Finally, is it true that your aircraft is not really a Kitfox IV, but
a copy? If so, I guess that none of this really matters, since it
appears your plane flies just fine.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Paul A. Franz, P.E.
Posted: Tue Jan 27, 2009 4:11 am Post subject: KF IV Distance from DATUM to center of wheel |
On Mon, January 26, 2009 10:01 pm, Lowell Fitt wrote:
location.
That would be more difficult than just calculating the effect of moving it. Using his
spreadsheet numbers for weights and moments I could easily do that if I only knew the
weight of his main gear. That is the weight of the assembly that would be moved
forward.
My concerns are getting the proper allowable weight and balance envelope for his
particular airplane as moving the main gear forward will alter the CG. Ideally it
should be moved forward as far as possible. The limits would be one of:
1) practical forward limit for attaching the gear to the structure
2) forward CG limit
3) maximum allowable tail wheel weight.
I think normal conventional design is a tail wheel weight of 5 to 10% of the gross
weight. This might be limited by the tail wheel spring(s) or the tail wheel itself.
But, I think it could be much higher than 55 lbs. Certainly it needs to be higher than
the 15 lbs he shows now.
So, if you know the weight of the main gear assembly that would be moved or in the
case of changing gear types, the weight of the old and the weight of the new, I can
calculate new weights at the wheels for any new gear position. In fact, I could do it
in spreadsheet fashion so you could just plug in the new moment arm and get the
results.
I guess one could do it for plugging in both the weight and the position. For me it's
a matter of time available.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Bellevue WA
425.241.1618 Cell
propellerdesign(at)tele2. Guest
Posted: Tue Jan 27, 2009 5:01 am Post subject: KF IV Distance from DATUM to center of wheel |
Moving the gear a few inch forward will not move the CG much, it will add
weight to the tail.
most taildragger have the main gear close to the leading edge of mean
aerodynamic chord, just a few inch behind.
the main wheel should be so placed that a line from wheel axle to CG is
15-25deg with tail up, meaning we need to know not just the cg in length but
also height position.
Jan
Tom Jones
Posted: Tue Jan 27, 2009 6:29 am Post subject: Re: KF IV Distance from DATUM to center of wheel |
Tks |
Francisco, the primary issue I see in your weight and balance sheet is that the axle centerline is only 1.7 inches forward of the forward CG limit...assuming one degree forward wing sweep.
The 'Most adverse forward" on your sheet should be labeled 'Most adverse aft". Doing some quick and dirty math with the 154 pound pilot, 30 pounds fuel and no baggage, I calculate a "Most adverse forward" CG of 12.0 inches and gross weight 1069 for your plane. With these numbers the axle is still only 3.74 inches forward of the CG.
To compare, my Classic 4 axle center line is 2.5 inches behind the datum and the forward CG limit is 10.2 inches. Axel is 7.7 inches forward of forward CG limit.
My actual calculated most adverse forward CG is 12.3 inches at a gross weight of 796 pounds. The axle is 9.8 inches forward of CG.
Your plane will also have more inertia due to the heavier gross weight. Just a little too much brakes or a gust of a tail wind and your beautiful plane will be on its back.
I would not taxi until this condition is resolved.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Float Flyr
Posted: Tue Jan 27, 2009 7:45 am Post subject: KF IV Distance from DATUM to center of wheel |
Lowell:
I just ran a couple of calculations and I think he needs to move his main
wheels ahead to position 3.21 in. aft of datum to provide 45Lb. on the tail
wheel at empty weight.
I think all aboard will agree 15 lb is way too small a weight on the tail
wheel for a close to 900 lb. plane. In the mean time he should keep his
feet off the brake pedals.
Just for the fun of it my calculations started with
45lb on the tail (at)151.8in. = 6831 an increase in moment at the tail of
4486. This moment to be subtracted from the total of the main moments.
(3610.28+3573.85)-4486 698.13
I then subtracted the 29.55 lb added to the tail from the total of the front
wheels. (437.08+432.67)-29.55=837.2
Finally 2698.13/837.2= 3.22 that is just about a full five inches forward
from where it is now.
Truth is because the landing gear itself has weight it will probably put
slightly less than 45lb. on the tail wheel.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Tom Jones
Posted: Tue Jan 27, 2009 8:34 am Post subject: Re: KF IV Distance from DATUM to center of wheel |
I did some "What if" computer weight and balance assuming 50 pounds for the landing gear. With Francisco's weight and balance numbers the 50 pound gear can be moved to zero inches from the datum (at wing leading edge) and it moved the empty weight CG only about a half inch forward.
I think there is room in the numbers to move the gear forward enough that the tail weight will take care of its self.
Classic IV
Ellensburg, WA |
Posted: Tue Jan 27, 2009 8:57 am Post subject: KF IV Distance from DATUM to center of wheel |
If wing cord is same on BrazFox as Kitfox wheel should be at same distance
from leading edge of wing.
(datum is something that can be placed any where, but is convenient to have
on same place as other of same brand.
Jan
www.jcpropellerdesign.com
Float Flyr
Posted: Tue Jan 27, 2009 8:59 am Post subject: KF IV Distance from DATUM to center of wheel |
C of G is fine for flight. But only having 15 lb on the tail wheel means he
won't have to use very much brake to turn it on its nose.
Especially on a short field landing. One thing for sure he won't break any
tail springs.
Noel
Kitfox III-A
Float Flyr
Float Flyr
Posted: Tue Jan 27, 2009 10:11 am Post subject: KF IV Distance from DATUM to center of wheel |
Re ran my calculations for a 65 lb tail wheel the answer comes out that the
main wheel should be .41 in ahead of the datum. This maintains the current
C of G
Noel
Kitfox III-A
Float Flyr
Posted: Tue Jan 27, 2009 11:44 am Post subject: KF IV Distance from DATUM to center of wheel |
I just did a search on the web to try to get a handle on what the weight on
the tail wheel should be for similar configured airplanes, if not similar
weight. I checked C-180s and Pa-18s They both have the tail wheel out under
the rudder. They were all around 5.5% of total weight on tail give or take
0.1% except for one Super Cub that was way down at 4.6% and that guy was
having problems with his W&B.
Going by that search, and limited data, I calculated the tail of the plane
should be around 48.68 lb. Give or take a pound or two. To get that weight
on the tail wheel without changing the CG would require the mains be located
2.31 in aft of the datum. I double checked the calculations and that
includes the movement of the weight of the mains. I think he will be safe
by moving the mains 5" ahead. His plane should have the same flight
characteristics but be a lot safer landing.
Any way we want to cut the grass I think we all concur that the mains are
much too far aft to be safe if any braking is to be used. If he doesn't
mind loooooooong run outs and stays away from rough strips the gear that far
aft probably somewhat reduces the possibility of a landing loop as does the
far aft gear on a tricycle gear plane.
Noel
Kitfox III-A
